Eomund Posted March 13, 2016 Report Share Posted March 13, 2016 So I was driving home last night and started to hear a god awful squealing from under my dash and my speedo started bouncing around like crazy. Immediately pulled over and popped the speedo cable out to prevent any possible further damage. I've determined it's the cluster unfortunately. Has anyone dealt with this. Is it repairable, or should I start shopping for a replacement? Thanks! 1 Quote Link to comment
MikeRL411 Posted March 14, 2016 Report Share Posted March 14, 2016 In all honesty I would first have the speedometer cable to the transmission lubricated. Graphite "oil dag" is better than "water dag" and both are better than straight powdered graphite. A very far out alternative is that the solder joint between the speedometer drive shaft and the copper drag cupstarted to crack and the cup is rubbing the housing. The crack would induce a wobbling needle as the magnetic coupling varied with the angle between the cup and the rotating magnet at the end of the drive shaft. Good luck in solving this problem! 1 Quote Link to comment
MicroMachinery Posted March 14, 2016 Report Share Posted March 14, 2016 I've had this happen. Interested to see what your issue is. 1 Quote Link to comment
4perrev Posted March 15, 2016 Report Share Posted March 15, 2016 Had it on an Acura back in the day.pulled the cable and greased the heck out of it. Worked for a minute and came back. Took the speedo out and the two plates inside were bent. Tried to straighten, but didn't work. Went to a junkyard and pulled an RX-7 and it worked great. Datsun, maybe just Datsun parts. 1 Quote Link to comment
Charlie69 Posted March 15, 2016 Report Share Posted March 15, 2016 Here in Phoenix we have Dick's speedometer repair. He does all the law enforcement vehicles here so a civilian speedometer is a time taking repair. It usually costs about $175. I would suggest sourcing another speedometer if it is not the cable. Quote Link to comment
4perrev Posted March 25, 2016 Report Share Posted March 25, 2016 Did you find the mouse yet? 1 Quote Link to comment
mrbigtanker Posted March 26, 2016 Report Share Posted March 26, 2016 What he said on top. Also make sure if you fucked with it that its lined up properly in the hole and the cable screw is tight and even. 1 Quote Link to comment
4perrev Posted March 28, 2016 Report Share Posted March 28, 2016 Tight, like a tiger and well lubbed!! 1 Quote Link to comment
Eomund Posted April 24, 2016 Author Report Share Posted April 24, 2016 Haven't had a chance to pull it yet. My alt died, so that had to be dealt with first. Ima gonna try and pull it tomorrow, just to see what I'm dealing with. If it turns out the thing is beyond repair for any reason, I guess I'll be hitting you guys up for a gauge cluster :p 1 Quote Link to comment
Eomund Posted April 24, 2016 Author Report Share Posted April 24, 2016 Pulled it apart, way more simple than I expected, as per par with this truck. I lived behind the wheel mechanism, and fed grease into where the cable goes into. Not sure how permanent the fix will be, I'll let you all know. For now it's working perfectly though. 1 Quote Link to comment
4perrev Posted May 2, 2016 Report Share Posted May 2, 2016 Nice job. They are pretty simple little truck as most everything is mechanical. You'll find that most repairs can be found here cause somebody over the years already did what you're about to do. 1 Quote Link to comment
Eomund Posted May 2, 2016 Author Report Share Posted May 2, 2016 True. Unfortunately, I found nil on the Speedo. Why I had the mentality, if I gotta replace it, might as well try and fix it first. Info or no. 1 Quote Link to comment
