TipTricky Posted March 13, 2012 Report Share Posted March 13, 2012 I have a 71 510 and want to make to rear axles bigger and was wondering if any one knew of a swap kit or and good ways of going about it Quote Link to comment
Eagle_Adam Posted March 13, 2012 Report Share Posted March 13, 2012 noobs must search :poke: Quote Link to comment
TipTricky Posted March 13, 2012 Author Report Share Posted March 13, 2012 I did search and didn't find anything if you could give a link that'd be nice. Quote Link to comment
I'm BLUE Posted March 13, 2012 Report Share Posted March 13, 2012 Not too many swap kits unfortunately ... If you can measure ... build jigs ... have common sense ... and weld ... you can put just about whatever the heck you want in there. This shoould get you started Very clean build... http://community.ratsun.net/topic/40836-ford-88-build/ Inquiries ... http://community.ratsun.net/topic/35978-ford-8-88-9-source/ Narrowing axle groupthink... http://community.ratsun.net/topic/40602-narrowing-an-axledifferential-service/page__st__20 The build i wanted to post cant find Atm, but wil try to ... guy put 8.8 4-link in his goon. Quote Link to comment
I'm BLUE Posted March 13, 2012 Report Share Posted March 13, 2012 Heres another thread to read ... http://community.ratsun.net/topic/16184-limited-slip-in-a-wagon/ Oh yeah by the way ... using search is way easier if you go to google first ... then type in ratsun before or after your keywords :) Quote Link to comment
TipTricky Posted March 13, 2012 Author Report Share Posted March 13, 2012 Oh ok cool. Thanks for the links. Quote Link to comment
I'm BLUE Posted March 13, 2012 Report Share Posted March 13, 2012 Oh ok cool. Thanks for the links. Yup! Go to "project datto" forum ... there was a member who'll 4-linked his 510 wagon ... did the 8.8 ... did a pretty good documentation of it to! ... i cant find Atm otherwords i would have posted haha. It should be in the recent 20-pages of projects i believe. Quote Link to comment
TipTricky Posted March 14, 2012 Author Report Share Posted March 14, 2012 Well just went through about 30 pages of forums and didn't see it but I learned some new things that will help Quote Link to comment
INDY510 Posted March 14, 2012 Report Share Posted March 14, 2012 . http://community.ratsun.net/topic/22822-4-linked-wagon/ ............. . hard to miss a thread titled "4 linked wagon" ...... bumped 3 days ago ..... :rolleyes: Quote Link to comment
jesusno2 Posted March 14, 2012 Report Share Posted March 14, 2012 I am working on toyota 8 inch diffs for wagons should be done with one soon. narrowed axles machined for 4x114.3 bolt pattern. stronger and cheaper than a bulky heavy 8.8 Quote Link to comment
TipTricky Posted March 14, 2012 Author Report Share Posted March 14, 2012 Haha Indy I read that don't know why I forgot. Thanks though. So to keep the independent rear I'm going to use a 87 to 76 chevy Corvette rear end thoughts? Quote Link to comment
INDY510 Posted March 14, 2012 Report Share Posted March 14, 2012 So to keep the independent rear I'm going to use a 87 to 76 chevy Corvette rear end thoughts? 1 Quote Link to comment
TipTricky Posted March 14, 2012 Author Report Share Posted March 14, 2012 ... Im going to take the IRS out of a corvette and use it in my datsun. Quote Link to comment
datzenmike Posted March 14, 2012 Report Share Posted March 14, 2012 m-m-m-m I don't know. Lots of custom work and welding and not much, actually no gain. Just get some 510 axles that fit. Quote Link to comment
INDY510 Posted March 14, 2012 Report Share Posted March 14, 2012 . If you cut out everything you need to cut, in-order to fit the 2 foot wider rear suspension,, you will no longer have a 510 ... <_< there is nothing holding these cars together except the floors, and a few sheet metal braces.. ... cut that out,,, and you could fold the car in half with your hands Quote Link to comment
TipTricky Posted March 15, 2012 Author Report Share Posted March 15, 2012 I have strengthened the whole frame added a roll cage and everything i need a rear end thats independent and holds up against some power Quote Link to comment
Boaty Posted March 15, 2012 Report Share Posted March 15, 2012 I know somebody running just shy of 400whp with a bone stock set of axles, he hasn't even had any problems with U-joints. I'm dying to know what "against some power" means. Not a SBC... tell me it's not a SBC! You can run the stock rear suspension without any problems. People have been doing it for 40 years including pure-bred race vehicles. R180 and R200 differentials are easily obtained, but take a bit of work. If you've caged and reinforced everything yourself I'm sure modifying the crossmember and fabbing up a mustache bar for the larger differential wouldn't be that big of a project for you. Depending on how low you plan on keeping the vehicle, you may have to invest in some camber/toe adjusters for the rear crossmember. Some are sold from FutoFab (same kit available from Byron Meston up in British Columbia, believe the same price as well). There is also the Datsport kit, but you're looking at money for a pre-fabbed piece + freight from Australia. They sell a DIY kit as well if you're handy with a welder and feel comfortable doing it. FutoFab (Dave Patten) http://www.futofab.com/index.php?option=com_content&view=category&layout=blog&id=22&Itemid=22 Datsport (in Australia) http://www.datsport.com/suspension-rear-pricelist.html Wolf Creek Racing sells a set of CV axles that bolt into a stock 510 rear suspension. http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=72&Itemid=61 They are spendy. But I have not found a single person have a single complaint about them - they are a very well built part. Believe they use Porsche axles. Consider WCR's kit to be the top dollar big-dawg axle kit you're ever going to find. There are several alternatives, such as custom adapters and modified VW axles, which work but aren't as beefy as the Porsche axles. If and when I'm able to purchase a set, I won't hesitate or think twice about the investment (even though I wish it was more reasonably priced!) All it takes is money. Quote Link to comment
TipTricky Posted March 15, 2012 Author Report Share Posted March 15, 2012 One reason i was going to do the corvette rear end is because i have most if not all of the IRS from a corvette. I have a second diff in the garage not sure what it is exactly but i took everything out of the back of the car today and thought about some things along with what you said makes since to stay stalk i need some refresher parts though the axles seem a bit worn and 400whp is about what ill be making. Thanks for the tips and info im new to the 510 seen but im learning these cars can take a lot of abuse. oh and any clue what this diff is i have not looked it up yet. Number on it is: 214 38311 78600 Quote Link to comment
