First car/Project/Datsun J15 521
jayochoa
  • Replies 41
If you have the original OEM starter, they are completely rebuildable, if you can get the parts.  A lot of parts are common to the British MG engine Nissan copied.
Sometimes if a starter is working poorly, all you need to do is to get to the contacts the solenoid makes, clean them and the starter works again.
Soooooo I took apart the solenoid
20131023_185553_zps0d697a99.jpg?t=138250
I couldnt get into the valves because the wires were soldered shut.
20131023_164009_zps857baf1d.jpg?t=138250
So I soldered that off
20131023_164558_zps7f236d70.jpg?t=138259
I also had to clean it up a bit because it was literally black.
20131023_183816_zps2fcd372c.jpg?t=138259
I soldered them back together after cleaning and lubing it.
20131023_190037_zps0920ce96.jpg?t=138250
We tested it out and it pops out and goes back in very easily! :]
Next thing to do is to put it back in and test it out!
I'll keep you guys updated !  :thumbup:
Nice job!  I admire your willingness to just dive in, and see what you can do.
The starter may still have some issues when you get it back in, but you have learned a lot!
:) haha thanks man.
If it still isn't working properly I might just take apart the motor of the starter and see what's going on there.
Alright well today I didn't get a chance to put the starter in (it's going in tomorrow).
Today me and TheRedWrench cleaned my wheels!!! We were tight on time so we only had time to clean two.
(I'm putting on new tires soon. Apparently they had white lettering so that was a nice surprise.)
FRONT BEFORE AND AFTER:
882b2a2c-b8bd-4bd0-bcdb-d6779aacd2ee_zps        20131025_222919_zps5027b152.jpg?t=138268
BACK BEFORE AND AFTER:
20131025_223049_zps29252496.jpg?t=138276         20131025_223030_zpsb24a4679.jpg?t=138276
I don't know about you but I LOVE my wheels! :wub:
[i know the different sizes of the picture are weird, but I'll take better ones once they're mounted...promise!]
Those are the old Enki cookie cutters they are nice wheels,you staying with that tire size.Keep up the good work save that 521.
Alright quick on-the-go-update/mini to-do list:
Starter is in.
Fix the heater leak.
Connect temporary temperature gauge .
Connect valve cover breather hose
Take out the dirty fuel.
Oh and this is what my truck sounds like at the moment:
Keep up the good work!
I have the J-13 in my 66 520. I had to use Nissan Fork-Lift J-15 parts to rebuild it, but also got the benefit of larger intake and exhaust valves. The J-15 was used in forklifts until 1984, and the J-16 an J-18 were used in South America till somewhere in the mid 90's! The difference between how yours sounds and mine, is at the time I rebuilt it, I was living in San Diego, and a budy worked for Crower racing. He R & R'd my pistons and rods, while his bother custom ground a performance cam and lifters for the J-13! It actually has a "lope" at idle!  If you ever need to replace the rocker shaft, the MGB 1800 rocker assy fits perfectly! Mine was bad, and no replacements to be found. I had always heard that Datsun copied MG for the E and J series motors. But when I found out that the Rocker assy was Identicle!!! WOW!!
Good Luck!
Garry
I actually have a full set of these type of rims in 14 inch, I think they are hard to clean around the rivets.  :crying:
You can drive the rivets out from the backside to the front. Had them on my '90 back in the day and thats what I did when I polished the wheels. Then just drove them back in. Never lost any driving it as they're splined.
