Eagle_Adam Posted December 12, 2012 Report Share Posted December 12, 2012 Currently my 620 is dead in the water due to what i believe is a bad fusible link and or battery cable - im not looking for help diagnosing the problem im looking for advice, tips, tricks, and do's and dont's of selecting parts and assembling the positive and negative wires. My plan is to get the ends that require you to solder in the wire not clamp it down, but i know little compared to what i should.... Soooooooooooo, someone school me! Quote Link to comment
banzai510(hainz) Posted December 12, 2012 Report Share Posted December 12, 2012 I buy the Cables from schucks/Oriley with the molded ends on there already(made in USA and get the shortest size that will fit also) if you dont get 12volts to the fuse box it has to be the link. Otherwise if a bad batt cable you should still get 12volt with a tiny volt meter as its only a miliamp load to get the meter to work. Its big Power draws that make the cable or the ends/corrossion (look Bad) Quote Link to comment
Eagle_Adam Posted December 12, 2012 Author Report Share Posted December 12, 2012 currently my neg batter cable is smoking and the truck will crank fore a min or so b4 is starts...... Quote Link to comment
datsunaholic Posted December 12, 2012 Report Share Posted December 12, 2012 Smoking cables means a bad connection OR too small a wire. Quote Link to comment
Eagle_Adam Posted December 12, 2012 Author Report Share Posted December 12, 2012 honnestly, IDK. Im replacing the wires, ends and links cus i can and it hasnt been done and ive wanted to for a while. Quote Link to comment
banzai510(hainz) Posted December 12, 2012 Report Share Posted December 12, 2012 I would ck the ground. If got lots of money get new cables anyways. Re ck the timming, valave lash ,intake/ carb/intake tighteness, choke ect. Your truck should not take a minute to start unless very worn out ck unnder dizzy cap. Loosness in dizzy. If points ignition ck all wires being crimpped on good. on my 521 daily driver I pull the choke and pump the carb before I start. takes about 2 trys on a very cold day. If not driven in a awhile its alot longer to get started but not a minute.(most its no gas in the carb) Quote Link to comment
yello620 Posted December 12, 2012 Report Share Posted December 12, 2012 Eagle, you are on the right track by looking for the soldered/molded style cables. I always use the largest cables i can get. My current cables in my Datsun are close to twice the size of the cables that are on the shelf at Oriellys and everywhere else i looked for them. Those bolt on cable ends that are readliy available at every auto parts store are crap. Quote Link to comment
DanielC Posted December 12, 2012 Report Share Posted December 12, 2012 I used these parts to make a positive battery cable for my 521. Not shown, large heat shrink tubing. here is the battery end. The starter end. and the wire that goes to the fusebox. I put the terminal ends, in a vice, and heated the outside with a propane torch. Then I filled the cup about half way with molten solder, and preheated the ends of the cable, while keeping the molten solder in the terminal hot. I then shoved the end of the cable, and fusebox wire into the molten solder in the cup. hold it still until the solder cools. Then slide the heat shrink over the ends. Quote Link to comment
metalmonkey47 Posted December 12, 2012 Report Share Posted December 12, 2012 I just buy the pre-molded from Autozone. Running 2 gauge + and -. Trucks never had a problem starting. Quote Link to comment
72240z Posted December 12, 2012 Report Share Posted December 12, 2012 I use maxima diesel batter cables cut down in length. At 00 (maybe even 000) they are one of the thickest stock car battery cables I have ever come across lol. My torch was out of gas at the time I reused the crimp connector and soldered it up on my stove. Ridiculous overkill but I'll never have an issue...With the bat reversed so the pos side isnt under the fender support I run a quick disconnect on the ground. MUCH safer. A nice bonus to maxima cables is they come with 2 female blade connectors already soldered in with the main and rubber molded caps. Very useful neat and safe. Quote Link to comment
banzai510(hainz) Posted December 13, 2012 Report Share Posted December 13, 2012 The ones I get from O rileys. The USA made ones(1 option) there is a wire comming from the +side post with a inline splice just like its made for a 521 to power the fuse box. Quote Link to comment
