TheGam1ngK1ng Posted March 25, 2016 Report Share Posted March 25, 2016 I have a 1978 Datsun B210 with the A14 engine. I am reassembling the engine, but I'm missing the head studs. Where can I buy head studs for this car, or is there anyone willing to sell them to me? Thanks guys Quote Link to comment
Draker Posted March 25, 2016 Report Share Posted March 25, 2016 Are A12 and A14 studs the same? There is a guy from texas on here parting an A12. Quote Link to comment
Draker Posted March 25, 2016 Report Share Posted March 25, 2016 http://community.ratsun.net/topic/69009-a12auto-going-to-the-recyclers-tomorrow/ Quote Link to comment
roadkill2525 Posted March 26, 2016 Report Share Posted March 26, 2016 http://arp-bolts.com/kits/ARPkit-detail.php?RecordID=1117 Quote Link to comment
datzenmike Posted March 26, 2016 Report Share Posted March 26, 2016 You should be able to get grade 10 fasteners for about 1/4-1/3 the price of ARP from a fastener store, even if they have to order them. Measure the thickness of the head and make sure they are all the same length. Allow for head gasket and washer plus measure down into the block to find the thread depth. Make them slightly shorter or add washers so the bolt does not bottom out in the block. Not rocket science. One of the bolts may be narrower to allow oil up from the block to oil the rocker arms??? Ask someone. Quote Link to comment
squatches Posted March 27, 2016 Report Share Posted March 27, 2016 Nissan can still get them. I'll get the number in morning. Quote Link to comment
datzenmike Posted March 27, 2016 Report Share Posted March 27, 2016 A14 bolts... 11056-H2301... qty.... 9 11057-H5700... qty.... 1.... this one might be narrower so oil can pass up along side it from the block to the oil feed to the rocker arms Quote Link to comment
KELMO Posted March 27, 2016 Report Share Posted March 27, 2016 Mike is correct (I know, he is always correct), if I remember right, the smaller head bolt will have a "T" stamped in it and goes in the middle hole on the same side as the fuel pump. So, the thread is titled "head studs" and we have been talking about head bolts. If you are in need of the studs that hold the manifolds on.....see below. manifold stud: up to 07/75 08213-82810 qty 11 from 08/78 08223-83010 qty 2 & 08213-82810 qty 9 nut: 08911-20810 qty 11 (the # I just recently used is: 08911-1082A) lock washer: 08915-1381A qty 5 plain washer: 14037-E3000 (by the part # I do not think this is a plain washer, it should be a fat somewhat curved yoke that helps hold intake and exhaust together) qty 2 yoke: 14037-32200 qty 4 ( the # I recently used is 14037-N3600) Most if not all of the part #'s are still available from Nissan (well, within the last 6 months) Quote Link to comment
