Pacific coast Datsun Posted October 16, 2008 Report Share Posted October 16, 2008 Ok did the search 1st & it's not workin for me. OK heres the deal, on the way up to JCCS last Sunday the rubber surrounding the carrier bearing decided to give out / it's not there anymore. The part was replaced a few years ago so i know the bearing itself is still good. What id like to do is to repair / replace the rubber surrounding the bearing. I seem to remember somebody here doing this with good results..i wanna say it was Datzenmike. Id like to know what material was used. I really dont want to have to repace the entire part, i remember it being a pain & i actually broke my vise removing the old part...:blink: TY in advance... Quote Link to comment
]2eDeYe Posted October 16, 2008 Report Share Posted October 16, 2008 I wrapped the bearing in leather (a belt) once and it worked ok to get me home. :P Quote Link to comment
datzenmike Posted October 16, 2008 Report Share Posted October 16, 2008 I did do mine when it had the center bearing. I removed the top U shaped metal surround that clamps the rubber against the lower base. I used a strip of conveyor belt from a gravel pit. It was about 3/8" thick. I used a steak knife but recently used some to help isolate my rad from vibration and used a jigsaw. Faster and safer. Cut a long strip just wide enough to fit the stationery outer race of the drive shaft bearing, I forget 1 1/2" maybe? Wrapped it around and around like a jelly roll, until big enough that the U clamp would hold it tightly against the base half when bolted down. 4-6 turns around, I forget. May have used that soft black wire to hold it while clamping it down. Don't remember having any problems with it unwinding or anything while working with it, a couple of test fits and it was on. I only intended it as a temporary fix till I could find a new one but it worked so well there was little reason to bother changing it. Had it on for years. The conveyor belt was a sheet of rubber with layers of cotton or nylon fabric inside. (like a tire) It was an old belt so I got 5 feet of it for the asking. I think I used some for my body lift too. Quote Link to comment
Pacific coast Datsun Posted October 16, 2008 Author Report Share Posted October 16, 2008 D-mike thank you so much for the info. I have time to search for the kind of rubber you described. I dont drive the truck that much so im sure it'll hold fine. Steve...i dont wear belts, i like my dickie's droopy.:lol: Quote Link to comment
240ADAM Posted October 16, 2008 Report Share Posted October 16, 2008 I know someone who just replaced there whole driveline with a stock 510 wagon driveline, i guess it fit great, no more carrier bearing.:D Quote Link to comment
moparvwfreak Posted October 16, 2008 Report Share Posted October 16, 2008 i recently did it myself. not to hard but i dont think i got it all the way pressed on. i'll have to pull it out and take another look someday soon. Quote Link to comment
datzenmike Posted October 16, 2008 Report Share Posted October 16, 2008 I know someone who just replaced there whole driveline with a stock 510 wagon driveline, i guess it fit great, no more carrier bearing.:D I assume it's a one piece then. Interesting. Doesn't the drive shaft hit the cross member? Quote Link to comment
Pacific coast Datsun Posted October 16, 2008 Author Report Share Posted October 16, 2008 I cant go w/ a 1 piece shaft..my truck is so low it'll hit the bottom of the cab. Im wondering if a surplus store will have the rubber i need?? Quote Link to comment
datzenmike Posted October 16, 2008 Report Share Posted October 16, 2008 My last piece I got from a recycler. Quote Link to comment
tdaaj Posted October 16, 2008 Report Share Posted October 16, 2008 i've made my own drivbe line support rubber out of black windshield sealent. very strong and flexible. Quote Link to comment
Pacific coast Datsun Posted October 17, 2008 Author Report Share Posted October 17, 2008 Thanks Ted..i can grab any old gasket at the yard if i go that route. Quote Link to comment
Llittle_Llama Posted October 17, 2008 Report Share Posted October 17, 2008 I cant go w/ a 1 piece shaft..my truck is so low it'll hit the bottom of the cab. Im wondering if a surplus store will have the rubber i need?? cut your ds tunnel out and raise it..... Quote Link to comment
]2eDeYe Posted October 17, 2008 Report Share Posted October 17, 2008 What he said...^ And make some room for your exhaust while your in there, it likes to breathe :D Quote Link to comment
OL YELLER Posted October 17, 2008 Report Share Posted October 17, 2008 , i like my dickie's droopy.:lol: Your what is drooping? Quote Link to comment
Pacific coast Datsun Posted October 17, 2008 Author Report Share Posted October 17, 2008 Dwn- easier for me to repair the rubber surround + i dont have that 1 piece driveshaft anymore. Steve- if my exhaust was tucked up any higher it would be in the cab:lol: Ron- i was refering to my shorts...:rolleyes: Quote Link to comment
OL YELLER Posted October 17, 2008 Report Share Posted October 17, 2008 Dwn- easier for me to repair the rubber surround + i dont have that 1 piece driveshaft anymore.Steve- if my exhaust was tucked up any higher it would be in the cab:lol: Ron- i was refering to my shorts...:rolleyes: Of course you were...........................!;) Quote Link to comment
