Willdatsun Posted July 16, 2012 Report Share Posted July 16, 2012 Wondered about what engines people have managed to put into 620s, I'm thinking of doing something with one at some point. I have put VG30s into a couple of large easy vehicles but whats it like putting one in a 620? NA or TUrbo? Would a pathfinder plenum have to be used for example? CUstom extractors? Custom built sump? Wiring and plumbing I am OK with. THanks! Quote Link to comment
Digi7al Trauma Posted July 16, 2012 Report Share Posted July 16, 2012 A Lamborghini v12 it technically possible.... just depends on your skills and how much you want to spend. But from what i remember the pathfinder plenum, i thing the pathfinder oilpan works with just bumping it in a bit... i remember the mounts were completely custom. I remember it was really tight, and it was only a n/a block... the headers were the most modified pieces of the install... I honestly cannot tell you from experience... i will try and find the thread and post it here 2 Quote Link to comment
Zeusimo Posted July 16, 2012 Report Share Posted July 16, 2012 I Remeber There Was A Yellow One At Canby Quote Link to comment
]2eDeYe Posted July 16, 2012 Report Share Posted July 16, 2012 That was Yello620 at Canby. Was a lot of work and research from what I recall. Build thread: http://community.ratsun.net/topic/15744-620-vg-conversion/page__hl__%20yello620%20%20vg30 :) 1 Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 Most guys do not carefully select the best sump from among all the ones available. Probably there is a combo that fits relatively easy in a 620, but who knows? The engine bay is the right size. Quote Link to comment
Z chopper Posted July 16, 2012 Report Share Posted July 16, 2012 figure if a vg30 will fit into a 521, a 620 should be much easier Quote Link to comment
datzenmike Posted July 16, 2012 Report Share Posted July 16, 2012 The lack of strut towers on a 620 is offset by torsion bars and one piece steering column. Do-able and there is a frame and more ground clearance for the pan and the rear end will easily handle it. Quote Link to comment
thorpie Posted April 15, 2013 Report Share Posted April 15, 2013 I sure is possible. I used a vg30e from a 1984 300zx z31. I used a front sump from a nissan maxima and had to modify the starter motor. http://datsunminitruckin.com/vg30e-build-with-5-speed_topic2126.html Quote Link to comment
