ggzilla Posted October 27, 2012 Report Share Posted October 27, 2012 Looking for an A-series header For A-series, South Yokohama makes high-quality large-tube headers 4-into-1 for 1200 http://www.south-yokohama.com/products/detail.php?product_id=66 4-into-1 for B310 http://www.south-yokohama.com/products/detail.php?product_id=43 Quote Link to comment
HRH Posted October 27, 2012 Report Share Posted October 27, 2012 The racetep header I got some 6 years ago was shit for quality. Massive amounts of wiggle from a way too large center hole, leaky flanges. Not worth it. If you're going to get one, have Troy Ermish build you a custom header. Or just run the stock exhaust manifold. Quote Link to comment
datsunfreak Posted October 27, 2012 Author Report Share Posted October 27, 2012 For A-series, South Yokohama makes high-quality large-tube headers 4-into-1 for B310 http://www.south-yok...p?product_id=43 I don't normally consider myself a cheap bastard, but I can't see paying $1100-1200 for a header. I can build my own for less than half that. Last stainless header I built only cost about $500-550. Quote Link to comment
datsunfreak Posted October 27, 2012 Author Report Share Posted October 27, 2012 Or just run the stock exhaust manifold. Can't. Two reasons. 1. Because it won't clear the dual sidedraft intake. 2. Because racecar. Quote Link to comment
DISLEXICDIME Posted October 27, 2012 Report Share Posted October 27, 2012 time to head to the lazer cutter and buy some weld L's Quote Link to comment
datsunfreak Posted October 27, 2012 Author Report Share Posted October 27, 2012 time to head to the lazer cutter and buy some weld L's Sounds like it... :rofl: Just wish this motor was crossflow so I could make me a big ol' bundle-o-snakes style header.... :thumbup: Quote Link to comment
DISLEXICDIME Posted October 27, 2012 Report Share Posted October 27, 2012 ahhh just build a snake bundle turbo manifold and a custom intake with a snail and a su attached Quote Link to comment
datzenmike Posted October 27, 2012 Report Share Posted October 27, 2012 So who else makes a header for an L20b? NIssan. (hint: it's the one on the right) Cheap and effective Quote Link to comment
ggzilla Posted October 27, 2012 Report Share Posted October 27, 2012 Can you grind the top center of the cast header so it will clear the aftermarket intake? Quote Link to comment
JoeCool Posted October 27, 2012 Report Share Posted October 27, 2012 NIssan. (hint: it's the one on the right) Cheap and effective Is that an L20b like mine? Can't tell what mine looks like with the heat shield. Quote Link to comment
datzenmike Posted October 27, 2012 Report Share Posted October 27, 2012 No, the L20B are 4 pipe into a single down outlet. That one is an L16/18 with 4 into 2 and then 2 into 1 down pipe. The '75-'77 L20Bs had the intake and exhaust bolted together so you would need to address a hole in the bottom of the intake below the carb. A plate could be bolted over it. The '78 and up L20Bs had divorced intake and exhaust manifolds and will take an earlier L16/18 exhaust no problem. Quote Link to comment
datsunfreak Posted October 28, 2012 Author Report Share Posted October 28, 2012 Can you grind the top center of the cast header so it will clear the aftermarket intake? Nah. In order to grind enough off to make it fit, you'd break through into the exhaust ports. B) I actually have some custom machined spacers to push the intake manifold out 1.5" to clear a stock exhaust manifold, but again I really want a header, so... :wub: Quote Link to comment
datsunfreak Posted October 29, 2012 Author Report Share Posted October 29, 2012 Did some wheeling and dealing and picked up a lightly used Nissan Comp header today, so call off the dogs! ^_^ Quote Link to comment
