Intake manifold identification
usaf_daddy
Picked this up recently, the manifold has no marking on it at all but looks to be in good shape and carbs are 44mm and are in decent shape as well. Just wanted to see if anyone has any knowledge of this.
  • Replies 8
Looks like a SSS manifold. I had one identical... can't recall the casting... I think K14. Looks like that one was ground and polished.
Looks to be L4 head flange with 4 bolt z carb flange... Not lynx based on shape and markings.
That's no sss manifold, they've got a diagonal 2 bolt pattern.
Yes it does look like the SSS intake, but it isn't. They had water cooling posts that matched the head ports ... and 2 bolt 38mm carbs.
Not a roaster 1500 g15 manifold for two SUs
Nope, but getting close...
May be a Roadster U20 manifold.
It is consistent with the 2 liter Roadster engine intake.
Also don't the Roadster SU throttles rotate opposite direction to the SSS 38mm SUs?
