Eric Posted November 3, 2012 Report Share Posted November 3, 2012 I have a 610 wagon, with std. L18 and 4 speed. Can i fit the dogleg 5 speed from my S110 with L18 in my wagon? Gearboxes have the same length? Quote Link to comment
bonvo Posted November 3, 2012 Report Share Posted November 3, 2012 yes it can be done but the 610 has the long tail transmissions by default your best bet is to find a 5 speed from a z or truck as they are already long tail transmissions i put a dog leg in my 610 and had to cut a new hole for the shifter and lengthen the drive line other then that it bolted in Quote Link to comment
datsunaholic Posted November 3, 2012 Report Share Posted November 3, 2012 He's in the Netherlands, so the S110 (180SX) dogleg might already be long. Quote Link to comment
bonvo Posted November 3, 2012 Report Share Posted November 3, 2012 true enough only way to really know is to take both transmissions out and measure Quote Link to comment
Eric Posted November 4, 2012 Author Report Share Posted November 4, 2012 so s110 gearboxes have different lengths in different countries? i gues il have to measure it then, i have 260z 5 speed ready but that is much older than the s110 gearbox i have so i prefer to use the s110 box. Quote Link to comment
datzenmike Posted November 4, 2012 Report Share Posted November 4, 2012 Best to measure the lengths. You don't have to remove them to do this but you do have to get under there to do it. Measure back from the underside horizontally to the tail where the driveshaft goes in. This will avoid an inaccurate slope distance. Use a string with a nut on it as a plumb bob on the tail. I think you will find that the long transmission is 31.5" or 80cm in length. We did get long F4W63 4 speeds with our 610s and they look like this... We did not get 5 speeds in our Z cars until '77, but in Europe the old Fairlady Roadster box (FS5W71A) was fitted with an L series bell housing. A few made it over here for competition use (FS5C71A) through the dealers? (not sure) Anyway your 260z 5 speed looks like this?... Note the flange output to the driveshaft. We also did not get the FS5W63A dogleg in the long length either, but a few have shown up, probably bolted to import engines from Japan. Do yours look like this? All three are approximately 80cm long. The Roadster box is bullet proof. The dogleg is no where near as strong. We got the short doglegs and they were just adequate for an unmodified 2 liter L series motor. . Quote Link to comment
Eric Posted November 5, 2012 Author Report Share Posted November 5, 2012 That last picture with the FS5W63An looks like the dogleg that is under my s110, havent been under the 610 yet to see what that one looks like. Thanks for that info and pictures, thats helpful! The numbers can be found on the gearboxes? Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 The 63-series gearboxes will have a cast "63" on the right side of the housing or the extension (tail housing). The actual model number does not appear on the box. You can identify via the photos. Quote Link to comment
datzenmike Posted November 5, 2012 Report Share Posted November 5, 2012 I would say the passenger side but???? It's by the reverse light switch. Quote Link to comment
ggzilla Posted November 5, 2012 Report Share Posted November 5, 2012 Passenger side is different in Canada. But if you say "right side" that works everywhere ... Quote Link to comment
Eric Posted November 7, 2012 Author Report Share Posted November 7, 2012 Passenger side various from country to country, i have a RHD car in the Netherlands, so my passenger side would be on the left side of the car. Quote Link to comment
datzenmike Posted November 7, 2012 Report Share Posted November 7, 2012 Yeah I was kidding. Right rear of transmission just below the reverse light switch. 63A. The #2 is likely a casting revision. Quote Link to comment
ggzilla Posted November 7, 2012 Report Share Posted November 7, 2012 Mike, do 71 series transmissions have a '71' identification mark? Quote Link to comment
datzenmike Posted November 7, 2012 Report Share Posted November 7, 2012 Many/most do yes. Z series say LZ71B This one is from my CA18ET and says Z (backwards L) 71B Pre '80 transmissions were only used on L series and seem to only have a single L on them (4 speeds too) 1 Quote Link to comment
Eric Posted November 7, 2012 Author Report Share Posted November 7, 2012 you know a lot about transmissions :) Quote Link to comment
Eagle_Adam Posted November 7, 2012 Report Share Posted November 7, 2012 there is none more knowledgeable about datsun transmission than king rat :D Quote Link to comment
