Going with D21 brakes/drop spindles-Best place to get spindles?
southerncross
  • Replies 7
I don't think there is an easy swap to ball joints either. '78 and up LCAs are longer? and mounted to the frame differently. They won't fit onto pre '78 frames.
If you want front disc brakes get BEEBANI's conversion kit. You supply the rotor and caliper
There is an easy way to put disc brakes on kingpin 620s, mikes kit, it uses the easy to find 85/86 720 vented rotors and calipers, and you can use your 14 inch stock rims as far as I know, I am using 521 rims on a 1986 720 frame with no issues, and he also has a spacer just in case.
He has 6 kits left as of this post.
http://community.ratsun.net/topic/11459-disc-brake-kits-521520320620/
