Crashtd420 Posted August 8, 2020 Report Share Posted August 8, 2020 4 hours ago, Zonargx said: @Crashtd420 where exactly did you glue it I glued it at the center about 2 inches from the top Not sure if this matters if your getting the factory mount but I figured I'd answer ... but yes same spot.... If you go back to this idea let me know... I'll see if I can find the parts and glue I used.... 1 Quote Link to comment
MikeRL411 Posted August 8, 2020 Report Share Posted August 8, 2020 Visually, early Maxima rear view mirrors use the same mounting screw holes and the actual mirror looks like the 520 / 521 / 410 / 411. UV deterioration of the plastic mirror housing is a fact of life. 1 Quote Link to comment
Zonargx Posted August 8, 2020 Report Share Posted August 8, 2020 @Crashtd420 I used the Permatex from the auto parts 1 Quote Link to comment
thisismatt Posted August 9, 2020 Author Report Share Posted August 9, 2020 I wonder if a BMW mirror would fit. They have a similar ball & socket design, but I can't find the ball diameter posted anywhere. 1 Quote Link to comment
