ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 1 minute ago, datzenmike said: The plastic part (called a collar) helps align the the spindle and the distributor shaft. The part number is 22119-W0400 for most L20Bs earlier ones were metal, might fit.... on the chance Nissan still has them. Try... https://ratsun.net/classifieds/category/9-datsun-parts/ Thank you so much Datzenmike, I tried installing the original L16 dual points Dizzy collar on it, but the collar pin goes in offset on the L16 and wont aling with the matchbox. Erick Quote Link to comment
datzenmike Posted November 28, 2022 Report Share Posted November 28, 2022 Yup. Most L20Bs have that number, the early one has a different number and I guess it's also totally different. Try making something. It's just a collar to help align the spindle. Some checking says it was on everything but the L16/18 including L six cylinders z/zx and Maxima cars plus all the Z series Z20/22/24 engines in cars and trucks. It's a roll pin that holds it in place. Quote Link to comment
banzai510(hainz) Posted November 28, 2022 Report Share Posted November 28, 2022 photos of what your taling about? Quote Link to comment
ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 1 hour ago, banzai510(hainz) said: photos of what your taling about? Its the bottom collar and pin Hainz Quote Link to comment
banzai510(hainz) Posted November 28, 2022 Report Share Posted November 28, 2022 (edited) I cant open the foto but why you need that collar off? on lower part of dist? Im not confusing this with a pedastal right? Edited November 28, 2022 by banzai510(hainz) Quote Link to comment
ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 Ill try and post it again. Well my original question was to know if I really need it, since it broke off the matchbox which im trying to install on my 510. Quote Link to comment
ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 17 minutes ago, banzai510(hainz) said: I cant open the foto but why you need that collar off? on lower part of dist? Im not confusing this with a pedastal right? Yes, it is different from the pedestal Quote Link to comment
banzai510(hainz) Posted November 28, 2022 Report Share Posted November 28, 2022 all L series dist will fit the front cover if one has the matching pedastal. this will make it line up to #1 plug wire correctly but can be cheated if you move the oil spindal in the disrection you need to go so it lines up to Number 1. some people put the pedastal in 180 then say car dont work its off 180 put just move the plug wires 4 to 1 and then start 1 3 4 2 CCW fire order. you m ight know this already Im just not getting the pin thing Quote Link to comment
Crashtd420 Posted November 28, 2022 Report Share Posted November 28, 2022 1 hour ago, banzai510(hainz) said: I cant open the foto but why you need that collar off? on lower part of dist? Im not confusing this with a pedastal right? Quote Link to comment
datzenmike Posted November 28, 2022 Report Share Posted November 28, 2022 This one. Plastic collar with metal clip around bottom. Came on most L20B and up engines including points, and also Z series distributors. Earlier are metal. Quote Link to comment
banzai510(hainz) Posted November 28, 2022 Report Share Posted November 28, 2022 (edited) Im 90% sure all my L20 ones are metal Edited November 28, 2022 by banzai510(hainz) Quote Link to comment
datzenmike Posted November 28, 2022 Report Share Posted November 28, 2022 22119-H2700 is the earliest use part number for 521/510/610 Then changed to this number.... 22119-W0400* is the '79 620 Matchbox plastic collar set includes the roll pin. Shows that part* used on all z and zx cars, 810 and Maxima. All L16/18 20B 620s, all L18/20B 710s, All A10 L20B and Z20, All S10 and S110, all 720 gas engines L20B, Z20/22/24. 16 hours ago, ddrum said: Thank you so much Datzenmike, I tried installing the original L16 dual points Dizzy collar on it, but the collar pin goes in offset on the L16 and wont aling with the matchbox. Erick The hole in the distributor shaft is not centered?? Got pictures? Quote Link to comment
banzai510(hainz) Posted November 28, 2022 Report Share Posted November 28, 2022 bottom of my dist look like this all of them and spares I have Quote Link to comment
ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 2 hours ago, datzenmike said: 22119-H2700 is the earliest use part number for 521/510/610 Then changed to this number.... 22119-W0400* is the '79 620 Matchbox plastic collar set includes the roll pin. Shows that part* used on all z and zx cars, 810 and Maxima. All L16/18 20B 620s, all L18/20B 710s, All A10 L20B and Z20, All S10 and S110, all 720 gas engines L20B, Z20/22/24. The hole in the distributor shaft is not centered?? Got pictures? It's not centered, only by a bit but enough so the pin wont go all the way through, but on the points, its perfectly centered. Its really bizarre! I don't have any pictures right now, ill try taking some tomorrow morning, but I tried installing the collar onto the matchbox and it fit, but the hole never lines up no matter how its put in (that's what she said). Quote Link to comment
datzenmike Posted November 28, 2022 Report Share Posted November 28, 2022 So you want the metal collar on the matchbox. Can you drill a second hole that matches the off set? Quote Link to comment
ddrum Posted November 28, 2022 Report Share Posted November 28, 2022 34 minutes ago, datzenmike said: So you want the metal collar on the matchbox. Can you drill a second hole that matches the off set? Hmm that might just work, ill give that a try! Quote Link to comment
datzenmike Posted November 29, 2022 Report Share Posted November 29, 2022 Line up one hole on the collar with the hole in the shaft and run a drill through to make a hole on the other side? Quote Link to comment
ddrum Posted November 29, 2022 Report Share Posted November 29, 2022 1 hour ago, datzenmike said: Line up one hole on the collar with the hole in the shaft and run a drill through to make a hole on the other side? Yes, that is exactly what needs to be done in order to make the pin go through Quote Link to comment
ddrum Posted December 2, 2022 Report Share Posted December 2, 2022 (edited) So I followed Datzenmikes advice and it seems to work! Time will tell. Here is a picture of what I was talking about being off center. In the following picture you can see i elongated the hole to correct for the offset of the distributor collar for the pin to go through the matchbox distributor Edited December 2, 2022 by ddrum 1 Quote Link to comment
