allen dodson Posted April 7, 2008 Report Share Posted April 7, 2008 I can get one cheap but are they two long to fit in the 521 with the extra two cylinders? Quote Link to comment
Bleach Posted April 7, 2008 Report Share Posted April 7, 2008 they'll fit if you remove the radiator Quote Link to comment
gen4maxima536 Posted April 7, 2008 Report Share Posted April 7, 2008 and/or cut into the firewall Quote Link to comment
ggzilla Posted April 7, 2008 Report Share Posted April 7, 2008 Well, since a 260Z motor can fit into a Datsun 1200 sub-compact, it should fit even more easily into a larger 520/521 pickup. L26-power Datsun 1200 Quote Link to comment
Bleach Posted April 7, 2008 Report Share Posted April 7, 2008 L26 in that drag car? I thought for some reason it was the 2.8L from a 280ZX turbo. The six cylinder engine blocks are all the same length and height. So the L24, L26, L28 will take up the same space. Quote Link to comment
ggzilla Posted April 7, 2008 Report Share Posted April 7, 2008 Yes, it is L26. A turbo has been fitted, so a lot of people think it is a factory ZX engine. But it is L26 with (i think) mechanical fuel injection. 700hp is a mite more than the factory turbo engine output :-) Quote Link to comment
datzenmike Posted April 8, 2008 Report Share Posted April 8, 2008 Well, since a 260Z motor can fit into a Datsun 1200 sub-compact, it should fit even more easily into a larger 520/521 pickup. The 520/521 might by wider and without strut towers but if anything has just enough room front to back for a four. It's going to be crowded on the driver's side with a six cylinder: intakeexhaustturbomastercylinderonepiecesteeringcolumnsteeringboxtorsionbar in there. Quote Link to comment
]2eDeYe Posted April 8, 2008 Report Share Posted April 8, 2008 starting to looklikeatightfitin there :D Quote Link to comment
fisch Posted April 8, 2008 Report Share Posted April 8, 2008 I always figured if this was possible w/o MAJOR modification, it would be the most common swap done! Mmmmm a 6 in a 521 sounds sweet though!! Quote Link to comment
510six Posted April 8, 2008 Report Share Posted April 8, 2008 It is a major PITA putting a inline 6 into a 510, it involves cutting and reforming the firewall and transmission tunnel. Fitting a 6 cyl into a 1200 would require the same modifications, still a PITA. It would be easier and cheaper in the long run fitting a V6. My old small turbo big shot of N20 setup New, large turbo small shot of N20 Quote Link to comment
