Anderson521 Posted February 18, 2016 Report Share Posted February 18, 2016 So I bought the truck and it has no rear brake components, popped the drum off and it was empty, the reason I ask about interchangeability is my rear lugs do not have the same thread as my fronts. Could I possibly have a 620 or other diff? Or is that standard? 1 Quote Link to comment
Eagle_Adam Posted February 18, 2016 Report Share Posted February 18, 2016 Pic's will help immensely ;) 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 So this is passenger side with a 620 cylinder I got from pick n pull a while back 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Passenger side with cylinder that came with truck, cups were lying at the bottom of drum when I removed it. 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Whoops I mean drivers side 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Close up 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Second part of my dilema 1 Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 First is rear and second is front Front lug nut slips right over the rear threads 1 Quote Link to comment
Charlie69 Posted February 19, 2016 Report Share Posted February 19, 2016 Not sure of the thread size of the 620 but the 720 runs a larger diameter lug bolt. 521 7/16-20 thread 620 m12-1.25 thread 720 m12-1.25 thread Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 Anybody know if there's a stamp somewhere that would shed some light on it? Quote Link to comment
datzenmike Posted February 19, 2016 Report Share Posted February 19, 2016 So I bought the truck and it has no rear brake components, popped the drum off and it was empty, the reason I ask about interchangeability is my rear lugs do not have the same thread as my fronts. Could I possibly have a 620 or other diff? Or is that standard? The rear axle assy has been swapped. No way a truck would be made with different size lugs on it. Possibly all the wheel studs were removed and replaced with something else. Quote Link to comment
Anderson521 Posted February 19, 2016 Author Report Share Posted February 19, 2016 The rear axle assy has been swapped. No way a truck would be made with different size lugs on it. Possibly all the wheel studs were removed and replaced with something else.Or perhaps axles from a different truck that fit In the same housing? I'm told this vehicle has blown several gear sets so maybe the previous splines or the axles themselves were damaged and 620 axles were all that were available thus the smaller lug size?? Quote Link to comment
wayno Posted February 19, 2016 Report Share Posted February 19, 2016 OK, a lot depends on if you have changed the front brakes to disc brakes, if you have then that would likely be why the front lugnuts drop over the rear lugnut studs, early Datsun trucks had small studs, while the later stuff had larger studs/lugnuts. Now if you still have the 521 front drum brakes, then the front drum lugnuts dropping over the rear studs doesn't seem possible, as there were no smaller studs/lugnuts as far as I know on trucks, but the later 620 and 720 hubs did have larger studs/lugnuts, and they do not work on earlier axles. Quote Link to comment
datson4life Posted February 19, 2016 Report Share Posted February 19, 2016 Left my house with 521 wheels installed and new brakes all around. The dude said he just needed the truck for parts Quote Link to comment
