81sunnyson Posted June 30, 2012 Report Share Posted June 30, 2012 what is the best way to get limited slip into an H165? not sure ration i have .....H165 with discs from 81200sx hatchback with napps z20 engine what size splines? has anybody ever tried a chevy ten bolt LSD from a vega or monza, 7.5" ring gear and 26 splines? weir performance has the toyota slippers but pricey is it possible to put a spool in? minispools are $90 bucks from Jegs.com Quote Link to comment
81sunnyson Posted June 30, 2012 Author Report Share Posted June 30, 2012 http://www.weirperformance.com/spoolslimitedslipunits.html these are the options Quote Link to comment
80datson Posted June 30, 2012 Report Share Posted June 30, 2012 You just answers yrr own question.. Quote Link to comment
80datson Posted June 30, 2012 Report Share Posted June 30, 2012 Weld that bitch up what do You need a LSD for? Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 If you have never been to this sight... you should have. http://datsun1200.com/modules/mediawiki/index.php?title=LSD Quote Link to comment
81sunnyson Posted July 1, 2012 Author Report Share Posted July 1, 2012 tried to email pitroad but with translater in browser no response yet they are running what they call "custom"Ae86 LSD....the splines must be larger what size splines in the H165? has anybody ever tried a chevy ten bolt LSD from a vega or monza, 7.5" ring gear and 26 splines? http://www.weirperformance.com/spoolslimitedslipunits.html what about these? Quote Link to comment
80datson Posted July 1, 2012 Report Share Posted July 1, 2012 Dude stop posting the same shit its annoying. Why do Yu need an LSD? WELD THAT BITCH UP! Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 Limit your LSD search to this thread from now on this one is closed http://community.rat...-for-h165spool/ Only way a "chevy ten bolt LSD from a vega or monza" will work is if you swap the complete axle assembly. To do this your driveshaft must bolt up and be the right length (or shortened/lengthened), the axle must be a similar width to fit under your 210 so the tires don't stick out, your 4 link must match up or be made to fit the 210 and hopefully your rim bolt pattern is the same. The '80-'81 200sx H-165 has a 3.70 differential ratio for auto and standards. They are also 23 spline count, as near as I can see in the dark.. Quote Link to comment
ggzilla Posted July 1, 2012 Report Share Posted July 1, 2012 ibtl I tired a monza 10-bolt once but it wouldn't slip Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 Do A series need LSDs? Or just nice to have? If the later put it lower on your list as there are lots more important things. Quote Link to comment
81sunnyson Posted July 1, 2012 Author Report Share Posted July 1, 2012 http://www.speedwaymotors.com/9-Inch-Ford-Alternator-Drive-System,27898.html this would be cool to have to power stereo or air ride or hydraulics Quote Link to comment
81sunnyson Posted July 1, 2012 Author Report Share Posted July 1, 2012 if i plan on making over 150hp....insurance and dont you guys discourage welding diffs cuz they would eventually snap? gotta check with peter zekert and get his opinion Quote Link to comment
81sunnyson Posted July 1, 2012 Author Report Share Posted July 1, 2012 here's another option http://www.nolimitmotorsport.com/prod/QDF6L says these fit Nissan 200SX SER (USA only) / Nissan Primera SR20DE, Sentra SER, NX2000, 200SX SER, Infiniti G20 but again over a grand Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 what size splines in the H165? has anybody ever tried a chevy ten bolt LSD from a vega or monza, 7.5" ring gear and 26 splines? Post #8 http://www.speedwaym...stem,27898.html this would be cool to have to power stereo or air ride or hydraulics Only 50 amp output and only works when moving. This is worse than useless.... Quote Link to comment
INDY510 Posted July 1, 2012 Report Share Posted July 1, 2012 and dont you guys discourage welding diffs cuz they would eventually snap? Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 here's another option http://www.nolimitmo....com/prod/QDF6L says these fit Nissan 200SX SER (USA only) / Nissan Primera SR20DE, Sentra SER, NX2000, 200SX SER, Infiniti G20 but again over a grand That's for a FWD front wheel drive Sentra car. Quote Link to comment
DRIVEN Posted July 1, 2012 Report Share Posted July 1, 2012 What's your fixation with the GM 7.5? Even the GM guys think they suck. I have one...in a Cutlass - it's a C-clip setup. The Quaife you linked is for a FWD transaxle. The alternator is for a racecar and would barely power a set of halogen headlight + points ignition. DMike, is this dude for real? I love jokes but now I just want punch something. Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 and dont you guys discourage welding diffs cuz they would eventually snap? Won't snap if welded right... will kill you first. Quote Link to comment
Laecaon Posted July 1, 2012 Report Share Posted July 1, 2012 Yea, now its just clutter on the forum. Is this a second account? Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 DMike, is this dude for real? I love jokes but now I just want punch something. I'll check if it's HRH.... Quote Link to comment
DRIVEN Posted July 1, 2012 Report Share Posted July 1, 2012 If it's HRH, he gets a high five. If not, I may have found my new "special project". O'doyle rules! Quote Link to comment
ggzilla Posted July 1, 2012 Report Share Posted July 1, 2012 81sunnyson, do you have a FWD datson? If your A-series engine makes 150 HP, then you have even less need of an LSD than a stocker. 150 HP is made at very high RPM. Of course, any LSD is cooler than no LSD. But then an air locker differential would be cool, but you only have 50A alternator. But you could use rear disc brakes and it would stop faster. If you use a spool then you have to wait for it, but if you use a a Lincoln it's done right away. What size tires are you using? I favor very low profile for max performance, but most guys nowadays favor very large rims for looks. Quote Link to comment
Laecaon Posted July 1, 2012 Report Share Posted July 1, 2012 Some quick snooping. His profile has an email of "thejoel_hunter@hotmail.com" Type "joel hunter datsun" into google and find other posts. Like this one from april 19th. http://japanesenostalgiccar.com/2012/04/17/turn-your-datsun-into-a-champion-with-the-210zx/ or this: http://rides.carcraft.com/ride/1209544/joel-hunter81datsun/1980/datsun/b210/index.html Quote Link to comment
DRIVEN Posted July 1, 2012 Report Share Posted July 1, 2012 "hopefully 100mph 1/4 in the ten's" --Priceless :rofl: Please, for the sake of the children, let this be a sick hoax. Quote Link to comment
