81SVN20 Posted March 10, 2015 Report Share Posted March 10, 2015 Hey fellow ratsun buddies can someone help me out in the removal of the cluster I removed the screw but the damn thing does not want to come out and I'm afraid of cracking the bezel.... Im in the process of changing out my speedo cable, pics are welcomed and any help is awesome thanks in advance! 1 Quote Link to comment
Lockleaf Posted March 11, 2015 Report Share Posted March 11, 2015 At the bottom there are two metal sleeves that clip on to the plastic. I usually feel around in there with a flat head to find them and then slide the flat head between the metal clip and the bezel to separate them. 2 Quote Link to comment
wayno Posted March 11, 2015 Report Share Posted March 11, 2015 Hey fellow ratsun buddies can someone help me out in the removal of the cluster I removed the screw but the damn thing does not want to come out and I'm afraid of cracking the bezel.... Im in the process of changing out my speedo cable, pics are welcomed and any help is awesome thanks in advance! There are 2 screws holding the bezel in on the top, then you need to pry down a little to get the bezel past the lip that it is in, it should come right out, you need to pull on the bottom straight out to get it out of the lower clips. You have a column cover also, you will have to remove the top of it to get the actual instrument cluster out, 4 screws hold the cluster in position, 2 on the upper sides, and 2 obvious ones on the bottom, you will need to un-plug the instrument cluster plugs and the speedo cable, don't know which cable you have, one twists off, while the other has clips that hold it on that you have to depress and then pull straight out. 2 Quote Link to comment
81SVN20 Posted March 12, 2015 Author Report Share Posted March 12, 2015 At the bottom there are two metal sleeves that clip on to the plastic. I usually feel around in there with a flat head to find them and then slide the flat head between the metal clip and the bezel to separate them. There are 2 screws holding the bezel in on the top, then you need to pry down a little to get the bezel past the lip that it is in, it should come right out, you need to pull on the bottom straight out to get it out of the lower clips. You have a column cover also, you will have to remove the top of it to get the actual instrument cluster out, 4 screws hold the cluster in position, 2 on the upper sides, and 2 obvious ones on the bottom, you will need to un-plug the instrument cluster plugs and the speedo cable, don't know which cable you have, one twists off, while the other has clips that hold it on that you have to depress and then pull straight out. Thanks alot Lockleaf and wayno! Will tackle it this weekend.... Quote Link to comment
Charlie69 Posted March 12, 2015 Report Share Posted March 12, 2015 This sows the 2 top mounting holes. This shows the lower side mounting holes. This is to help you picture the placement of the 2 holes. 3 Quote Link to comment
petercscherer Posted March 12, 2015 Report Share Posted March 12, 2015 Here's the dash as mounted in the truck.Two screws on top, two on the lower sides, and the lower clips hold it in. ~Peter 3 Quote Link to comment
81SVN20 Posted March 12, 2015 Author Report Share Posted March 12, 2015 Thanks Charlie69! Quote Link to comment
81SVN20 Posted March 12, 2015 Author Report Share Posted March 12, 2015 Here's the dash as mounted in the truck.Two screws on top, two on the lower sides, and the lower clips hold it in. ~Peter Thanks Peter! This pic is very helpful, do you by chance have a pic of the bezel when you were removing it... that I would like to see as well. Quote Link to comment
petercscherer Posted March 12, 2015 Report Share Posted March 12, 2015 I really don't, I'm sorry. There are (I believe) 4 screws across the top that are screwed straight up into the dash. and then it clips into those lower clips on the bottom. It helps to have the column cover off when doing all this, but it's not necessary, I've removed mine twice now and I only removed my column-cover the first time. Also, if you have really small hands and are very dexterous, you can actually undo the speedo cable without needing to pull the dash out. It's rather cramped up in the dash, and getting underneath is tough, but it is doable. ~Peter 1 Quote Link to comment
Charlie69 Posted March 12, 2015 Report Share Posted March 12, 2015 If you have a tilt column drop it as low as it will go. If you have a regular column then pull the 2 bolts on the dash column clamp and push the column down if you need more room to pull the cluster assembly out. I disconnect the speedo cable and wiring after i pull the cluster out at an angle. there is a clamp that holds the speedo cable on the firewall under the hood that needs to be taken off to get enough slack in the speedo cable to do this. Quote Link to comment
81SVN20 Posted March 12, 2015 Author Report Share Posted March 12, 2015 Getting excited thanks guys! 1 Quote Link to comment
Rhino13 Posted March 13, 2015 Report Share Posted March 13, 2015 This sows the 2 top mounting holes. This shows the lower side mounting holes. This is to help you picture the placement of the 2 holes. So jealous you got that painted dash denmarkboy found. Do you have it in a truck yet? 1 Quote Link to comment
Charlie69 Posted March 13, 2015 Report Share Posted March 13, 2015 Not yet fortunately, I had to take some of the pictures I posted last night. I love the uniqueness of the denmarkboy cluster. My favorite part is the little stones glued to the to the face of the clock. 1 Quote Link to comment
Rhino13 Posted March 13, 2015 Report Share Posted March 13, 2015 Yeah it's done up really well too. I really like the tach, might even paint mine like that eventually. 1 Quote Link to comment
Charlie69 Posted March 14, 2015 Report Share Posted March 14, 2015 I am not positive but I think the colors are done with Sharpies not paint on the gauge faces. Paint is definitely used on the needles. I will be taking this cluster apart for a thorough cleaning and will look closer then. I will take more close up pictures at this time. 1 Quote Link to comment
