bloobe Posted January 20, 2013 Report Posted January 20, 2013 I am getting a grinding sound when I trying start my 510. It's like when your car is already started and you try and start it. The engine doesn't engage or anything. Just a lovely grinding noise. Suggestions appreciated :) Quote
BJW's FiveTen's Posted January 20, 2013 Report Posted January 20, 2013 Your starter come loose? If not Try putting it in 3rd gear and rolling it a foot or two forward to turn.the engine some. Then try starting it again. Could have a section of your ring gear missing some teeth. If after rolling it in gear to a good spot on the flywheel ring gear it starts well then your looking at putting a flywheels in it. Quote
bloobe Posted January 20, 2013 Author Report Posted January 20, 2013 Oh boy, the little guy is hanging on by a thread. Thanks Bryce! Quote
BJW's FiveTen's Posted January 20, 2013 Report Posted January 20, 2013 No problem my friend. Happy to help keep another Datsun rolling. Quote
bloobe Posted January 20, 2013 Author Report Posted January 20, 2013 Well now I see why things came loose. Both engine threads were stripped. Quote
BJW's FiveTen's Posted January 20, 2013 Report Posted January 20, 2013 Once loose they just beat up the threads. Quote
bloobe Posted January 20, 2013 Author Report Posted January 20, 2013 Sorry to keep bugging you--I'm not sure how to proceed in this situation. Am I looking at re-threading the holes, or should I consider something like loctite, or is there another option? I am still learning :) Quote
kelowg Posted January 20, 2013 Report Posted January 20, 2013 helicoils inserts and locktite. autozone carriers different size kits, just take your time tapping new larger threads. install insert with locktite when NEW starter bolts. Quote
bloobe Posted January 20, 2013 Author Report Posted January 20, 2013 Oh man, thanks Kelowg. You are a lifesaver. Quote
datzenmike Posted January 20, 2013 Report Posted January 20, 2013 The starter threads into the aluminum transmission. Quote
BJW's FiveTen's Posted January 20, 2013 Report Posted January 20, 2013 If you need a hand let me know. I could come by after work tomorrow. Any one know off hand what size I have heilicoil kits at work. Thanks bryce 206-915-9311 Quote
bloobe Posted January 21, 2013 Author Report Posted January 21, 2013 Bryce, that'd be amazing! I picked up new bolts that are the same fitting, 10M-1.25 The length seems different between the two maybe 25mm & 35mm, but I don't know if that makes a difference. Quote
bloobe Posted January 21, 2013 Author Report Posted January 21, 2013 Mmmm, you are correct. I had said engine. Thanks. Quote
BJW's FiveTen's Posted January 22, 2013 Report Posted January 22, 2013 Someone had used a 3/8 bolt for one of the holes and the other was gone. I put in one insert and cleaned up the threads in the other hole and used a new longer bolt. Should get him down the road for a while. Quote
bloobe Posted January 23, 2013 Author Report Posted January 23, 2013 Thanks Bryce for your help and for stopping by. Quote
banzai510(hainz) Posted January 23, 2013 Report Posted January 23, 2013 L16s the hole is straight thru and you could use a nut. could just drill it out if in a pinch 5 speeds or later Datsun had threaded holes on the trans and the right size bolts. You got it fixed now so dont matter Quote
