j_boy_619 Posted November 28, 2013 Report Share Posted November 28, 2013 Im thinking of making/ buying something like this ( http://www.ebay.com/itm/Blow-Through-Carb-Hat-Throttle-Body-Turbo-Bonnet-Performance-Power-/400615738667?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d468f0d2b&vxp=mtr ) and then connecting it to some hose and this inline airfilter ( http://www.ebay.com/itm/Spectre-9833-Polished-Inline-Aluminum-Air-Box-/111059733984?_trksid=p2054897.l4275 ) then to the air intake hole on the front of the B210. Is this a stupid/ bad idea? Quote Link to comment
datzenmike Posted November 28, 2013 Report Share Posted November 28, 2013 Your stock air filter and housing is better and if you have smog checks that won't pass as you've messed with the emissions system. Quote Link to comment
metalmonkey47 Posted November 28, 2013 Report Share Posted November 28, 2013 Your stock air filter and housing is better and if you have smog checks that won't pass as you've messed with the emissions system. Mike, I think they'd figure out there's a turbo there haha Quote Link to comment
Stupid_fast Posted November 28, 2013 Report Share Posted November 28, 2013 It could result in some minor ram-air effects. Is it worth it? Probably not. If you wanna go fast get some real mods. Carb, cam, ect. @TheDmike, 75 and older is smog exempt in cali. Quote Link to comment
datzenmike Posted November 28, 2013 Report Share Posted November 28, 2013 Still has to have all the emission stuff on it. If you want fresh air run some dryer vent hose from the snorkel to the rad support or out one of the headlight high beams. That air filter thing is to the intake what a fart cannon is to the exhaust. Quote Link to comment
j_boy_619 Posted November 28, 2013 Author Report Share Posted November 28, 2013 That air filter thing is to the intake what a fart cannon is to the exhaust. Lol i like the simile. I only have 2 head lights, so i guess i'll have to look at this again Quote Link to comment
0r0B210 Posted November 28, 2013 Report Share Posted November 28, 2013 I think it is cool- you won't see many people with this little Mod. I think if you manu'd a whole assembly- throttle/carb hat with intake hose to fender opening designed for intake hose, it would be a cool little intake system. haters will hate. Quote Link to comment
Dawa Posted November 28, 2013 Report Share Posted November 28, 2013 i like it too. do it. Quote Link to comment
H5WAGON Posted November 28, 2013 Report Share Posted November 28, 2013 $80...for what? Will that top hat thing even work with the carb you have...? Mod stock air cleaner to hose like DatzenMike said...Or find something different. Inline AirBox is interesting B) Quote Link to comment
datzenmike Posted November 28, 2013 Report Share Posted November 28, 2013 Where will you find replacement air filter cartridges? The stock ones are down town. Also the stock air cleaner has the warmed air connection to the exhaust and an idle compensator valve in it. Quote Link to comment
j_boy_619 Posted November 28, 2013 Author Report Share Posted November 28, 2013 The top link was just to show, I would have to make one. If im corect the air filter is cleanable. Do webers have warmed air connection to the exhaust and an idle compensator valve in it? Quote Link to comment
CGS1948 Posted November 28, 2013 Report Share Posted November 28, 2013 Im thinking of making/ buying something like this ( http://www.ebay.com/itm/Blow-Through-Carb-Hat-Throttle-Body-Turbo-Bonnet-Performance-Power-/400615738667?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d468f0d2b&vxp=mtr ) and then connecting it to some hose and this inline airfilter ( http://www.ebay.com/itm/Spectre-9833-Polished-Inline-Aluminum-Air-Box-/111059733984?_trksid=p2054897.l4275 ) then to the air intake hole on the front of the B210. Is this a stupid/ bad idea? Keep it stock, and put the 89+ bucks in your gas tank. B) Quote Link to comment
datzenmike Posted November 29, 2013 Report Share Posted November 29, 2013 The top link was just to show, I would have to make one. If im corect the air filter is cleanable. Do webers have warmed air connection to the exhaust and an idle compensator valve in it? . No but easy enough to trim the bottom and drill 4 holes and mount the stock one. Keep it stock, and put the 89+ bucks in your gas tank. B) . Absolutely this. Spend the money on something that needed. 1 Quote Link to comment
ggzilla Posted November 29, 2013 Report Share Posted November 29, 2013 B210s came stock with a fresh air inlet. It is a bit on the small side compared to aftermarket ones, but plenty big for the stock 80 HP engine. So why not just find a stock inlet tube and connect it back where it belongs? 1 Quote Link to comment
