another aussie and his 620 we call kenny.......and another called doug
Eccles
  • Replies 356
so went out and test fitted everything after removing the engine mount on spare engine
turns out that theres another issue after bolting it up
14089392_1351773388184407_672761683_n_zp
this here is the issue and yet again no biggie,  I'm looking into either step washers
or ill shave the header mounting points
thinking the the shaving as then it will sit nice and flat
14059983_1352938804734532_945219637_o_zp
in the process i started cleaning up the header
14060525_1352940844734328_142223126_o_zp
14045377_1352940871400992_450724154_o-1_
14087562_1352931948068551_257944141_o_zp
  • Like 3
Ok so most mods made and we are test fitting to Doug this weekend
Will build engine mount and exhaust while its in Doug
Removed tray and pressure washed Doug
Rebuilt weber and now need manifold studs and to work out throttle
Will post up a more detailed post with pics tonite
We all love pics
hey guys so heres some pics of my progress
first step was shave the mounting points
from this 3mm step
to this flat mount
14101742_1355977297764016_55038355_n_zps
14139494_1355977901097289_7717438_o_zpsa
was a pretty easy mod to do,  used an angle grinder then finished it off with a file
14123366_1359917857369960_900652962_o_zp
14151717_1359917870703292_779664456_o_zp
heres what the carb looked like before i pulled it down and rebuilt and cleaned it
14111644_1358768220818257_773967426_n_zp
it now bolts up to my spare engine
14080012_1360410097320736_33945782015271
14192100_1360410127320733_45753454868374
14102575_1360410110654068_59915990523604
  • Like 3
heres how it sits on a flat surface
14124136_1355975877764158_446031290_o_zp
so now it bolts up its time to mount into doug so we can mod the engine mount and build an exhaust
so off the tray came
14194402_1360652287296517_1286860357_n_z
then i pulled out the pressure washer and cleaned the chassis so my daughter can paint it
14139245_1360707210624358_538308581_o_zp
gave the cab a pressure wash too and made sure everything is working fine for mock up
14151844_1360707257291020_1069967030_o_z
  • Like 3
new brake shoes turned up so these will go in sat before we start test fitting stuff to doug
14137841_1355948294433583_1751222294_n_z
i got a busy weekend this weekend so my greenhouse build is gonna be at a stand still for a few weeks,  i did cart all the timber home for it
14152218_1361622987199447_2115467288_o_z
and one of kenny hanging with higher society
14182113_1361350190560060_1949100218_n_z
ilil try update at the end of sat and may even make a video of the test fit and exhaust build
this is gonna fucking work so once in ill change diff ratio
  • Like 3
Take the throttle linkage off the stock carb and install it on the Weber use the stock throttle cable if it is long enough.  I always use the stock carb linkage on my Weber installs.
Be sure and put a lit return spring on the Weber so it will always return to idle.  Webers have a flat spot in them if you stomp the pedal to the floor if you accelerate evenly they pull real nice.
i have a few spare stock carbs so i like this idea
ill take a look at what i have loose and spare,  cheers for the advice
i have a new throttle cable in packet i plan to use
  • 2 months later...
Here's a little video talking about my conversion
Been playing with video a lot
This was first time starting with keys and throttle all hooked up
This has takin ages as our shoe season has started so I been crazy busy
New video of Kenny that I took after classic as he was all clean
Note
New tail gate lettering, note the holographic lettering from Japan it's an original item and was in packet, was called tail getors
240z. Steering wheel, this was from Travs first car
1200 tach I modded to fit into 620, used a 620 dome scott had in a spare dash
Repainted me tail light surrounds back to stock color
Blacked out behind the grill
Took out mech fuel pump and added block off plate to make more room for exhaust with conversion
Oh and I forgot
A month ago was melbournes datsun day
Kenny took out best 620 for second year in a row
Pretty happy
I'll try keep this updated as over my Christmas break new diff Centre and Weber conversion go in
Cheers
  • Like 4
