ohmrchristopher Posted November 19, 2012 Report Share Posted November 19, 2012 So my inner headlamps are yellow, and I like the look of them on. However its not fair to the other drivers to have all four lights on (highbeam/passing mode) when I'm driving through town. So is there a way to wire the inner two lamps [high] to the marker/signal lights so that A] When the [light] knob is pulled half way my [high] lamps come on with my marker/signal B] When the knob is fully pulled out the inner [high] lamps turn off and act as normal? High/low per coloum switch. I realize that taking power from the marker/signal lights will cause the [high] lamps to flash when turning, I am kinda into this as I think it would be better..... Wait I just remembered that our turn signals dont flash on/off, they flash dim/bright.... does that mean the signals are getting a <12V source for power then a 12V source to flash? I would need two relays for this would I not? One to close a circut to turn on the [high] lamps when the markers are on, and a second to piggyback off the flasher circut and make them flash with the signals? Im going to go stare at a wiring diagram and play with MS Paint for a bit... :? PS truck is a 1973 Quote Link to comment
DanielC Posted November 19, 2012 Report Share Posted November 19, 2012 The turn signals are on or off. They do not go dim. It just takes time for the bulb filament to heat up, and cool down. You are on the right track by using relays. I do not think the wiring, turn signal switch, or the flasher would live long with the extra electrical load of a headlight in the circuit also. if you use a normal flasher, it will also change the speed of the flashing, I think much faster. Another issue is it is harder on the lamp filament to be switched on and off a lot. You may also shorten the headlight lamp life a lot. Quote Link to comment
ohmrchristopher Posted November 19, 2012 Author Report Share Posted November 19, 2012 On my truck the light is on, then "flashes" brighter. I know it doesnt sound right but thats what it does. What If I tried to copy the Dodge cars where the "turning" headlamp turns right off to allow seeing the signals flash much easier? Quote Link to comment
erichwaslike Posted November 19, 2012 Report Share Posted November 19, 2012 if they are on, then get brighter that means you have a dual fillement bulb in the turns. if so tap off the side that is on not the one that flashes and put a relay in and have it control the high beams. but it sound like your a lil confused on the function of the turn signal setup. also having your high beams flash will get you a ticket as it will look like you are impersonating a cop car, and i bet a few ppl wont liek having a high beam flashing at them and you may get a coke or shake thrown at you and your ride.... Quote Link to comment
banzai510(hainz) Posted November 19, 2012 Report Share Posted November 19, 2012 Daneial stern had a H1 lamp that had a parking light in the housing. I wonder if you could just splice of the turn signal and route that to the H1 lamp I dont see it on their site now but I think its the same as this one. Maybe someone can verify. I had this on my Capri while station in Germany. Just put your blinker on what ever side of the road you was so on comming cars could see the corner of your car. It was a small lamp so it didnt really drain the battery http://www.rallylights.com/detail.aspx?ID=2257 Quote Link to comment
blackwolf Posted November 20, 2012 Report Share Posted November 20, 2012 You probably need to beef up the wiring if you try to do that, other wise you will just melt all your wiring and cause a fire. Im not sure on the gauge wire used for the turn signals but i know the head lights use bigger for the amount of amps being pulled. Quote Link to comment
wayno Posted November 20, 2012 Report Share Posted November 20, 2012 There are lots of headlights available with the trun signals inside of them. http://www.ebay.com/itm/Classic-7-inch-Glass-Lens-HeadLights-Diamond-Tri-Bar-Yellow-Turn-Signal-H4-/251183908649?pt=Motorcycles_Parts_Accessories&hash=item3a7bba4729&vxp=mtr http://www.ebay.com/itm/1-DAY-HUGE-SALE-7-CHROME-CLEAR-DOT-TRI-BAR-HEADLIGHTS-w-TURN-SIGNAL-STREET-ROD-/230884524113?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c1ca4051&vxp=mtr http://www.ebay.com/itm/7-Blue-Dot-Tri-Bar-Headlights-w-Turn-Signal-Bulbs-/251184356101?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a7bc11b05&vxp=mtr Quote Link to comment
banzai510(hainz) Posted November 20, 2012 Report Share Posted November 20, 2012 I like the the top one but look like taiwan made but acceptable. Be good for old jeeps. OI kinda like the datsun turn signals myself and why would one want to change.( I know to be different) Quote Link to comment
sedition88 Posted November 25, 2012 Report Share Posted November 25, 2012 PM Greengoon. He has yellow highbeams that he turned into turn signals. Here's he's link: http://community.ratsun.net/topic/26747-the-greengoon-build-thread/ Quote Link to comment
erichwaslike Posted December 6, 2012 Report Share Posted December 6, 2012 it was actually still turn signals with the factory bulbs in a headlight housing... its on this page.... its not high beams.... http://community.ratsun.net/topic/26747-the-greengoon-build-thread/page__st__40 Quote Link to comment
