sick620 Posted March 10, 2013 Report Share Posted March 10, 2013 My 620 is having some issues with timing and it needs adjusted. It needs more advance, BUT both the adjuster on bottom of distributor and on top of distributor are all the way advanced, if i move it retarded AT ALL it doesn't run so Its right on the threshold of running now. Also even if I had more adjustment my dist is millimeters away from hitting motor where it wouldn't be able to advance at all.. At low RPM the CARB backfires HARD, at higher rpm the exhaust backfires slightly. What do I need to do to get more adjustment? I tried jumping the plug-wires one spot advanced then retarded the dist but then it wont even turn over!! . PLEASE HELP> Quote Link to comment
dat77sun Posted March 10, 2013 Report Share Posted March 10, 2013 sounds like your distributor is off a tooth Quote Link to comment
sick620 Posted March 10, 2013 Author Report Share Posted March 10, 2013 can i just pull out the dist and rotate it a 180 andvanced on the tooth and put it back in ? then retard at adjustment bolt? Quote Link to comment
kelowg Posted March 10, 2013 Report Share Posted March 10, 2013 or just move wires one spot over in direction of advance. #1 plug wire can b at any point on cap as long as firing order is right. Quote Link to comment
datzenmike Posted March 10, 2013 Report Share Posted March 10, 2013 I would pull the distributor out, it can be in any position, but TDC won't hurt. Have someone grip the spindle with pliers and hold it while you loosen and lower the oil pump. Once oil pulp is out of the way, reach up and support the spindle from underneath and with help lower slightly until it disengages the worm gear on the crank. Turn one tooth counter-clockwise as seen from underneath and push back up in place. Have your helper hold while you reinstall the oil pump and tighten the bolts. The spindle and the dizzy shaft will now be 9 degrees more advanced from where you were before. The dizzy body will be positioned the same but the rotor will be advanced. You should be able to get the range you need now. or just move wires one spot over in direction of advance. #1 plug wire can b at any point on cap as long as firing order is right. I tried jumping the plug-wires one spot advanced then retarded the dist but then it wont even turn over!! . PLEASE HELP> Quote Link to comment
sick620 Posted March 10, 2013 Author Report Share Posted March 10, 2013 ^is that my only option? I dont really have tools, ive never pulled an oil pump, and I dont have a helper. lol Quote Link to comment
sick620 Posted March 10, 2013 Author Report Share Posted March 10, 2013 Do I move plug wires one spot clockwise to advance them or one spot counter clockwise? maybe I went the wrong way? Quote Link to comment
datzenmike Posted March 10, 2013 Report Share Posted March 10, 2013 All you need is a 10mm and a 12mm spanner to do this. Advance is clockwise. But one in four positions, that adds 90 degrees... a lot. Quote Link to comment
sick620 Posted March 18, 2013 Author Report Share Posted March 18, 2013 Ok I pulled oil pump and tried this.... But when I tightened up oil pump the shaft wedged in there the wrong way. So I took it back apart and carefully tightened it back up, but the top of the shaft was sticking out too far on the distributor side of things. So I took it back apart and looked at shaft and the gear had moved down the shaft a little ways from wedging in there the wrong way. So I got a socket and hammered the gear where it was supposed to be, and reinstalled it to close to where I remembered it was positioned. Now it wont start, it just backfires out of the carb or the exhaust and never really starts. Im assuming its that Im SUPER advanced now...Is there anyway to just start fresh? Ugh im so frustrated right now! :frantics: Quote Link to comment
izzo Posted March 18, 2013 Report Share Posted March 18, 2013 Yes, you can start fresh. Set motor to TDC according to crank pulley and timing mark. You can also remove spark plug from #1 piston and throw a flat head screw driver in there to make sure its on the compression stroke. Then start from there.... To bad you're six hours away mang id shoot over and help out Quote Link to comment
racerx Posted March 19, 2013 Report Share Posted March 19, 2013 Watching Hainz video may help... Quote Link to comment
sick620 Posted April 5, 2013 Author Report Share Posted April 5, 2013 ok truck is at TDC.... What do I do next!?!? Where do I need to make my rotor point... remember Im as retarded as my distributor when it comes to this stuff... Quote Link to comment
racerx Posted April 5, 2013 Report Share Posted April 5, 2013 Is the shaft tang at 11.25 position. Quote Link to comment
sick620 Posted April 5, 2013 Author Report Share Posted April 5, 2013 english please? lol Quote Link to comment
datzenmike Posted April 6, 2013 Report Share Posted April 6, 2013 Set to TDC. Pull dizzy out look in hole. You must have the spindle in this position. Note that the left side half moon is smaller than the right. This assures that the dizzy will only go in in one position. When you get the spindle in this position and the oil pump and the dizzy bolted in, the plug wire dirctly above the rotor is NUMBER ONE go counter clockwise 3, 4, 2 you are so done! Quote Link to comment
sick620 Posted April 6, 2013 Author Report Share Posted April 6, 2013 alright guys shes running great :D Quote Link to comment
racerx Posted April 6, 2013 Report Share Posted April 6, 2013 Thanks mike...glad to hear that it works.. Quote Link to comment
sick620 Posted April 6, 2013 Author Report Share Posted April 6, 2013 shaft tang isnt at 11:45 ... I just got the rotor to point at a plug wire on the cap and made that my number 1 wire... Quote Link to comment
datzenmike Posted April 6, 2013 Report Share Posted April 6, 2013 This will work also. Only as long as you don't run out of adjustment range. Quote Link to comment
banzai510(hainz) Posted April 9, 2013 Report Share Posted April 9, 2013 put it to TDC asa your supposed to. so the Tang is 11.25 or the 11 28 as I mostly call it. Zero on the crank. take the dist out. rotate it 180 deg so youll get the full movent and wont hit the motor. turn the rotor till it locks down with both the timming adju top and bottom close to center you should be able to get the rotor on #1 plug wire(or put #1 plug wire there). if it points inbetween 1 and 3 this could be a mis matched matchbox set up meaning the pedastal is the incorrect one for the dizzy you have. to fix this you move the tooth on oil/dizzy spindle one tooth. in the disrection you need to go. But since your avatar say you have 76 620 I assume its points. and it the correct one. Maybe you install it off a tooth. photos would help at TDC and show us what you got or watch from part 1 to get a better understanding on how to line up motor Quote Link to comment
