sedition88 Posted March 20, 2012 Report Share Posted March 20, 2012 So tomorrow I'll be doing my head gasket on my L18. I already have the head gasket kit, spark plugs, and oil. What else do you guys think I need and what should I look for? Any tips and tricks would be very helpful. Thanks!! Quote Link to comment
ZackTheImpaler Posted March 20, 2012 Report Share Posted March 20, 2012 Location SLUT? Haha. Have you ever changed a head gasket before? Helps to know where you are at before throwing out advice Quote Link to comment
bananahamuck Posted March 20, 2012 Report Share Posted March 20, 2012 Click the link ...it shows tension retainer you need to hold chain tight .. Link also shows dimensions so you can make one yourself. http://community.rat...-swap-write-up/ 1 Quote Link to comment
sedition88 Posted March 20, 2012 Author Report Share Posted March 20, 2012 Location SLUT? Haha. Have you ever changed a head gasket before? Helps to know where you are at before throwing out advice Yep SL,UT. It's like a local joke, it stands for Salt Lake cityUTah I have not changed one before, no. I will be getting help from a couple local Ratsuners however, so I wont be doing it alone at least. Bananahamuck: Thanks for the link, I'll go through it for sure Quote Link to comment
ZackTheImpaler Posted March 20, 2012 Report Share Posted March 20, 2012 I figured salt lake. That's a good one. Take lots of pics, make sure your gasket is on straight before torquing the head on, and for the love of all that is holy don't drop the chain. Quote Link to comment
sedition88 Posted March 20, 2012 Author Report Share Posted March 20, 2012 and for the love of all that is holy don't drop the chain. Just like not dropping the soap? It's a real pain in the ass, but you've learned your lesson for next time? I'll be sure you remember that. Wish me luck! Quote Link to comment
banzai510(hainz) Posted March 20, 2012 Report Share Posted March 20, 2012 Persoanlly I would break the crank bolt loose also when taking the head chain off, incase you drop the chain later. But amazon does have those timming chain wedges for sale for 10$ also when putting the chain back on you can slightly move the came left of right to get slack tp pull the chain up to get on the cam dowell. PS mark the chain before removing it on the timming mark #1 2 or 3. ink pen or whiteout. remove the fuel pump! 1 Quote Link to comment
datzenmike Posted March 20, 2012 Report Share Posted March 20, 2012 Mark timing chain and scam sprocket relationship so it goes back the same way. This is also a good time to check for timing chain stretch and make adjustments when putting the sprocket back on. Disconnect the down pipe and carb linkages and hoses and lift the head off with both manifolds and carb on it. This saves so much time and lessens the chance of braking manifold bolts and having a leaking intake/exhaust leak. Keep the head level and tip up just enough to wire wheel off the old gasket material. Be sure you find and keep the two alignment dowels that line the head up on the block. I don't think it matters but loosen the head bolts from the outside ends and working inward to the center. Fully loosen them and lift head off with the bolts. This way the washers don't fall into the motor (or gravel driveway) Don't forget the four 10mm bolts around the front timing cover. Set TDC so you only have to clean gasket out of two cylinders. Do NOT rotate the cam in the head if at all possible. If you do, be extra sure that you check/set the cam back to TDC before installing head. This will save you some bent valves. 1 Quote Link to comment
HRH Posted March 20, 2012 Report Share Posted March 20, 2012 I want one I don't want Datsun brought here! Don't want our Datsuns cheapened. Don't want to run into someone talking about his Datsun unless it's at least 30 years old. Don't want some tool coming up to me and saying "Hey you have a Datsun just like me!" Russia can have 'em. . Put a straight edge in an x across the length of the head measure for. 003" If you have more than this have the head clearanced. In fact its a good idea to do that anyway. Quote Link to comment
