73DATSON Posted December 10, 2012 Report Share Posted December 10, 2012 I just order a NEW CAM FROM ISKY 490-290-280. I wanted a Aggressive Cam and this is what they gave me for street mod. So what you guys think?? XMAS is going to be GOOD:-))) for the LOL RATSON. Quote Link to comment
datzenmike Posted December 10, 2012 Report Share Posted December 10, 2012 Think? I think you're so excited you forgot the picture? Quote Link to comment
73DATSON Posted December 10, 2012 Author Report Share Posted December 10, 2012 I'm super excited:-))) I just order it not in yet... Quote Link to comment
datzenmike Posted December 10, 2012 Report Share Posted December 10, 2012 Premature expectation? Quote Link to comment
73DATSON Posted December 10, 2012 Author Report Share Posted December 10, 2012 LOLOLOL I feel like I'm 9 at TOYS R US:-))) is that cam going to changed the sound of the motor??? Quote Link to comment
datsunaholic Posted December 10, 2012 Report Share Posted December 10, 2012 Yes, especially if you don't get the special lash pads needed to use it. 3 Quote Link to comment
Dawa Posted December 10, 2012 Report Share Posted December 10, 2012 'street street cam' cool man, i saw recommendations for isky cams on ozdat but havent read about anyone's personal experience. Quote Link to comment
73DATSON Posted December 10, 2012 Author Report Share Posted December 10, 2012 Yes the people from ISKY sold me a complete kit to go with that bad azz cam....they just said that I need to get lifters followers?? Don't know what that is? Quote Link to comment
73DATSON Posted December 10, 2012 Author Report Share Posted December 10, 2012 'street street cam' cool man, i saw recommendations for isky cams on ozdat but havent read about anyone's personal experience. Yes me too, read so much about the company. As soon as I get it in ill post pictures:-))) Quote Link to comment
EricJB Posted December 11, 2012 Report Share Posted December 11, 2012 Did they sell it to you outright, or with a core charge? I thought anymore, you had to ship them a core, and they ground it and shipped it back. Quote Link to comment
73DATSON Posted December 11, 2012 Author Report Share Posted December 11, 2012 sold out right no core. Quote Link to comment
banzai510(hainz) Posted December 11, 2012 Report Share Posted December 11, 2012 I think this cam is a little long in the duration but one can put the sprocket on #3 setting and maybe lower the gear ration on the diff to get the cam alive sooner. They mean NEW rocker arms. Rockauto.com had them for 7$ apc recently but must have sold out. most are about 26$ apc make sure made in Japan. sealed Power used to sell USA made ones and they are BAD!!!!!!!!!! Quote Link to comment
73DATSON Posted December 11, 2012 Author Report Share Posted December 11, 2012 wow sick i love it and i can't wait :thumbup: Quote Link to comment
datzenmike Posted December 11, 2012 Report Share Posted December 11, 2012 Just use your old rockers. (followers) Sheet of glass, wet sandpaper 600 grit maybe higher, kitchen sink. Back and forth rolling/rocking motion to put a pollish on them. Did they sell you new springs too? .470"- .480" lift is close to spring bind on the stock ones. Quote Link to comment
73DATSON Posted December 11, 2012 Author Report Share Posted December 11, 2012 yes when i get it i'm going to need some help :poke: i do have a adjustable cam gear installed already. just don't know how to adjust it with the new ISKY CAM :confused: Cam should be in next WK :thumbup: Quote Link to comment
73DATSON Posted December 11, 2012 Author Report Share Posted December 11, 2012 Just use your old rockers. (followers) Sheet of glass, wet sandpaper 600 grit maybe higher, kitchen sink. Back and forth rolling/rocking motion to put a pollish on them. Did they sell you new springs too? .470"- .480" lift is close to spring bind on the stock ones. yes new springs,pads. and some other stuff can't remember Quote Link to comment
73DATSON Posted December 17, 2012 Author Report Share Posted December 17, 2012 Ok so I called ISKY CAM to see what's up with my order? And they charged me but never called me to tell me that they don't have any CORDS!!! So I cancel,-((((( but I found this WEB CAMS in CALI. They had this cam left: Intake Exhaust Valve Lash (Inch): .007" .011" Valve Lift (Inch): 0.450 0.450 Valve Lift (mm): 11.43 11.43 Advertised Duration: 260° 260° Duration @ 0.050": 238° 238° Lobe Center: 108° 111° = 109.5° Overall Intake Opens 11° Before TDC Exhaust Opens 50° Before BDC Intake Closes 47° After BDC Exhaust Closes 8° After TDC Valve Timing Is Checked With Zero Valve Lash @ 0.050 Inches Of Valve Lift. So I think this would be a better cam? Not to crazy?? But my question is the lash cap? What size?? .160? .170? .180? Don't know? I'm heading to Nissan 2mrow. Any body? Quote Link to comment
DISLEXICDIME Posted December 17, 2012 Report Share Posted December 17, 2012 Have yo driven a l with a cam like that . It sucks in stop and go but it sure comes alive after 3500 Quote Link to comment
