AZhitman Posted January 20, 2012 Report Share Posted January 20, 2012 Confirmed the 3.7 ratio, confirmed it's LSD, but I'm not positive on the rest. Thanks guys! Quote Link to comment
thisismatt Posted January 20, 2012 Report Share Posted January 20, 2012 R180. Not likely to be an LSD - what makes you say it is? Quote Link to comment
Ranman72 Posted January 20, 2012 Report Share Posted January 20, 2012 need pics of the depth of the pop out on the diff cover Quote Link to comment
thisismatt Posted January 20, 2012 Report Share Posted January 20, 2012 It's an R180 for sure. You can tell by the spacing between the top two cover bolts and the cover itself on the R180 has a solid flat area where the mustache bolts are, rather than two flat spots on the R160. Quote Link to comment
datzenmike Posted January 20, 2012 Report Share Posted January 20, 2012 38311 is an R-180 housing. Can't make out the other numbers but if U3000 its from a 280z or 280zx (came in 3.364 and 3.545 ratios only) 810 (came in 3.70 ratio only) Quote Link to comment
AZhitman Posted January 20, 2012 Author Report Share Posted January 20, 2012 R180. Not likely to be an LSD - what makes you say it is? Because I laid hands on it - it's not an open diff. Quote Link to comment
AZhitman Posted January 20, 2012 Author Report Share Posted January 20, 2012 38311 is an R-180 housing. Can't make out the other numbers but if U3000 its from a 280z or 280zx (came in 3.364 and 3.545 ratios only) 810 (came in 3.70 ratio only) The other # is indeed U3000. This diff was in a stash of parts from a long-closed race shop that built 510's. From what I'm reading, the 810 didn't come with LSD, except maybe the U12 version in other markets, which leads me to believe it's been opened up and swapped internally (?). Alternatively, according to this site: http://www.classiczcars.com/forums/archive/index.php/t-1568.html "Maxima, Z, 810 and the 720 4X4 all used the same casting number on the diff housing which indicates the larger 115mm ring gear." I guess it wouldn't surprise me if they used a late-70's Z carrier and put an LSD in it for the track cars... Quote Link to comment
datzenmike Posted January 20, 2012 Report Share Posted January 20, 2012 Try twisting the axles in opposite directions. Pull the cover off. Could be welded. The K is on later R-180 diff cases, seen them on 720s, not sure when they changed. Quote Link to comment
AZhitman Posted January 20, 2012 Author Report Share Posted January 20, 2012 Try twisting the axles in opposite directions. Pull the cover off. Could be welded.. Ah, that could be - They won't turn opposite (at least with the small amount of torque I'm able to put on them). Quote Link to comment
thisismatt Posted January 20, 2012 Report Share Posted January 20, 2012 Because I laid hands on it - it's not an open diff. Yeah, I didn't say it was open, but R180 LSDs are exceedingly rare and it would be extremely odd to get one without being 100% sure of what you were buying in the first place. Quote Link to comment
datzenmike Posted January 20, 2012 Report Share Posted January 20, 2012 Ah, that could be - They won't turn opposite (at least with the small amount of torque I'm able to put on them). Could be welded. ...could be a true LSD also. Take cover off. The only way to be sure Quote Link to comment
AZhitman Posted January 21, 2012 Author Report Share Posted January 21, 2012 ...could be a true LSD also. Take cover off. The only way to be sure Roger that - Will check in with pics once I crack 'er open, Captain! Quote Link to comment
AZhitman Posted January 22, 2012 Author Report Share Posted January 22, 2012 Yep indeedy. It's a R180 with 3.70 gears and welded. I think I'll probably sell it, since I don't want to use a welded diff in my street car. Quote Link to comment
yellowdatsun Posted January 23, 2012 Report Share Posted January 23, 2012 Aww man, that sucks. Looks like neither of us should buy things that we aren't *100%* positive about. Dangit. Quote Link to comment
AZhitman Posted January 24, 2012 Author Report Share Posted January 24, 2012 Yep. Oh well. Someone might have a use for it (it'd be great in a drag / drift machine). Quote Link to comment
wanna 510 Posted February 1, 2012 Report Share Posted February 1, 2012 Yep. Oh well. Someone might have a use for it (it'd be great in a drag / drift machine). any idea on what car a r160 came out of. Quote Link to comment
datzenmike Posted February 1, 2012 Report Share Posted February 1, 2012 510 sedan but not the 510 wagon, the 610 sedan and hard tops but not the 610 wagon. Quote Link to comment
AZhitman Posted February 2, 2012 Author Report Share Posted February 2, 2012 This is an R180. It's also for sale, altho I'm pretty certain I'm not gonna try and ship it. :( Quote Link to comment
