banzai510(hainz) Posted August 8, 2012 Report Share Posted August 8, 2012 Running lights really dont need the alternator. Remember the feed wire to the fuse box. the running lights will be output power from fusebox. ck the connections soemtimes the fuses might look good. Cahnge them out anyways with the correct amperage Quote Link to comment
uberkevin Posted August 8, 2012 Author Report Share Posted August 8, 2012 tranny. Quote Link to comment
uberkevin Posted August 8, 2012 Author Report Share Posted August 8, 2012 Running lights really dont need the alternator. Remember the feed wire to the fuse box. the running lights will be output power from fusebox. ck the connections soemtimes the fuses might look good. Cahnge them out anyways with the correct amperage I'll ck those thank you. But what I meant was could my alt have been what made my truck just spotter a little and die and not want to start after It stopped. That was my problem a few days ago after driving for about 25 minutes. Also longest drive Ive had sence I put the engine in. " It was sitting for 20 plus years" Quote Link to comment
DanielC Posted August 8, 2012 Report Share Posted August 8, 2012 The reverse lights will only work with the key on. If you have to work on the reverse lights for a while, unplug the wire on the distributor to the points, from the coil. Here is a picture under one of my Datsun 521 trucks. I am checking for power to the reverse light switch, in this picture. The reverse light switch wires are red, with a black stripe. One of the red w/black wires always has power with the key on. The other red w/black wire goes to the reverse lights. It gets power when the transmission is in reverse. Here is a picture of how I backprobed the connector, to check for power. Quote Link to comment
uberkevin Posted August 8, 2012 Author Report Share Posted August 8, 2012 Thank you this should really help get them working. I'll let you know. But what do you mean by " unplug the wire on the distributor to the points, from the coil" I have an idea but I dont want to mess something up. Quote Link to comment
DanielC Posted August 8, 2012 Report Share Posted August 8, 2012 If you have a points type of distributor, there are two wires going to it. But if you do not leave the key on very long without the engine running, do not worry about it. Quote Link to comment
ggzilla Posted August 9, 2012 Report Share Posted August 9, 2012 Alternator not running for 20 years should be OK. Remember, the engine does not need an alternator to run good. It won't sputter if the alternator stops working. Quote Link to comment
Eagle_Adam Posted August 9, 2012 Report Share Posted August 9, 2012 werent these two truck for sale a little bit ago? i think ive seen em before Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Nope, But you can come look at the red one if you want anything from it. But testing my reverse switch?? these can go bad right?? Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Has it really been a year since I've seen these 2 trucks? http://community.ratsun.net/topic/34520-abandoned-vehicle/ Where does the time go? Tsk, tsk. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Youve seen these two truck huh?? Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Youve seen these two truck huh?? I have. Jaret's greenish one was in my yard for close to 9 months waiting for him to deliver parts. The red one was in a field in Pasco, along the river across the street from Jaret's uncles house. We should talk. Quote Link to comment
banzai510(hainz) Posted August 9, 2012 Report Share Posted August 9, 2012 flatcat should help !!!!!!! alternator belt loose??????? If the alternator is not charing eventlually the battery will drain out truck stops running Charge the battery up and put a diguital volt meter across it. 1)Test at idle, take reading 2)than rev it up 3)then put the headlights on the reverse lights not working is a minor issue and worry about the lights and why it dies first. I had one of these , plug in cig lighter and doesnt drain the battery,you can monitor it when good and always cking youll know soemthing is up before it soemthing goes wrong to far from home(hopefully). Theres different version out there but they work. http://iequus.com/Product/3721/Battery-Monitor Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Just so it's known- I have no hard feelings. Really more upset that I lost a friend out of the ordeal between Jaret and myself. Glad to see the truck made it back to life. Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 flatcat should help !!!!!!! Flatcat would. But I have history with this truck. And this owner is friends with previous owner. With that on the table-this dude probably doesn't even want my help. Who knows the story this guy has heard aboot me. (For my side of that story- http://community.ratsun.net/topic/34520-abandoned-vehicle/ ) Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 So how did you get the trucks again? I can tell you so much about both of those trucks. You friends with Jaret? I saw he's on your Face Space. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Man I can forsure use some help. This is my first datsun and frist time really doing anything but I love it. Lreaning whats what. Jaret is my gfs cuzin. And I got his truck for 500 bucks, with two other engines, We'll one was half a engine. But yeah there is a huge wiring problem. Maybe not huge but forsure has one, I just got back from driving and my blnker lights went out but came back on after hitting a few bumbs my running lights and reverse lights don't work either. I also think my engine is running kinda wired. Can I post videos on here I recored it running. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 And i got the red truck from the feild by Jarets uncals house. I live there. youve been out here right and looked at the red one right? Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Wowzers. I know that carb has seen better days. And if the long block was the only thing swapped into the green truck, then suspect some PCV issues along with a close to FUBAR'd carb. As far as the electrical-that will just need to be sorted out in person. 40 year-old system-and that green truck has seen better days. Between Jaret and the previous owner, it's a nightmare. Did he give you any history? Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 And i got the red truck from the feild by Jarets uncals house. I live there. youve been out here right and looked at the red one right? I have. It was supposed to be mine. That's also how they now what engine it has in it. 'Cuz I told them. That motor is a Japanese imported crate motor. W53 head on an L16. Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Uh oh. Somebody added me as a friend. :blush: Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 No history. and Ive got a weber on it now. Some of the stuff you said I have know I idea what it means haha I had to change the cluch and that was it, there was an inch and a hald diffrece between them. Jaret bets shit up and I knew that before I got this truck from him so I knew I had my work cut out for me. Also whenever you have free time give be a call or text some help would be awesome! Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Is that the Weber that Jaret gave you? If it is, it is not in good shape. And that truck was destroyed by the guy that owned it before Jaret. Jaret bought it the day after I went and looked at it. I couldn't walk away fast enough. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Well its doing kinda good now lol Destroyed how so? and yeah same weber carb, So a new one is in order or?? Quote Link to comment
bananahamuck Posted August 9, 2012 Report Share Posted August 9, 2012 See now if you guys had a Tri-cities meet and greet like you were threatening to do,,, this would have all been hammered out already... just sayin :) Quote Link to comment
