Docsis510 Posted December 1, 2013 Report Share Posted December 1, 2013 I have a 510 with an l-18 motor.. the car had a 4speed transmission in it.. I swapped the tranny for a 5speed dogleg. I used the mount and crossmember from the 4speed tranny.. the dogleg seems to be pushed up against the tunnel and way forward having to cut some of the tunnel so the shifter eould move freely. .. my question is when installing a dogleg do people use a different mount and crossmember or do I have a tall short dogleg.. tranny says 63#1 and 63#2 Quote Link to comment
Ranman72 Posted December 1, 2013 Report Share Posted December 1, 2013 pics of the tranny would help us determin what you have Quote Link to comment
datzenmike Posted December 1, 2013 Report Share Posted December 1, 2013 Should be 26" long and I'm sure it is. If a long (very rare) dogleg the shifter would be about 5" to the rear. The stock 510 mount will be forward of the dogleg mount so yes the dogleg will be forced forward to fit. Not a good idea and this will also conflict with the motor placement. The dogleg shifter should fit the stock hole location. This is how much a 521 mount must be trimmed and welded to move the mount to the rear to fit a dogleg. This is NOT for a 510. Only to show roughly how much the difference in location is. The 521 uses basically the same 4 speed as the 510. Should say 63A on the pass side tail near the reverse light switch. #2 or #3 is just a casting revision. Quote Link to comment
hang_510 Posted December 2, 2013 Report Share Posted December 2, 2013 its been awhile, but IIRC you need to reverse the Xmember and space it from the body ~3/4" 1 Quote Link to comment
Docsis510 Posted December 3, 2013 Author Report Share Posted December 3, 2013 I messured the dogleg and it its 26" long.. the only difference is that the holes from the 4speed are 19 1/2 inched measuring from front of the tranny back... the holes from the dog leg are 21".. so theres a 1 1/2 inch difference on the tranny mount placement... even reversing the crossmber pulls everything forward... ill put the 3/4" spacer and see if that helps.. I might just redrill holes on the crossmember. .. Quote Link to comment
hobbes_the_cat Posted December 3, 2013 Report Share Posted December 3, 2013 I think the VG30.com crossmembers are slotted to work with doglegs. I think he still charges $75 for em. Quote Link to comment
Colbino Posted December 3, 2013 Report Share Posted December 3, 2013 I think the VG30.com crossmembers are slotted to work with doglegs. I think he still charges $75 for em. I have the same issue with my swap and just purchased the crossmember from techno toy tuning for $68. The vg ones are difficult to come by and T3 has them in stock. Quote Link to comment
banzai510(hainz) Posted December 3, 2013 Report Share Posted December 3, 2013 the vg30 x memeber which is worth the money, use the 280zx trans mount I believe then it should come out to the correct height. I heard of the GM trans mount working also Quote Link to comment
