Pops79Datsun620 Posted June 26, 2014 Report Share Posted June 26, 2014 Heys guys I recently got my 79 620 running and road ready, just going to replace all the front suspension. After that what are different things I can change on the motor to give it a little more power? Quote Link to comment
wayno Posted June 26, 2014 Report Share Posted June 26, 2014 Dual SUs give it more power than a down draft, but your in CA, so I guess you be screwed. Quote Link to comment
ggzilla Posted June 26, 2014 Report Share Posted June 26, 2014 The L20B is a strong little motor. Its plenty beefy right from the factory. To get more HP fit a Weber 38 and a long-duration cam. Then rev it up while driving. It will make significantly more HP at 7000 rpm than at 5600 rpm. The stock red line is 7000, but it makes peak HP at 5600. Headers and higher compression make only a very small difference. Going up to 10:1 compression will gain you about 5 HP. Quote Link to comment
hobospyder Posted June 26, 2014 Report Share Posted June 26, 2014 I would say do a swap but I guess that is out since cali Quote Link to comment
dr.feltersnatch Posted June 26, 2014 Report Share Posted June 26, 2014 strap a giant turbo on it. or nitrous, lots of nitrous. 1 Quote Link to comment
datzenmike Posted June 26, 2014 Report Share Posted June 26, 2014 Heys guys I recently got my 79 620 running and road ready, just going to replace all the front suspension. After that what are different things I can change on the motor to give it a little more power? Two things. For $50 get a 4.375 third member from any other year of 620 other than your '79 and swap it in. This will give you increased acceleration across every gear and has ZERO affect on your emissions. For a lot more get a new direst replacement 32/36 weber carb. It has everything needed, all the gaskets and adapter plate, air filter... everything needed. When emissions testing time comes around put your stock carb back on and call it good. (you did keep the old carb, right???) Quote Link to comment
ggzilla Posted June 26, 2014 Report Share Posted June 26, 2014 The 32/36 is also good for about 5 HP. Or you could jet the stock carb richer. Drill the jets out, its a lot cheaper than replacing the carb. Quote Link to comment
banzai510(hainz) Posted June 27, 2014 Report Share Posted June 27, 2014 Loose 10 pounds also Quote Link to comment
Radim Posted June 28, 2014 Report Share Posted June 28, 2014 Easiest way is to do what I did.Build a Big Bore stroker L20B and run a fat ass cam and Dual 44s.Done. Quote Link to comment
