Uber Deaf One Posted October 6, 2012 Report Share Posted October 6, 2012 Drive the car harder. Or, if you have a stock rear crossmember, slot it and dial out the camber. I don't see anything TERRIBLY wrong with your rear camber... if you drive the car a little harder through the turns you'd use that outside edge more. EDIT: You were still posting pics. Quote Link to comment
Turbojovi Posted October 6, 2012 Author Report Share Posted October 6, 2012 Any input on how to adjust the rear doesn't look adjustable..... Quote Link to comment
Turbojovi Posted October 6, 2012 Author Report Share Posted October 6, 2012 Its not a track car this is a DD Quote Link to comment
Uber Deaf One Posted October 6, 2012 Report Share Posted October 6, 2012 Slot the rear crossmember to get some camber adjustment out of it. If you don't want to or can't do that, you can purchase a crossmember with this done already, or even fancier setups. What else is done to the car...? I see a finned differential cover, bigger wheels, rear disk brakes... Also I'm not saying go out and bomb your local mountain roads. But onramps/offramps, take them a little faster here and there. You'll use more of the tire and your tire wear issues will be gone. EDIT: You could also raise the rear of the car. Higher ride height in the back = less camber. I wouldn't be worried about that much camber though.... I bet your toe is way off for a daily driver. Quote Link to comment
Turbojovi Posted October 6, 2012 Author Report Share Posted October 6, 2012 whats the name of the the company that makes this rear cross memeber? it has a posi rear end the last owner said toyota MR2? has panasports 14 or 15 rear disc brakes probaly from a 240zx ill be post pics later to help my identify some of these parts Quote Link to comment
DAT510 Posted October 6, 2012 Report Share Posted October 6, 2012 whats the name of the the company that makes this rear cross memeber? it has a posi rear end the last owner said toyota MR2? has panasports 14 or 15 rear disc brakes probaly from a 240zx ill be post pics later to help my identify some of these parts Weird, there is a Nissan stamp on the cover..240Z doesn't have rear discs. maybe 240sx? and they don't come drilled stock.. Try getting the pics of under the Diff. one can tell a R180 and a R200 apart from the size. Do 510s come stock with Anti roll bars in the back!? I don't remember seeing one under my 510.. I'm really tired can't remember. Quote Link to comment
Uber Deaf One Posted October 6, 2012 Report Share Posted October 6, 2012 This is probably the best aftermarket crossmember. http://datsun510.com/photopost/showphoto.php?photo=8005&cat=views&limit=views You bought a 510 that looks to have been done up pretty good... drive it harder! lol I don't think 510s came with rear bars... that one is likely aftermarket. Quote Link to comment
Turbojovi Posted October 7, 2012 Author Report Share Posted October 7, 2012 How do i go about buying one like that? Quote Link to comment
datzenmike Posted October 7, 2012 Report Share Posted October 7, 2012 I don't think 510s came with rear bars... that one is likely aftermarket. They didn't. Cars come from the factory with slight understeer designed in. Lowering or adding a stiffer front bar increases this and the need for one at the back to counter act this. Quote Link to comment
Turbojovi Posted October 7, 2012 Author Report Share Posted October 7, 2012 This is probably the best aftermarket crossmember. http://datsun510.com/photopost/showphoto.php?photo=8005&cat=views&limit=views You bought a 510 that looks to have been done up pretty good... drive it harder! lol I don't think 510s came with rear bars... that one is likely aftermarket. Quote Link to comment
Turbojovi Posted October 7, 2012 Author Report Share Posted October 7, 2012 How do i go bout buying one of this Quote Link to comment
datsunfreak Posted October 7, 2012 Report Share Posted October 7, 2012 How do i go bout buying one of this Email the guy who makes them. I'll send you his contact info in a PM. Quote Link to comment
banzai510(hainz) Posted October 7, 2012 Report Share Posted October 7, 2012 Dude dont even worry about it.!!!!!!!!!!!!! a little neg camber is good. plus it looks gangster. Mine is alot worse!!!!!!!!! why waist the time/money doing all that work. most street 510 dont need a sway bar in rear. Kinda defeats the purpose of a IRS. Unless you race on a nice FLAT TRACK and corner really hard on rear swap bars one MAY adjust of thay have added holes to pick from. If you DONT what you can do is tighten the bushings or loosen them. Thats a cheap adjustment right there. Quote Link to comment
Dime Dave Posted October 8, 2012 Report Share Posted October 8, 2012 Here is another option, Camber -Toe Brackets that weld to your existing crossmember. Link: http://www.futofab.c...nsion&Itemid=22 Quote Link to comment
Uber Deaf One Posted October 8, 2012 Report Share Posted October 8, 2012 ^ I have the same brackets... very happy with them. Quote Link to comment
