Help! Truck Won't Idle
Zeusimo
  • Replies 22
We had a similar problem since we replaced our alternator with a larger one, not made for the car.
Since it was for a different model, the leads had to be modified a little, since the alternator wasn't charging the battery.
So just check all of the wires the run from the alternator, with a meter.
Edit: just checked my alt and remembered our problem; the jumper we put in to override the volt reg. was wrong. Sorry I'm of no help. mellow.gif
Autozone.. And Tested A Good 15V
I Would Check ALL The Wires But I Don't Have A Meter... I Might Have To Buy One
Currently Charging Battery Cuz It Was 1/2 Full
I Also Found That I Blew A 10A Fuse...
I Don't Know What It's For But I'll Pick One Up On My Way To School
Maybe All Of This Rain Messed Something Up...
Truck Starts Fine...
Just Replaced Alternator..
Charge Light Stays On...
Have To Keep My Foot On The Gas For It To Run
I Have No Clue What's Wrong, It Was Fine Yesterday
I Don't Have A DMM :(
It's likely the 'C' terminal fuse to your idle cut solenoid and choke heater (it goes to other places too but if the idle cut isn't working it ..... won't idle)
Fixed :)
That Little Box Near The Horn That Holds
The Choke And Idle Connections Simply Loosened Itself,
Therefore No Ground...
Edit:
Delete Post, Thread, Forum?...
I'm So Stupid Sometimes
Like Getting Up To Grab A Spoon
But You Wonder Off To The Fridge
And Look Around Until Your Mind Notices...
WTF Am I Doing?
You Were Gonna Get A Spoon <_<
