Budget 620 KC
  • Replies 51
No the truck's driveshaft is still in there, I just pushed it up over the tail of the transmission. I need to remove the small section of the driveshaft that looks like its being held on by 4 10mm bolts.
I remember those bolts being super tight and almost rounding one off. Can someone reassure me that it is those 4 bolts to remove it?
  • 2 months later...
Its been a while because I got punched in the face by life.
Lost my job, got bummed out for a while, but now I'm back!
I have the 240 radiator mounted with the 16 and 12 inch fans, found radiator hoses that would work, modified a 4 rib belt to do a single belt mod, and just sent out the drive shaft to be shortened.
I was going to get a one piece drive shaft, but to do that, I have to get a 3in shaft..... and that makes it a lot more moneys!
My carrier bearing has a small tear in it, but im thinking of filling it a bit with window weld to make sure it doesnt come apart later on.
I also bought D21 calipers to start piecing together the disc brake setup
Now all I need is the fuel pump (if someone wants to chime in and help that would be great)
figure out how what sensor I need to turn on the fans in 2 stages
and wire this baby up!
It was also really cool seeing a couple of Ratsun guys at mile square last week!
  • 5 weeks later...
  • 1 month later...
FINALLY another update!
you know how life is, always getting in the way of your hobbies.
Luckily I've had a lot of help from my new Ratsun family.
ON TO PICS!
the bed of the truck is full of parts, including the shortened driveshaft that needs to get placed in asap (note the brakes in there too)
I finally put on beebanis disc brake brackets, cleaned and painted the rotors/calipers with the help of my lady friend.
Radim gave me his old 3in blocks, and i got new U-bolts (still need to adjust the torsion bars up front)
I found a craigslist bargain for these Chevy wheels 15x9. will have 195/60/15 all around
AND i need to get rid of the rebuilt radiator (since its useless to me) it will be getting posted up sooner or later
also decided to get organized and started to make a to do list
  • 2 months later...
Ok so its been a bit.... but im damn close now!
The Chevy smooth wheels I had wouldnt clear the caliper.... crap.
Ended up getting 15x8 steelies from Summit, as well as MT-90 gear oil.
DONE LIST:
drive shaft
shifter install
fuel pump mounted/wired
bled clutch and brakes
adjust torsion bars
bought electric fan controller and radiator hose adapter
NEED TO DO:
finish the 90% of the wiring (i'm confused a bit about the lower harness that connects to the transmission and alt/starter)
find out what the hell is going on with the rear brakes, and temperately fix it till i have enough monies to buy new everything
FIND ANY L SERIES SPEEDO COG
finish installing factory tach.
make intake
mount battery in bed
install fan controller
put in coolant
re-weld center link thing...
get new rod ends
sea foam and change oil
install turn signals
other odds and ends
and yes, I have oics
I'm using the KA trans. The driveshaft company I used came down to my place and measured it up.
There were some complications due to a 'new guy' so they had to cut it twice and never got an accurate measurement.
Honestly, I don't like the way it sits right now. Its pulling the carrier bearing more than I would like.
  • 3 weeks later...
Awesome update!
I got her running!!!!
Well, not without the HUGE help from schicksal!
Still need to block off all the vacuum leaks that i caused by removing the egr
Also need to finish making the intake so i can see if it will idle on its own or not.
I really hate letting it run with open headers though.
Now on to oics!
First off, I installed air shocks so i have SOME rebound now.
I also finished reindexing the torsion bars and also added low profile bumpstops up front.
C notched rear will come in the future, till then, I cant hit the frame in the rear thanks to the new shocks :)
I also went to Homedepot and found a random can of spray paint that looked like it would match pretty well.... And its not too bad actually! Much better than the black at least.
IMG_20131203_153658_889-1_zpshleli8cw.jp
I was also able to pick up a L series speedo cog.... I really should have remembered what color it was.... crap (just realized this now)
I was scared of my expensive MT90 gear oil spilling out..... so i did this :)
At least it worked!
Grill with emblem will be put on soon enough, and I'm hoping Erich will help me weld new tabs onto the bumper (since the KA rad blocks the stock location)
I also was able to dig this up form my old phone.
This is the donor car the KA came from.
It's now LS powered..... Im thinking I might want to take the LS off his hands too lol
  • 2 months later...
This is more of an update for myself.
Today (just now) I finally got this KA running properly!
All it took me was 10 months and more money than I would like to ever add up!
Im so excited that I can start getting this thing ready for Canby and ready for me!
I got some BEAUTIFUL Mazda 3 heated leather seats ready to go in and I'm going to design the interior off of the seats!
I also just got a NEW full time job for a company making monster truck parts.
Im going to see if I can design and build my own roll cage (because drift truck)
All the dirty work is pretty much done! Now its all about maintenance and modifications to make this thing MY OWN!
Canby or bust!
Drove my KaKc 620 around the block for the first time in 11 months since I started the engine swap!
I didn't even get out of my driveway and someone already gave me the head nod of approval!
Then again it currently is running open header lol!
A huge thank you to the Ratsun community!
I'll post a link to my build thread in the comments. This thing has a long way to go!
More oics to come soon once the exhaust gets done!
  • 7 years later...
Welp.... its been about 7 years since i've update this....
I bet you all thought that this project was parted out and never finished...
(thats usually what happends)
But for the 7 of you that still exist, here is a little update......
I didnt upload to ratsun due to the photobucket lockedown years ago.
and I was more excited to have a working truck that i didnt think about uploading.
Soooooo, you may have seen my MAAD620.... you can find it on Youtube, or Amazon where its used as a display photo for ponretro's front lip.
or maybe youve seen it at Walmart, where JADA toys made a model of my truck (even put my name on it)
This thing has been running perfectly. I did go coilovers up front and got the KA rebuilt.
Im now an advanced tech for Mercedes, so I had enough  $$$ to buy custom built wheels from Love20bee.
My instagram is Fredwrench . i'll likely never post here again....... but it was cool to re read my own thread 🙂
Much love to all my OG Ratsun fam.
Edited by TheRedWrench
  • Like 8
