reddituser Posted February 13, 2012 Report Share Posted February 13, 2012 I have a 1967 1600 with an L18 swap. My son took it upon himself to remove the cylinder head without setting the first cylinder to TDC, and without blocking the timing chain, so it now will not clear the cam (I was thinking if we got it back on just the way it came off it would be ok, maybe still a possibility). So now I need to remove the front cover to get the timing chain hooked up again. I have been watching this video series: but he starts from the beginning with the entire engine in TDC on no 1 hole. Does anyone have any resources for someone looking to reassemble an engine without being in TDC? Not sure how to proceed from here. Any advice would be appreciated. Thanks! Quote Link to comment
ggzilla Posted February 13, 2012 Report Share Posted February 13, 2012 If the timing chain hasn't dropped, you can still get it going. Just pull the chain tight (so it won't drop) and turn the crank pulley to TDC. Quote Link to comment
Guest 510kamikazifreak Posted February 13, 2012 Report Share Posted February 13, 2012 Your going to have to pull the t-cover off,no way around it the tensioner has popped out(spring loaded). Quote Link to comment
reddituser Posted February 13, 2012 Author Report Share Posted February 13, 2012 The timing chain did drop enough to get hooked up on the tensioner, and the cam sprocket was removed and the paint he marked the chain and sprocket with aren't very clear. Is there a way to "reset" everything using factory marks? Quote Link to comment
ggzilla Posted February 13, 2012 Report Share Posted February 13, 2012 Yes, after you pull the timing cover, you can reset everything. Timing marks on the chain don't matter, the relationship between the two shafts are what matter. Quote Link to comment
reddituser Posted February 13, 2012 Author Report Share Posted February 13, 2012 Can I remove the front cover, reposition the tensioner, and put everything back together, then rotate the engine by hand to TDC to verify the timing marks on the cam and sprocket line up? Quote Link to comment
ggzilla Posted February 13, 2012 Report Share Posted February 13, 2012 Yes. Do it just like in the video. Quote Link to comment
Guest 510kamikazifreak Posted February 13, 2012 Report Share Posted February 13, 2012 get #1 piston to tdc. from there its 42 links on the chain to get the correct timing marks(o)on cam do you have a manual? Quote Link to comment
reddituser Posted February 13, 2012 Author Report Share Posted February 13, 2012 No manual. 42 links from the indent on the lower sprocket, then I need to rotate the cam so the no 2 mark meets that link (42 up from the indent), putting the head in TDC. Am I interpreting that correctly? Quote Link to comment
Guest 510kamikazifreak Posted February 13, 2012 Report Share Posted February 13, 2012 No manual. 42 links from the indent on the lower sprocket, then I need to rotate the cam so the no 2 mark meets that link (42 up from the indent), putting the head in TDC. Am I interpreting that correctly? yup thats it,and on the rear of the cam gear there is a v notch,and on the thrust plate the is a (- ) the V should be centered to the (-) Edit* only thing I could find in a quick search. Quote Link to comment
Laecaon Posted February 13, 2012 Report Share Posted February 13, 2012 I set my block to TDC by having the key of the crank point at 12 o'clock on the block (make sure piston 1 is at the top). This is with the cover off. Set the front 2 lobes of the cam to 10&2. Place head on block. Attach chain, making sure to either follow gold links or the number of links. Add the tensioner. To get the cover back onto the motor now, you will need to slightly drop the front of the oil pan, or risk damaging the gaskets. It is wise to add a dab of RTV in the corners of the timing cover where it meets the block and oilpan/head Quote Link to comment
DanielC Posted February 13, 2012 Report Share Posted February 13, 2012 You have got to get the engine to TDC. I am not sure if you can turn the crankshaft fully through 360 degrees without turning the camshaft, I think that if a valve is fully open, it is possible a piston may hit the valve, and bend the valve stem. let me define "straight up" for the camshaft and crankshaft keys for the next part of this information. Ignore the fact that the L-engine is tilted when in the vehicle. "Straight up" has the crankshaft key exactly in line with center of the camshaft, and if you continue this line beyond the center of the canshaft, the line will go through the center of the dowel pin in the