A10's U-nite !!!!
Since nobody can answer me anywhere else..... I'll ask here, seeing that your fairly active in the a10 forum Mike...
Finishing the wiring in the KA in my A10 and having a bit of confusion on wiring starter and alternator. I would assume I would wire up the alternator as you would in any other application, but it's the starter that's getting me.
From my understanding I wire the orange wire from ecu pin 24 to the starter solenoid.
Correct? This doesn't really make sense to me? I'm a bit confused why this would be...? Doesn't the orange wire go to the IGN S/W on an S13?
I also see that I take the Blk/W wire (old ignition coil wire, from fuse box) and wire that into one of the relays on can/am.
Correct.
Just to clarify..... I realize that all I need to do is wire from IGN S/W ST to the starter, sure. But I am unsure where and why I connect the orange from ecu pin 24?
Yes. I have studied the wiring diagram on "can/am box thread" ... How to wire KA sr ca into anything.
This is actually embarrassing considering that I'm a tech haha! But I've never done an engine swap, except on S13's ...
Can some take a good pic of there starter and alternator (so I can see wires / plugs) on their L20?
Thanks
  • Replies 4.1k
I did a hardcore bondo session this weekend.
Before:http://imgur.com/HIhaW1U
Bent/Wire wheel:http://imgur.com/er3YQro
Bondo 1:http://imgur.com/Xq0p85o
Bondo 2:http://imgur.com/81mSxw4
Bondo 3:http://imgur.com/dAMHx6H
Bondo 4:http://imgur.com/yGCUtzl
This was my first time doing body work. It was a ton of work but its going to be sexy when finished.
Too bad that is not a Scirroco.
G60. Almost.
I'd rather G60 than a Scirroco. Any day.
But I'd still prefer my Nikes over a VW.
Ick.
..... the red one is a carado or however its spelt. the yellow is a 20th gti, fun mutha fucka. the other one in the garage is this:
but he totaled it :(
Corrado was escaping me.
G60 being the supercharged Corrado or the VR6.
Either way, I'll keep the Dunks.
Way more reliable.
cool story, now what about your A10?
What A10?
I'm looking on to smaller and better things.
your machanical skills were were not strong with that one...hope its 521 because you already showed the world you couldnt fix one of those.
at least there would be one less B210 in the world when you get done with it
Tsk, tsk.
Proved I couldn't fix a 521?
Incorrect.
B210?
Still shooting blanks.
Learn to spell. My MECHANICAL skills have never been in question.
The A10 always was/is a parts donor. The game plan had always been to do what is about to happen.
But now, the plans date has moved up a bit quicker than anticipated.
Where would you be if it wasn't for your Dad?
