Dat Lurka Posted February 5, 2013 Author Report Share Posted February 5, 2013 Yes definitely using anti sieze on the splines! Got a giant bottle for doing spark plugs. The lip of the bushing is chipped. Just slightly. Quote Link to comment
Laecaon Posted February 5, 2013 Report Share Posted February 5, 2013 I got my pilot bearing out with a sketchy way. I scored a line on the bearing with razor a few times. Then continued the score with a sharp flat screwdriver. I then took said sharp screwdriver, and drove it through the score line with a hammer. Split the bearing and it popped right out. Quote Link to comment
72240z Posted February 5, 2013 Report Share Posted February 5, 2013 The bushing costs like 5 bucks, it should be replaced with a new one if chipped. You dont need anything on the splines, its the tip that goes into the bearing. The splines engage the clutch, grease/anti-seize can migrate onto the clutch from there and mess shit up real good.They sell a puller for the bearing, or it can be rented for free at autozone/advanced.look at post 53http://community.ratsun.net/topic/11701-jays-72-s30/page-3 Quote Link to comment
Laecaon Posted February 5, 2013 Report Share Posted February 5, 2013 Im aware of pullers. I just like DIY. I didnt even leave a mark on my crank. Crank happened to be sitting on my bench at the time though. Quote Link to comment
DRIVEN Posted February 5, 2013 Report Share Posted February 5, 2013 Make sure you clean/sand the end of the input shaft and test fit the new bushing/bearing to it before you install it into the crankshaft. It shouldn't be a tight fit. You should never have to use bolts to pull the transmission up tight to the back of the engine. Clean up the dowels too. Quote Link to comment
72240z Posted February 5, 2013 Report Share Posted February 5, 2013 I wasn't ragging on you or anything the link was for lurkas reference. Since you mention it though...Diy is great, just diy with the right tool for the job. There is absolutely no logical reason to remove a bearing that way when there is a correct free tool for the job. A cool grass roots method to remove a pilot bearing if the tool cant be had is to pack the bearing with grease then with a punch or socket extension or w/e fits into the center loose, tap it center of the bearing and the hydraulic pressure pops it out. Ideally it shouldn't be that tight it's true. Test fitting the bearing prior to installation is great but the dimension of the bearing changes slightly after installation. Once it is pressed in its going to be a tighter fit. In the case mentioned I used a nissan bearing on a clean shaft and it was still that tight, couldnt tell you why. Like lurka just found out with these transmissions shit is rarely ideal... Quote Link to comment
I'm BLUE Posted February 5, 2013 Report Share Posted February 5, 2013 Grease will help it go in but anti-seize it what will help it come back out lol. Using too much of anything is bad since it can hydraulically prevent the input shaft from entering. Lol yup ! Is why I mentioned a slight amount earlier on. I remember putting WAY to much lube/grease in the pilot bushing area one time at least 11-12 years ago as well :lol: quickly realized what I did at 12:30am working in the near dark :lol: ! Why yes.. When the trans comes back out it slips out fairly easily hahaha :rofl: (keeps my stuff from corroding together and I honestly really don't like the idea of the input shaft splines rubbing the disc hub dry every time the clutch goes in n out .. Yet the lube probably doesn't stay on there long enough :lol: ! ) futile efforts lol I've never had a problem with the lube on the splines getting on other components. Probably lucky because a very light amount :) . To think of it..I probably picked it up as a habit from other Les Schwab employees :lol: :ninja: Driven I keep forgetting to clean up the input shaft tips ! Arch At this rate I'll never remember :-/. Quote Link to comment
Dat Lurka Posted February 5, 2013 Author Report Share Posted February 5, 2013 I just cleaned it all up with some WD and slid it in. Right now is time for eggdrop ramen and Adventure Time Quote Link to comment
datzenmike Posted February 5, 2013 Report Share Posted February 5, 2013 Skib 5 years ago... Skib in 10 years. Quote Link to comment
72240z Posted February 5, 2013 Report Share Posted February 5, 2013 :rofl: :rofl: :rofl: Quote Link to comment
Dat Lurka Posted February 5, 2013 Author Report Share Posted February 5, 2013 Shit, you figured it out! Quote Link to comment
Dat Lurka Posted February 6, 2013 Author Report Share Posted February 6, 2013 Here's a ton of pics. I'm gonna edit them to make a how to eventually. Not the rats nest vvv Rusty splines Good technique Don't do this if you give a shit. It made it a hell of a lot easier. Slid the tail up into the cab and then turned it to push the other end up past the torsion bars and that's the end of it. Quote Link to comment
