therealdatsunnazi Posted December 15, 2014 Report Share Posted December 15, 2014 I have seen the beebani conversion, is there anything else out there ? I plan on z32 brakes upfront with the beebani brackets, what mc would bolt up to the early 620s ? 1 Quote Link to comment
Guest Rick-rat Posted December 15, 2014 Report Share Posted December 15, 2014 280 ZX MC, like it says in the Brake section of the forumWas that nice a nice enough answer?, Don't want to scare anyone away B) 2 Quote Link to comment
Charlie69 Posted December 15, 2014 Report Share Posted December 15, 2014 I believe Beebanis' is it at this time. Contact beebani he might have some options on the rear brakes. Quote Link to comment
therealdatsunnazi Posted December 15, 2014 Author Report Share Posted December 15, 2014 I didn't see a sticky or anything on it in the Brake section but I didnt go through a ton of pages either 1 Quote Link to comment
Charlie69 Posted December 15, 2014 Report Share Posted December 15, 2014 here are some search results. Unfortunately some of the image links do not work. http://community.ratsun.net/topic/20432-disc-brake-installed-on-a-drum-brake-truck/ http://community.ratsun.net/topic/18937-620-rear-disc-brake-conversion-photos/ http://community.ratsun.net/topic/25152-rear-disc-brackets-for-520521620/ There was another person I think making brackets out of aluminum. I have no information on him. The problem is as far as I know nobody did a write up for the E brake mod to go with the rear disk brake conversion. I am waiting for Mike Klotz to do a set. Mike Klotz also does front brake kits also along with many other items to better your Datsun. 1 Quote Link to comment
]2eDeYe Posted December 15, 2014 Report Share Posted December 15, 2014 I don't think any rears were ever done in aluminum, the aluminum front brackets are nice though. 1 Quote Link to comment
Z-train Posted December 15, 2014 Report Share Posted December 15, 2014 Why do you want to put disc on the rear? 1 Quote Link to comment
Guest Rick-rat Posted December 15, 2014 Report Share Posted December 15, 2014 You just have to be creative with the E-brake, I used some 1/8 cable and cable clamps and a couple, small turnbuckles (for adjusting) for mine. The cables I made hook up to the arm where the handbrake cable from the cab and cables to the rear are hooked up. I went for rear discs because they look very cool and drums on the rear are a bitch to adjust with lowering blocks, no adjustment needed and more time to drive instead of working on truck :rofl: 1 Quote Link to comment
Charlie69 Posted December 15, 2014 Report Share Posted December 15, 2014 Here are some vey pricey. http://www.ebay.com/itm/Datsun-310-520-521-620-Truck-Wilwood-New-Disc-Brake-Conversion-Set-REAR-Full-Kit-/400809649240?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d521de458&vxp=mtr Quote Link to comment
therealdatsunnazi Posted December 16, 2014 Author Report Share Posted December 16, 2014 here are some search results. Unfortunately some of the image links do not work. http://community.ratsun.net/topic/20432-disc-brake-installed-on-a-drum-brake-truck/ http://community.ratsun.net/topic/18937-620-rear-disc-brake-conversion-photos/ http://community.ratsun.net/topic/25152-rear-disc-brackets-for-520521620/ There was another person I think making brackets out of aluminum. I have no information on him. The problem is as far as I know nobody did a write up for the E brake mod to go with the rear disk brake conversion. I am waiting for Mike Klotz to do a set. Mike Klotz also does front brake kits also along with many other items to better your Datsun. i looked into mike and his bluehandsinc stuff but didnt see any rear info just a lot for the fronts, thanks for the links Why do you want to put disc on the rear?l more stopping power at higher speeds with less fade, the z32s might be enough top stop it but i dont want it to nose dive either, another thing is simplicity and off the shelf parts at any given time, the datsun stuff in this area is hard to find and down the road waiting will suck i have kicked around the idea of the 2000ish silverado rear end but im not sure i want to go about gettting shorter shafts for it, i could easily shorten the housing 2 Quote Link to comment
Guest Rick-rat Posted December 16, 2014 Report Share Posted December 16, 2014 Go to pinned brakes section, entry #8, click the link and there are some pics in that link that one guy did for his E-brake Quote Link to comment
datzenmike Posted December 16, 2014 Report Share Posted December 16, 2014 Are you racing the truck? Because fade is not a problem with the 620 10" rear drum brakes. The rears do very little braking compared to the stock fronts, and they will be molten hot metal before the rears fade. The only advantage to discs are ease of maintenance, (close to zero) adjustment (zero) replacement pads (cheap and very easy) Nose dive while braking is not caused by the brakes but by the suspension, shocks, springs and the ride height choice. It's caused by weight transfer to the front. Weight transfer when braking is unavoidable but it can be mitigated. Rear discs are not really needed but sure are sexy 1 Quote Link to comment
Charlie69 Posted December 16, 2014 Report Share Posted December 16, 2014 Mike Klotz has not designed a set of rears. That is why I am waiting. Rick-rat thank you for posting the e brake info. Quote Link to comment
therealdatsunnazi Posted December 16, 2014 Author Report Share Posted December 16, 2014 Go to pinned brakes section, entry #8, click the link and there are some pics in that link that one guy did for his E-brake will do, thanks Are you racing the truck? Because fade is not a problem with the 620 10" rear drum brakes. The rears do very little braking compared to the stock fronts, and they will be molten hot metal before the rears fade. The only advantage to discs are ease of maintenance, (close to zero) adjustment (zero) replacement pads (cheap and very easy) Nose dive while braking is not caused by the brakes but by the suspension, shocks, springs and the ride height choice. It's caused by weight transfer to the front. Weight transfer when braking is unavoidable but it can be mitigated. Rear discs are not really needed but sure are sexy im not for say racing the truck, but it will make good power and be a fun street machine(tail happy) , id like it to stop when need be, i hear what you are saying weight transfer etc etc, but if the back is good as the front then you have a better balance, im not against not using the drums, but things for these trucks are getting harder and harder to get, and the rears on my truck are shot, wheel cylinders, shoes, drums, so its not worth it to replace it all, when i could possibly do rear disc for a bit more cash, when i get more time i will post some about my self and my truck and other cars/projects therealdatsunnazi Mike Klotz has not designed a set of rears. That is why I am waiting. Rick-rat thank you for posting the e brake info. maybe he might go something going, im in no rush just looking whats out there 1 Quote Link to comment
