Project: Skunk Works II
  • Replies 94
wow!!
Car went to AZ?
Previous owner traded 1992 Sentra SE-R for that 510
It has a good motor.
I still have the Mikuni carbs for it
Ran strong when I had it.
Yup i totally owen the black 4 door now wow and its black again... And Congrats on the wagon looks in good shape
If anyone is interested on 68 dash, I will be installing a cleaner dash in about 3-4 weeks.
This one is actually still in good shape.
Will take more pics of it once removed.
Send me PM if you want it.
Question to all Ratsun 68 Fiveten expert.
Is the column shift transmission only made by Jatco or Borg Warner also made them for this car?
Hood and hood hinge different from other years?
Antenna, did they came with non retractable antenna?
thanks in advance
Thanks for info
Had a bad experience on my last BW transmission.
It was shifting ok and decided to remove filter and replace with new fluid.
And after that, transmission won't shift at all to any gear.
Is it possible that filter could be the issue?
Holding off on servicing this one.
The 68 is a Borg Warner. They didn't transition to JATCOs until like June '70.
  • 1 month later...
I've got a good REBUILDABLE used valve if you need one, but regardless, you should order a NEW 620 Pickup valve (still available from Nissan), and use the guts to rebuild whatever used one you get your hands on.
Thanks
I think this should work.
Ordering soon if still available
  • 4 weeks later...