camshaft. both the crankshaft key up, and camshaft dowel up. Number 1 TDC, firing stroke. The crankshaft key points straight up at TDC. TDC for #1, and #4 occur together, it is not until the camshaft, and cam chain are installed that #1 TDC becomes #1 TDC. With the camshaft in the head, #1 TDC happens when the dowel on the front of the camshaft is straight up. with both crankshaft, and camshaft in the engine at #1 TDC, the marks on the crankshaft and camshaft sprocket have 42 links on the timing chain between them. With the engine at TDC #1, you should be able to look through the camshaft sprocket, and see the slot in the camshaft thrust plate line up with the notch on the back of the camshaft sprocket. Before putting the front cover on the engine, after putting the timing chain on, with the spark plugs out of the engine, try to turn the engine by hand two complete revolutions, to make sure the engine does not bind up. It the camshaft is in wrong, the engine may stop near TDC, and near BDC if the engine stops, do not force it past the point it binds up. Find out why it stopped. Quote Link to comment
Guest 510kamikazifreak Posted February 13, 2012 Report Share Posted February 13, 2012 took a couple pics of one of my new t-chain sets crank gear(o) cam gear cam gear v notch tensioner Quote Link to comment
EricJB Posted February 13, 2012 Report Share Posted February 13, 2012 Put the tensioner back together and put a zip tie on it. That way you aren't fighting it while trying to line things up. Once it's together, cut the zip tie and pull it out. TDC #1 is the same crankshaft position as TDC#4. Make sure your at TDC#1 by pulling the dist cap and making sure the rotor is pointing at the #1 wire. At this point the cam lobe's for #1 should be close to 10:00 and 2:00. GENTLY rotate the motor by hand. Dont hit the key to see if you did it right. Good luck. P.S. man you guys type fast. Quote Link to comment
reddituser Posted February 13, 2012 Author Report Share Posted February 13, 2012 You are all so wonderful, this is all so very helpful. If I can manage to get the front cover off without killing myself, I think I may have a shot at getting this done without paying through the nose. Any additional info or phtos will be appreciated, but I believe I may have enough to complete. Quote Link to comment
Laecaon Posted February 13, 2012 Report Share Posted February 13, 2012 Cam at TDC: Sorry, no pics of the block at TDC... Quote Link to comment
Guest 510kamikazifreak Posted February 13, 2012 Report Share Posted February 13, 2012 You are all so wonderful, this is all so very helpful. If I can manage to get the front cover off without killing myself, I think I may have a shot at getting this done without paying through the nose. Any additional info or phtos will be appreciated, but I believe I may have enough to complete. When pulling the t-cover drop the oil pump first,there is a 10mm bolt that some people tend to not see,thus ending up cracking the t-cover. Quote Link to comment
Laecaon Posted February 13, 2012 Report Share Posted February 13, 2012 I also recommend when taking the bolts out, place them in order. As there are different lengths and diameters. Also there is a bolt or 2 that go through the waterpump that need to be removed. Just hope those are not rusted... Quote Link to comment
reddituser Posted February 13, 2012 Author Report Share Posted February 13, 2012 Sorry, no pics of the block at TDC... I believe you just find the point at which the No1 cylinder turns around. Anyone have input on this? Quote Link to comment
banzai510(hainz) Posted February 14, 2012 Report Share Posted February 14, 2012 I guess I could have made the vedio EZer to understand put head on at TDC. To do this when it might not be at TDc youll have to move the cam. this will be hard since it not on a engine block as the valave springs are giivng resisitance. What I would do is put the motor block so piston are half way down. Put head on block and put 2 head bolts to hold it and turn the cam with a wrench or However you want. Done Take head off Put block to TDC. You can gently put the timming cover back on to find the TDC mark on crank and front cover. If you dont have the brite links on chain put the chain on tight as you can then rotate counter clock wise on crank then turn clock wise to Zero on crank . If cam mark line up to that V notch its timmed if you have a new chain is pretty much self evident on how to line it up. If you have a stock L20 the factory put it at 2 on sprocket. If you have a l16/18 you can put to #1 or 2 if you like. Quote Link to comment