Z-train Posted December 16, 2014 Report Share Posted December 16, 2014 Rear discs are not really needed but sure are sexy Yep.Un-less you frequent the Tejon pass(loaded to the max)or track the vehicle, disc will offer zero advantages. Drums are actually more efficient than disc(do to swept area) until they get really warm,hence ,my opening comment.Good drums,good shoes and take the adjusters apart,clean and lube them with anti-seize and you'll have no issues. 1 Quote Link to comment
Z-train Posted December 16, 2014 Report Share Posted December 16, 2014 will do, thanks im not for say racing the truck, but it will make good power and be a fun street machine(tail happy) , id like it to stop when need be, i hear what you are saying weight transfer etc etc, but if the back is good as the front then you have a better balance, im not against not using the drums, but things for these trucks are getting harder and harder to get, and the rears on my truck are shot, wheel cylinders, shoes, drums, so its not worth it to replace it all, when i could possibly do rear disc for a bit more cash, Where are you that you can't get parts? ANY rear 620 brake part is at my local parts house. Back as good as front? That doesn't make sense. The rear drum are engineered to work with the front. Including the NLSV. Changing the "bias" will require other changes to the system to ensure the balance is correct or they will not only be inferior to the drum set-up,but could be dangerous. 1 Quote Link to comment
therealdatsunnazi Posted December 16, 2014 Author Report Share Posted December 16, 2014 Where are you that you can't get parts? ANY rear 620 brake part is at my local parts house. Back as good as front? That doesn't make sense. The rear drum are engineered to work with the front. Including the NLSV. Changing the "bias" will require other changes to the system to ensure the balance is correct or they will not only be inferior to the drum set-up,but could be dangerous. its not that i cant get parts, but most are not in stock or special order, im out in northern utah, datsuns are scarce out here and parts too, what i mean by back as good as the front is the should do there equal parts, i dont want all the stopping power up front with the z32's fronts that i already have, i havent driven it with them on or even driven it at all with drums ,all i know is once they fade they are gone, im no n00b on how things works or how they should work, but i am new to these trucks and learning the weak points, i originally planned on just swapping to a ford 8.8 rear end but learned that these trucks diff are pretty strong so decided to stick with this, another thing why i asked about the mc, is i thought i read somewhere the earlier trucks the bracket between to mc and booster was weird or something needed to swapped with a later truck or something, 1 Quote Link to comment
datzenmike Posted December 16, 2014 Report Share Posted December 16, 2014 its not that i cant get parts, but most are not in stock or special order, im out in northern utah, datsuns are scarce out here and parts too, what i mean by back as good as the front is the should do there equal parts, i dont want all the stopping power up front with the z32's fronts that i already have, i havent driven it with them on or even driven it at all with drums ,all i know is once they fade they are gone, im no n00b on how things works or how they should work, but i am new to these trucks and learning the weak points, i originally planned on just swapping to a ford 8.8 rear end but learned that these trucks diff are pretty strong so decided to stick with this, another thing why i asked about the mc, is i thought i read somewhere the earlier trucks the bracket between to mc and booster was weird or something needed to swapped with a later truck or something, They are not going to fade, you won't be driving them that hard. The advantages of disc brakes are listed above. Having leaking and worn out drums could almost be another reason but easier to buy the parts and replace. Order them if you have to. Otherwise... For disc brakes you will need a larger master. Larger calipers need more volume to move them the same amount as smaller ones. Too small a master will have a larger travel on the pedal and will feel mushy. Will still work but, mushy feel. The 15/16" master from a '79-'81 280zx will fit and best of all it's already got the proper residual valves in it. The later ''82-'83 master has the horizontal mounting bolts to the booster and this won't fit. 1 Quote Link to comment
cr83 Posted December 16, 2014 Report Share Posted December 16, 2014 i looked into mike and his bluehandsinc stuff but didnt see any rear info just a lot for the fronts, thanks for the links more stopping power at higher speeds with less fade, the z32s might be enough top stop it but i dont want it to nose dive either, another thing is simplicity and off the shelf parts at any given time, the datsun stuff in this area is hard to find and down the road waiting will suck i have kicked around the idea of the 2000ish silverado rear end but im not sure i want to go about gettting shorter shafts for it, i could easily shorten the housing would be nice to use the narrowed chevy diff, then the wheel bolt pattern would be the same Quote Link to comment
cr83 Posted December 16, 2014 Report Share Posted December 16, 2014 http://www.ebay.ca/itm/Datsun-310-520-521-620-Truck-Rear-Disc-Brake-Conversion-Set-Full-Upgrade-Kit-/121493463885?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c4993234d&vxp=mtr Quote Link to comment
