Rickie B Posted January 14, 2016 Report Share Posted January 14, 2016 You can use the stock air cleaner on your weber ,this is what i did,purchase the adapter,believe it is Redline part # ending in 301,this adapter fits on top of the weber,it has a 3 in. opening that fits the air cleaner perfectly.Now at this point the hood will NOT CLOSE,this is what i did.I cut aproximatly 3/8 off the Bottom of the adaptor. To lower the adaptor more, on the inside of the adaptor in the top 4 corners where the bolts come threw grind the corners till they clear the top of the carb,now the adaptor is sitting flat on the top of the carb.At this point the choke plate will not open,so mark with a marker where the choke plate hits and do some grinding on the adaptor.Now to to fill the gap and seal the adaptor to the top of carb i got a piece of 1/4 in neopreme sillicone rubber and made a perfect gasket by tracing the gasket that came with the kit and cut out the rubber one.Where the air cleaner mounts to the valve cover i needed a 1/2 in spacer under the brackets,can not get it down low enough to be perfect. It does still hit the hood but not by much,on the inside of my hood there is the 1/2 insulation pad so it does not come in contact with the bare hood,hood still closes very easy.Also No Wing Nut used a bolt with washers and rubber to seal the hole, use the clips to hold down the top.Hope this helps UPDATE,i removed the air cleaner ,flip it upside down ,there is a rubber seal with a 3/8 lip remove the seal and flip it around,now the lip is on top of the hole alowing air cleaner to come down even more, no need for spacers to bolt it to the valvcover,now the air cleaner barely brushes the insulation under the hood, hood closes very easy, Looks almost stock now :thumbup: 2 Quote Link to comment
datzenmike Posted January 14, 2016 Report Share Posted January 14, 2016 Now do it again with pictures and it can be a How To. 2 Quote Link to comment
Charlie69 Posted January 14, 2016 Report Share Posted January 14, 2016 Pictures and picture comments please. 1 Quote Link to comment
Rickie B Posted January 15, 2016 Author Report Share Posted January 15, 2016 Now do it again with pictures and it can be a How To. Ime new at this, dont know how to post pictures ,i dont think its as simple as up loading them from my computer,i registered at photo bucket but my antivirus said it was potentally harmfull so i left it alone,any sugestions? 1 Quote Link to comment
Rhino13 Posted January 15, 2016 Report Share Posted January 15, 2016 Well there is imgur, I'm not sure if it works on this form though. Most people use photobucket, most likely it thinks it's harmful because there's a lot of pop up ads. 1 Quote Link to comment
Charlie69 Posted January 16, 2016 Report Share Posted January 16, 2016 Get a better virus checker! I have been using Photo Bucket for years. 1 Quote Link to comment
Stoffregen Motorsports Posted January 16, 2016 Report Share Posted January 16, 2016 You just need to adjust your spam filter settings on Photobucket. I upgraded my virus software recently and it warned me about Photobucket too, but I have been using it for years. It's not the best out there, but it's free...until you run out of room, and then they got you. 1 Quote Link to comment
Lockleaf Posted January 16, 2016 Report Share Posted January 16, 2016 Then you sign up with a new email and start over 1 Quote Link to comment
Stoffregen Motorsports Posted January 16, 2016 Report Share Posted January 16, 2016 Once you fill up to the max allowable content, they block all your content until you pay them. If you don't pay up, all your old content is lost to the world. Quote Link to comment
Rickie B Posted January 16, 2016 Author Report Share Posted January 16, 2016 Thanks guys i appreciate all the sugestions,but why cant it be as simple as up loading them from your computer ? Quote Link to comment
Stoffregen Motorsports Posted January 16, 2016 Report Share Posted January 16, 2016 Because of the potential danger of allowing a virus onto the forum, most forums require a secondary hosting site like Photobucket. The worst thing about Photobucket is the time it takes to upload pics, then sort them and then when it comes time to load them onto the forum, that also takes way more time than it should. I wish Photobucket would listen to the complaints and change their format. 1 Quote Link to comment
Rickie B Posted January 17, 2016 Author Report Share Posted January 17, 2016 Thanks,appreciate the comments and sugestions.i have learned to use Flicker,so i will post some pics soon 1 Quote Link to comment