datzenmike Posted December 18, 2012 Report Share Posted December 18, 2012 but I found this WEB CAMS in CALI. They had this cam left: Valve Lift (Inch):0.450 Stock L20B cam: 0.413" at valve Advertised Duration:260° Stock L20B cam: 248 (likely not measured at 0.050" lift) Duration @ 0.050":238° Lobe Center: 108° 111° = 109.5° Overall Intake Opens 11°BTDC Stock L20B cam: Int. opens 16 BTDC* Intake Closes 47°ABDC Stock L20B cam: Int. close 52 ABDC* Exhaust Opens 50°BBDC Stock L20B cam: Ex. opens 54 BBDC* Exhaust Closes 8°ATDC Stock L20B cam: Ex. close 14 ATDC* Valve Timing Is Checked With Zero Valve Lash *Stock L20B cam not checked at 0.050" lift. @ 0.050 Inches Of Valve Lift. So I think this would be a better cam? Not to crazy?? But my question is the lash cap? What size?? .160? .170? .180? Don't know? I'm heading to Nissan 2mrow. Any body? Because of the measuring at 0.050" lift this is comparing apples to oranges except the valve lift and duration. I don't know what the stock valve opening and closings would be at 0.050". It does have a respectable lift and is under the need for replacement springs due to coil binding. 12 degrees of added duration will move the power band upwards by just over 500 RPMs... say about 6K-ish. Just for fun I messed with a cam calculator and with the 108/110 lobe center and keeping the following... Your cam has an Overlap of 41.00 degrees Intake Duration of 260.00 degrees. The Exhaust Duration is 260.00 degrees. The Inlet Cam has an Installed Centerline of 108.00 degrees ATDC. The exhaust cam has an Installed Centerline of 111.00 degrees BTDC. I have Intake Opens 22°BTDC Intake Closes 58°ABDC Exhaust Opens 61°BBDC Exhaust Closes 19°ATDC I basically added 6 degrees on either side of the cam lobe. I'll bet there are different way to get the same specs. Quote Link to comment
EricJB Posted December 18, 2012 Report Share Posted December 18, 2012 If you send Isky a core, it only costs $130.00 to have it ground. The cam outright (with a non OEM blank) is $245.00. I called last week to verify. Needless to say, I'm sending them a core. Quote Link to comment
72240z Posted December 18, 2012 Report Share Posted December 18, 2012 Both seem mild enough for the street and then some. I'm running a FAR BRE 311 power lobe came thats .463 lift and 329 duration with no problems at all. I paid 200 for the whole kit after hunting forums for a while. 1 Quote Link to comment
73DATSON Posted December 18, 2012 Author Report Share Posted December 18, 2012 <blockquote class='ipsBlockquote'data-author="datzenmike" data-cid="814819" data-time="1355795137"><p> Because of the measuring at 0.050" lift this is comparing apples to oranges except the valve lift and duration. I don't know what the stock valve opening and closings would be at 0.050".<br /> <br /> It does have a respectable lift and is under the need for replacement springs due to coil binding. 12 degrees of added duration will move the power band upwards by just over 500 RPMs... say about 6K-ish.<br /> <br /> <br /> <br /> Just for fun I messed with a cam calculator and with the 108/110 lobe center and keeping the following...<br /> <br /> <em class='bbc'>Your cam has an Overlap of 41.00 degrees<br /> Intake Duration of 260.00 degrees.<br /> The Exhaust Duration is 260.00 degrees.<br /> The Inlet Cam has an Installed Centerline of 108.00 degrees ATDC.<br /> The exhaust cam has an Installed Centerline of 111.00 degrees BTDC.</em><br /> <br /> I have<br /> Intake Opens 22°BTDC<br /> <br /> Intake Closes 58°ABDC<br /> <br /> Exhaust Opens 61°BBDC<br /> <br /> Exhaust Closes 19°ATDC<br /> <br /> I basically added 6 degrees on either side of the cam lobe. I'll bet there are different way to get the same specs.</p></blockquote> Hey mike what size lash cap I need? Quote Link to comment
banzai510(hainz) Posted December 18, 2012 Report Share Posted December 18, 2012 webcams has a 488 252 dur cam I would pick that one the 450 one you posted remeber you got to subtract the valve lash as that will be your real lift. L motors like lift. Remember they might have to grind the cam as the waiting period can take a month at least. The webcams are new cores if you want a outright one. There have been a few people said they got Isky cams before but never mentioned that they needed cores before. Nissanmotorsports might have new cams laying around. Schneider doesnt have new ones either but will do a core. if a regrind youll end up using close to 190 200 lash pads lash cap size depends on if head, valve seats and valves are machined as it all affects the wipe pattern.also it if the valve stems are event across the top. as soem people trim the tops also to make them even so one size pad is needed. I seen heads were every rocker needed a different size(bad news as you want close to 1 size. You can be off a little and not worry about it. Ill let Sealick take over as he knows the tricks to get by now on this 1 Quote Link to comment
datzenmike Posted December 18, 2012 Report Share Posted December 18, 2012 No idea. Ask Sealick. Generally it's a test fit. I think he cut up shims and stacked them untill he got it right, added up the shims and bought pads to match. Quote Link to comment
