Llittle_Llama Posted July 1, 2008 Report Share Posted July 1, 2008 i broke the part below the housing and bolts to the head, are there new ones available or must i JY it? Quote Link to comment
Gensaiken Posted July 1, 2008 Report Share Posted July 1, 2008 i broke the part below the housing and bolts to the head, are there new ones available or must i JY it? Likely better of JYing it. How did you break it? Quote Link to comment
0.C. Posted July 1, 2008 Report Share Posted July 1, 2008 I needed one last weekend, no local autoparts had them, they only sell the piece that goes from the thermostat to the hose. I went to the junkyard, couldn't find another one from an l16, so I had to grab one from a 280z, welded the extra sensors holes,looks kinda crappy but it works and it was only 7 box. I've seen a few on ebay for sale. Quote Link to comment
Gensaiken Posted July 1, 2008 Report Share Posted July 1, 2008 I needed one last weekend, no local autoparts had them, they only sell the piece that goes from the thermostat to the hose.I went to the junkyard, couldn't find another one from an l16, so I had to grab one from a 280z, welded the extra sensors holes,looks kinda crappy but it works and it was only 7 box. I've seen a few on ebay for sale. i've found out that some of those extra holes (if threaded) can be pluged up using simple fittings from a hardware store. Kind of nice to plug those stupid bypass holes. ;) Quote Link to comment
Llittle_Llama Posted July 1, 2008 Author Report Share Posted July 1, 2008 i replaced the thermostat and when torquing the housing down...POP! DAMMIT!!! Quote Link to comment
banzai510(hainz) Posted July 1, 2008 Report Share Posted July 1, 2008 these are the L16 housings from the 510/521 series Housine with NO BYPASS hole uses a strat water line 11061-21000 Housing w/bypass hole (needs a U shaped hose to go from water line to lower part of the housing 11061-P0300 T Neck 11060-21000 the temp sender 16mm nut 25251-37700 buy a spare of this cause most old ones youll never get out and break the housing again Quote Link to comment
Llittle_Llama Posted July 1, 2008 Author Report Share Posted July 1, 2008 i have an aftermarket gauge i am running and so i bought a plug for the other hole. can i run either of those or just one? what do you recommend? Quote Link to comment
datzenmike Posted July 1, 2008 Report Share Posted July 1, 2008 If there are two holes, use one, pipe plug the other. If the spare hole already has a sender in it, leave alone. You don't want to break another housing just to take a sender out to put a plug in. Use Teflon plumber's tape on the threads. Wrap in the opposite direction to tightening. Quote Link to comment
banzai510(hainz) Posted July 1, 2008 Report Share Posted July 1, 2008 Those #s I gave I dont know if they work. look like you have a W58 head so I assume you have the later housing with the big hole and maybe fits the aftermarket gauge better. Quote Link to comment
Bleach Posted July 1, 2008 Report Share Posted July 1, 2008 You're lucky you didn't strip out the threads in the head. You're bolting into aluminum. Go easy! Quote Link to comment
Llittle_Llama Posted July 1, 2008 Author Report Share Posted July 1, 2008 this thread needs pics....will be up in a few..... Quote Link to comment
datzenmike Posted July 1, 2008 Report Share Posted July 1, 2008 this thread needs pics....will be up in a few..... Does that mean a ... new thread? :lol: Quote Link to comment
Gensaiken Posted July 1, 2008 Report Share Posted July 1, 2008 this thread needs pics....will be up in a few..... lol, thats a first. OP ttiwwop'ed his own thread? :lol: Quote Link to comment
Guest DatsuNoob Posted July 1, 2008 Report Share Posted July 1, 2008 I've got a thermostat housing pretty much ready to ship, what are you willing to spend? Quote Link to comment
Llittle_Llama Posted July 2, 2008 Author Report Share Posted July 2, 2008 the lower half? 25 shipped? Quote Link to comment
Guest DatsuNoob Posted July 3, 2008 Report Share Posted July 3, 2008 Done and done. PM me with your shipping info and all that, and we can arrange payment through Paypal. Quote Link to comment
Jester Posted July 3, 2008 Report Share Posted July 3, 2008 Sounds like you need torque specs for the install of your new parts. :D Quote Link to comment
Llittle_Llama Posted July 3, 2008 Author Report Share Posted July 3, 2008 sure do, lol....paypal is on its way :) Quote Link to comment
Bleach Posted July 3, 2008 Report Share Posted July 3, 2008 the torque specs are just tight enough it won't leak but not tight enough to strip threads or break bolts. :) Quote Link to comment
datzenmike Posted July 3, 2008 Report Share Posted July 3, 2008 Yeah, clean the bolt and block threads then maybe some anti-seize compound on them. (for the next guy) Quote Link to comment
