JK510 Posted May 3, 2022 Report Share Posted May 3, 2022 (edited) On 4/25/2022 at 11:26 PM, mrbigtanker said: Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Well the watermelon wagon engine bay version 2. I know I know it could of been cleaner, its the best I can do. I changed some things to be cleaner. MAP sensor in cab now Header was installed this time with steering box out as it won't go in with it in. It was scratched up pretty good. Routed both engine and valve cover vents to catch can Pulled all the coil brackets off and cleaned it up by mounting vertical and shorter wires. Of course went back to a little red under the hood All new wire harness Most all nuts and bolts that were not changed out now are Re did the brake lines again, not the best but way better. These items are to just to name a few. Do you know which type of bracket you ordered to fit that Chase Bays coolant overflow tank to your car? There seems to be five choices and I'm not sure which one is best...? Thanks again, JK PS Your car is just beautiful 😍 Edited May 3, 2022 by JK510 1 Quote Link to comment
Stoffregen Motorsports Posted May 3, 2022 Report Share Posted May 3, 2022 That car needs to be driven without the hood on. 1 1 Quote Link to comment
mrbigtanker Posted May 4, 2022 Author Report Share Posted May 4, 2022 9 hours ago, JK510 said: Do you know which type of bracket you ordered to fit that Chase Bays coolant overflow tank to your car? There seems to be five choices and I'm not sure which one is best...? Thanks again, JK PS Your car is just beautiful 😍 So what I did was is remove the bracket and bolted right to front core support. Much cleaner and nicer. 2 Quote Link to comment
mrbigtanker Posted May 4, 2022 Author Report Share Posted May 4, 2022 7 hours ago, Stoffregen Motorsports said: That car needs to be driven without the hood on. Noooooooo, I need to show off my useless hood vents.lol 2 Quote Link to comment
mrbigtanker Posted May 5, 2022 Author Report Share Posted May 5, 2022 Alright so tomorrow wiring should be all installed and I hope to first fire up the second new engine tomorrow. Stay Tuned. 3 Quote Link to comment
mrbigtanker Posted May 6, 2022 Author Report Share Posted May 6, 2022 Will finish it on Monday, looking real good though. 2 Quote Link to comment
Duncan Posted May 10, 2022 Report Share Posted May 10, 2022 Well......... It's Monday night... 1 Quote Link to comment
mrbigtanker Posted May 10, 2022 Author Report Share Posted May 10, 2022 Got it almost all done, late start, got wagon fired up, however timing is really bad so we will re group and remedy and dyne again. 3 Quote Link to comment
Stoffregen Motorsports Posted May 10, 2022 Report Share Posted May 10, 2022 Did the engine not get run on the dyno first? 1 Quote Link to comment
mrbigtanker Posted May 10, 2022 Author Report Share Posted May 10, 2022 1 hour ago, Stoffregen Motorsports said: Did the engine not get run on the dyno first? It was denied according to Robellos numbers 222 Hp but that was with carbs. Im doing all this complicate my life fuel injection stuff. I was thinking of upgrading the ECU but the Microsquirt is all I need for this engine. It is running but seems like timing is way off, its popping so pretty sure. Plus I would kick my fat ass for not marking the TDC on the crank pulley before installing. 1 Quote Link to comment
Stoffregen Motorsports Posted May 10, 2022 Report Share Posted May 10, 2022 Denied? Or dyno'd? I see. So not with all your parts. That changes things. 1 Quote Link to comment
mrbigtanker Posted May 11, 2022 Author Report Share Posted May 11, 2022 3 hours ago, Stoffregen Motorsports said: Denied? Or dyno'd? I see. So not with all your parts. That changes things. Yes the dyne was denied. lol I hope for more but will see. 2 Quote Link to comment
mrbigtanker Posted May 11, 2022 Author Report Share Posted May 11, 2022 Untitled by raymond medeiros, on Flickr Some wiring down below 4 Quote Link to comment
mrbigtanker Posted May 11, 2022 Author Report Share Posted May 11, 2022 Untitled by raymond medeiros, on Flickr Programming the ECU PDM. 4 Quote Link to comment
mrbigtanker Posted May 11, 2022 Author Report Share Posted May 11, 2022 Untitled by raymond medeiros, on Flickr I had them rechromed and they came out ok as pot metal is garbage, then to go with my wagon theme I went red.I had to, I think it will look really good on the hood. 4 Quote Link to comment
mrbigtanker Posted May 15, 2022 Author Report Share Posted May 15, 2022 Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr So did a mock up of the vents on the hood. I like the red, it will.go good with front spoiler and interior colors. 3 Quote Link to comment
mrbigtanker Posted May 15, 2022 Author Report Share Posted May 15, 2022 Untitled by raymond medeiros, on Flickr How the wagon sits waiting for final finish touches. I addressed everything that needed attention and then some, man what an understatement.lol 5 Quote Link to comment
mrbigtanker Posted May 15, 2022 Author Report Share Posted May 15, 2022 Untitled by raymond medeiros, on Flickr Scratch original hood, now I am doing a Mario TSR Carbon hood in possibly this green. I can't help myself, I do need to save weight because I drive it.lol 4 1 Quote Link to comment
Duncan Posted May 16, 2022 Report Share Posted May 16, 2022 (edited) '69 Camaro SS hodd vents on the CF hood? Could be a thang...👍 The wagon is looking great! Edited May 16, 2022 by Duncan 1 Quote Link to comment
mrbigtanker Posted May 16, 2022 Author Report Share Posted May 16, 2022 32 minutes ago, Duncan said: '69 Camaro SS hodd vents on the CF hood? Could be a thang...👍 The wagon is looking great! Fuck it whats a 2000.00 hood with holes.lol 1 1 Quote Link to comment
edekalil Posted May 19, 2022 Report Share Posted May 19, 2022 On 5/15/2022 at 3:26 PM, mrbigtanker said: Untitled by raymond medeiros, on Flickr Scratch original hood, now I am doing a Mario TSR Carbon hood in possibly this green. I can't help myself, I do need to save weight because I drive it.lol I'll take your old one but you got to autograph it 1 Quote Link to comment
mrbigtanker Posted May 20, 2022 Author Report Share Posted May 20, 2022 8 hours ago, edekalil said: I'll take your old one but you got to autograph it With love or hugs and kisses.lol 1 Quote Link to comment
mrbigtanker Posted May 20, 2022 Author Report Share Posted May 20, 2022 Dyno numbers are better but ITB's are way to small, pulling 10 Inches of vacuum, ordering bigger ITB's. Probably 44-50 mil 3 Quote Link to comment
mrbigtanker Posted May 27, 2022 Author Report Share Posted May 27, 2022 On 5/19/2022 at 6:25 PM, mrbigtanker said: Dyno numbers are better but ITB's are way to small, pulling 10 Inches of vacuum, ordering bigger ITB's. Probably 44-50 mil Well all they had was 50's so go big or go home. lol 3 Quote Link to comment
mrbigtanker Posted May 28, 2022 Author Report Share Posted May 28, 2022 Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr So I guess go big or go home.lol I needed bigger ITB's as just over 10 inches of vacuum at wide open throttle. Was just going to get 48's but none in stock for awhile, soooo what da fuck got a set of 50's. Wish me luck 3 Quote Link to comment
