My 720: Beginning to current
  • Replies 20
original motor had a bad rod bearing at number 3. cyl walls werent to good either. took it to a local machine shop where they turned the crank and rods 20/20 and bored it .40 over. The head was also cracked between the valve of #3 combustion chamber. Found a reman head and port matched it. Also ported the intake. it also has a Comp High Energy 260 Cam, pacesetter headers and a weber 32/36 carb. Still a lot to do, but a lot of fun to drive.
The Z24 made great torque.
Best bang for the buck performance is changing to a 4.11 or even a 4.375 differential and is easliy reversed later if you want. Nissan tended to go 3.545 or 3.70 to get mileage numbers. A lower ratio will improve acceleration at the expense of mileage.
Nice build so far. One thing though is why not clean the engine bay while you had the motor out. Would've looked A LOT cleaner imo.
But I don't think they make a posi for it. Your best bet is the 4.11 diff like Mike said. I bought one but haven't installed it yet.
I got it from a '71 Datsun 521 and not only is it better gearing, the housing for it is Aluminum.  :thumbup:
The 521s only had 4.375 rear gears.... unless it was changed before you got it. Look on the outer rim of the ring gear for the numbers stamped there. It should have 39:9 if 4.11 and 35:8 if 4.375
Jason would you like this all moved to the Project forum? Likely you will be adding to it.
Oh okay, this whole time I thought I had a 4.11. lol
So I have a 4.375 diff with an aluminum housing from a '71 Datsun 521.
Either way you should try and get one if your looking for torque. I haven't switched mine yet cause it's for race purposes only.
Check the numbers stamped on it and divide the small one into the large. 8 pinion teeth into 35 ring gear teeth is 4.375.
The early 720 2 and 4wd were 4.375 and later Z22 powered 4x4s were 4.375.
There was an H-190 LSD option for the '88-'93 D21 Hardbody but it had 3.889 ratio gears. You could easily change them out for 4.375s. Remember it was an option so there won't be many out there AND it was only available on the 4 cylinder 2wd trucks. wayno on here found one once.
I don't agree with you Mike, the 521s with the J13 came with 488s.
Sure mike.
  • 2 months later...
I would have spent a day in that engine well with rags and rubbing compound! That beautiful motor deserves a beautiful nest.
