jnec510 Posted June 14, 2008 Report Share Posted June 14, 2008 this is my last chanc to keep my truck before i have to let it go. my electrical is all hay wire. i got the lights blinkers aN TURNSIGNALS to work now the dashlights are out. i bought a new under dash harness hopin for an easy fix:lol:. but of course i was wrong. now the dist isnt gettin power the ignition works here an there i couldnt find the plug for the dimmer switch. i am lookin for somebody close by to ix my truck. i am willin to pay:D. i reallyu want to get all of this fixed if i can. thanks. jason Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 i hate to say this, cause it makes it sound easy, but re-wire everything with new wire from scratch. thats what i am in the process of doing.... Quote Link to comment
jnec510 Posted June 14, 2008 Author Report Share Posted June 14, 2008 how hard is it i have never done it befor. would you make me one zap branigon:D Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 branigans law is like branigans love......fast and hard....... what i was saying is wire everything from scratch.....ok, i got online and foubd brand new headlight connectors, i used those and a spool of wire to do an all new headlight and front turn signal harness separate from the nissan stuff. next is the tails after i do a caddy light swap. new switches and it all works like i want it to. just do one area at a time and get each working before moving on to the next one. Quote Link to comment
jnec510 Posted June 14, 2008 Author Report Share Posted June 14, 2008 i get to frustrated doin electrical. i have been out wirh a electrical tester an just keep beatin my head agaist the wall. destroy all humans Quote Link to comment
dat521gatherer Posted June 14, 2008 Report Share Posted June 14, 2008 rewiring from scratch isn't easy if you dont know what your doing or a novice or even if you do know what your doing.. besides sticking withe stock is always best so the next owner doesnt take a flame thrower to it.:D just find a original unmolested wiring harness from the junk yard or a forum member and replace yours then save yours for spare parts. oh wait you have a 620.:eek: trade it for a 521. they look much better and the wiring is waaaayyyy easier. good luck Quote Link to comment
jnec510 Posted June 14, 2008 Author Report Share Posted June 14, 2008 i put a new one in from the junkyard an a new set of problems Quote Link to comment
Phlebmaster Posted June 14, 2008 Report Share Posted June 14, 2008 What's not working now?? ;) Quote Link to comment
jnec510 Posted June 14, 2008 Author Report Share Posted June 14, 2008 power to the coil dashights heater water temp gauge:mad: it makes me so:confused: Quote Link to comment
banzai510(hainz) Posted June 14, 2008 Report Share Posted June 14, 2008 ck the fuses and fuse box area???????? Ignition switch circut? Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 he said he already did a wide harness swap, thats why i recommended the new harness. i know it's hard, but thats what i did..... Quote Link to comment
]2eDeYe Posted June 14, 2008 Report Share Posted June 14, 2008 Stick with the stock stuff. Trace each wire in question individually to make sure you have a complete circuit. Each section of harness and each component of the system can be verified independently. You'll find the bad connection, it's all process of elimination, unfortunatly it is a very tedious process. Changing out components without knowing what is wrong in the first place can lead to more frustration. power to the coil Ignition circuit, trace it from the key to the battery... individual components first. dashights Do your parking lights work? Could be your dimmer heater Fan? again check the each component water temp gauge Sender, guage or wiring...don't forget to check your grounds Quote Link to comment
datzenmike Posted June 14, 2008 Report Share Posted June 14, 2008 You have a '77 right? Did you say you have a remote igniter ignition in it?? What year was the replacement wire harness out of? Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 those ideas are better than mine...... mine is still good too, lol Quote Link to comment
]2eDeYe Posted June 14, 2008 Report Share Posted June 14, 2008 You really have to know what your doing with electrical if you want to start from scratch....or you might end up with a BIG fire ;) Quote Link to comment
OL YELLER Posted June 14, 2008 Report Share Posted June 14, 2008 YOU can do this...it is just a matter of doing 'zactly like Redeye said, one wire one circuit at a time.......................Get a good wiring diagram, a couple of highliter markers and use the diagram to trace the wires....Listen man, if this OLD MAN can do , then you can too...Don't be in a hurry and you will find all your problems and solving them is easy....trust yourself man... Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 thats what i want mine to look like, i will post pics in a few..... Quote Link to comment
fiveNdime Posted June 14, 2008 Report Share Posted June 14, 2008 I would HIGHLY recommend using the stock setup if possible, for the simplicity of tracing stuff down. All the wires have different color markings on them so its easier to trace. If you just wire the truck up yourself you would need a ton of different colors. Or you could do it the wrong way and wire with a handful. I have wired many cars and I do it like the others say. Get one circuit done at a time. Focus on the stuff that makes it run first, then go to the safety things like blinkers and lights then make your way to the less important stuff. I wish I were there to help, I actually don't mind wiring its a hard skill to get down but once you do its not that bad. To me it sounds like you have a larger problem on your hands. Something like your fuse block. Test lights are your friends when wiring. Always remember to make sure the ground is good on what your testing. START at the Fuse block then branch out from there. I cant stress enough to start there and check one thing at a time. And don't bang your brains out:eek: PS Make sure you mark the circuits that are good with a piece of tape and/or make a checklist so you don't go over things you have done already. 1 Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 I would HIGHLY recommend using the stock setup if possible, for the simplicity of tracing stuff down. All the wires have different color markings on them so its easier to trace. If you just wire the truck up yourself you would need a ton of different colors. Or you could do it the wrong way and wire with a handful. I have wired many cars and I do it like the others say. Get one circuit done at a time. Focus on the stuff that makes it run first, then go to the safety things like blinkers and lights then make your way to the less important stuff. I wish I were there to help, I actually don't mind wiring its a hard skill to get down but once you do its not that bad. To me it sounds like you have a larger problem on your hands. Something like your fuse block. Test lights are your friends when wiring. Always remember to make sure the ground is good on what your testing. START at the Fuse block then branch out from there. I cant stress enough to start there and check one thing at a time. And don't bang your brains out:eek: PS Make sure you mark the circuits that are good with a piece of tape and/or make a checklist so you don't go over things you have done already. that has to be one of the best anwseres on this forum i have read in a long time. that is by far the best way to do it! i did it the other way around though, i started with the easy stuff to get it out of the way and taped those wires up so i could concentrate more on the more complex stuff..... Quote Link to comment
jnec510 Posted June 14, 2008 Author Report Share Posted June 14, 2008 i found one break an a bad inline fuse. fixed both an now the coil gets power only when i am crankin the starter. anybody have a complete harness they want to sell. relays an all. an there is no ignitor box the thing i thought it was was hooked to the wiper switch Quote Link to comment
datzenmike Posted June 14, 2008 Report Share Posted June 14, 2008 Coil on start only just means there is no power on the Black/Red wire going to the ballast resistor. Check for power in the run position: YES, power on the Black/Red, jumper a wire across the ballast resistor, it should now run, the ballast is bad. NO power on Black/Red wire, check for voltage at the ignition switch plug end of the Black/Red wire. Yes there is power, the wire between ignition switch and the coil is broken or a bad contact. No power, ignition switch or fuse is bad, replace fuses. 1 Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 damn your on the ball today!!! wish i knew half what you do about this stuff!!! Quote Link to comment
datzenmike Posted June 15, 2008 Report Share Posted June 15, 2008 Gotta keep theses ratsuns on the road and runnin'. Quote Link to comment
Llittle_Llama Posted June 15, 2008 Report Share Posted June 15, 2008 hells yes! imma need help with mine soon :( Quote Link to comment
