KA trans to L20B ?
I saw some discussion on this a while back, but can't seem to find any usable information.
What is required to mount a KA to a L20B? I know it's about 34'' long vs 26 inches, but what do I need to look into other then driveshaft length?
  • Replies 14
Your shifter is gonna be so far back.
Isnt it also going to be crooked, like to the right. I thought they were like Z motors.
And shifter far back? Same spot as if you swapped in the KA with the tranny...
I was hoping someone would say "put on an L series front cover" and it would fit perfect lol.
KA 5 speeds are like crack down here. People throw them away for scrap. L series 5 speeds on the other hand...
Bellhousing would have to be swapped, because of the angle the engine sits, like laecaon mentioned. This would include the nap-z motor trannies as well I believe. The KA tranny has a different mounting for the driveshaft as well, but if your already shortening a driveshaft, you can get a custom end put on. Another thing I can think of is whether the T/O bearing, flexplate, etc. would be interchangeable, I would guess not.
Look it up on hybridz, you'll need a Z 4 speed bellhousing get it machined a bit and your good to go. you might need to change the clutch disc but I can't remember for sure. The KA 5 speeds are nice trannies and a short shifter would be easier to come by and be cheaper then one for a Z tranny.
The 62mm KA counter shaft bearing would need to be removed and a 56mm 620 or 280z/zx bearing substituted that will fit the hole in the 620/280 case... or bore the case out to fit the KA bearing. If boring the case the KA cover plate must be used, if not the 620/280z cover is fine. On the inside, the case needs to be machined to clear the wider KA front counter gear. The 1st/2nd shift rod hole needs to be drilled out to 16mm from 14mm. Lot of work but really good tranny.
Look for a 5 speed if possible. Some 4 speeds have the reverse light switch in a different position then the 5 speed. Here the 4 speed switch hole has been filled and the switch moved abut an inch forward. This can be avoided with a proper 5 speed case.
I think the early D21 Hardbody 71C is quite close to the 71B. The S12 200sx and later 240sx 71C are much longer. I haven't had the pleasure of measuring either (and everyone measures them differently) additionally, they often have a metal dust shield on the back. Some include this others do not.
Totally forgot I didn't reply to this thread.
What about a 720 tranny?
http://community.rat...eed-for-a-l20b/
***Wait. You have a long one stock, right?
You rock flatcat! That actually seems like a pretty feasible idea.
All I know is that my trans measures about 26''
Well, yes, after you bore out the shaft bosses for the larger bushings/bearings/etc. It's not a direct swap.
Sucks to hear that.
I was looking more for simplicity here, since L series 5 speeds are worth their weight in gold down here (practically) I'm looking for other possible solutions. I will at the moment keep looking for L series transmissions, however the amount of info in this thread is phenomenal. I'm bookmarking this because I may be back to do this change over one day.
