Farmer Joe Posted December 5, 2012 Report Share Posted December 5, 2012 yeah, call me a dick, when you sit there and want us to spoon feed you the answer. i already said get in ahold of Duke since hes the only one i know that did the carbed DE. maybe you should check out his thread? theres your idea... Quote Link to comment
Ihatethenw Posted December 5, 2012 Author Report Share Posted December 5, 2012 ^ still mr know it all I hate this forum.. Thanks to all that helped pics to come... Quote Link to comment
Skib Posted December 5, 2012 Report Share Posted December 5, 2012 ^ still mr know it all I hate this forum.. humble yourself. your not going to get spoon fed here. the info is out there, its been done before. shit the info is in here already... its not going to just bolt up and work like magic your going to have to spend some monies, get creative and make it work. Quote Link to comment
Ihatethenw Posted December 10, 2012 Author Report Share Posted December 10, 2012 I got it! Why can't I just chop of the shaft in the ka dizzy? And out it in the cupler on the L dizzy and tig them together at the right length? Quote Link to comment
Stoffregen Motorsports Posted December 10, 2012 Report Share Posted December 10, 2012 I got it! Why can't I just chop of the shaft in the ka dizzy? And out it in the cupler on the L dizzy and tig them together at the right length? I can't picture it exactly, but yes, that's the idea! Other members may have a better idea what you're talking about, but sometimes a hybrid distributor needs to be made. I used to take the tach drive Mallory distributors and put L-series single point stuff inside, just so it would look cool, have a tach drive, and use over the counter internals. You are headed down the right path with your new way of thinking. Quote Link to comment
FricFrac Posted December 12, 2012 Report Share Posted December 12, 2012 I got it! Why can't I just chop of the shaft in the ka dizzy? And out it in the cupler on the L dizzy and tig them together at the right length? Good luck welding them together perfectly straight. I had a machinist cut and sleave my L28ET dizzy shaft to mate up to an Z24i dizzy to work on a Z22 timing cover.... http://community.ratsun.net/topic/48127-1969-datsun-510-2dr-z22-turbo-efi-build/?do=findComment&comment=786133 Quote Link to comment
Ihatethenw Posted December 14, 2012 Author Report Share Posted December 14, 2012 It should be done and fired up soon intake should be here Monday or Tuesday I'm pretty stoked ka24de in a ae86 corolla on dual side drafts... Hope it's fun it I'm selling motor and doing sr20 Quote Link to comment
izzo Posted December 14, 2012 Report Share Posted December 14, 2012 It should be done and fired up soon intake should be here Monday or Tuesday I'm pretty stoked ka24de in a ae86 corolla on dual side drafts... Hope it's fun it I'm selling motor and doing sr20 1 Quote Link to comment
hobbes_the_cat Posted December 15, 2012 Report Share Posted December 15, 2012 So you are in a hurry to build this motor so you can turn around and sell it? I hope you at least take a vid of it running before it goes away. Quote Link to comment
Ihatethenw Posted December 17, 2012 Author Report Share Posted December 17, 2012 When it blows it will be taken out and sr will be put in.. Plenty of drift videos to come... Pumpkin 210 building my dizzy should be fired this week Quote Link to comment
Ihatethenw Posted January 16, 2013 Author Report Share Posted January 16, 2013 Car runs now getting tuned soon burns 3 gear when ya drop A great super stoked for this years drift season Quote Link to comment
Ihatethenw Posted January 16, 2013 Author Report Share Posted January 16, 2013 When I made the dizzy I used points and ground it so they opened like points and fired first turn so easy to do this set up! Cost a lot! But sounds amazing and rips hard and revs fast as hell Quote Link to comment
DAT510 Posted January 16, 2013 Report Share Posted January 16, 2013 Wow. Good job! Quote Link to comment
Ihatethenw Posted January 16, 2013 Author Report Share Posted January 16, 2013 Thanks!! Does any one know what fuel presser webers run at so I can get the right fuel pump? Mines only at 2lbs.. Regulator is all the way out. Quote Link to comment
hobbes_the_cat Posted January 16, 2013 Report Share Posted January 16, 2013 I'm pretty sure 3.5lb is the magic number. My side draft webers like 3-3.5 lbs. Quote Link to comment
Ihatethenw Posted January 16, 2013 Author Report Share Posted January 16, 2013 Ok sweet Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 Weber requires 2.5 to 3.0 lbs per Weber. But will often run OK at higher pressures, but they do not guarantee it. Quote Link to comment
Ihatethenw Posted January 16, 2013 Author Report Share Posted January 16, 2013 So get a 7-9 lb pump and regulate it down? Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 Or use a 3.8 psi fuel pump and don't regulate it down. It'll work OK at 3.8 psi Or remove the regulator you have now, and perhaps the pressure will go back up to something in the range. Regulators are often the CAUSE of problems. Quote Link to comment
Ihatethenw Posted January 17, 2013 Author Report Share Posted January 17, 2013 I was thinking that its a fancy one.. Quote Link to comment
Stoffregen Motorsports Posted January 17, 2013 Report Share Posted January 17, 2013 Just don't use a cheap regulator. They restrict the fuel flow too much. http://www.summitracing.com/parts/mrg-9710/overview/ Use a Holley type regulator that doesn't restric fuel flow. http://www.summitracing.com/parts/hly-12-804/overview/ They are the same price. Quote Link to comment
Ihatethenw Posted January 18, 2013 Author Report Share Posted January 18, 2013 Mines a good one I paied like 100 fornit Quote Link to comment
ggzilla Posted January 18, 2013 Report Share Posted January 18, 2013 Your's is a good one for $100 which doesn't work (you said it would only output 2 lbs). To get the really good regulators you need to spend about $30. 1 Quote Link to comment
Ihatethenw Posted January 18, 2013 Author Report Share Posted January 18, 2013 I put in a used fuel pump my dad gave my that was a spare for our midget race cars.. I all ready knew I needed a bigger one. Quote Link to comment
mhub91 Posted February 22, 2016 Report Share Posted February 22, 2016 What ever happened to this engine? Any more info on distributor? Quote Link to comment
