jbirds510 Posted December 20, 2011 Report Share Posted December 20, 2011 can someone who is computer smart wip me up a modified 510 diagram to include a matchbox and zx coil and remove unneeded wiring and ballast from it? I had one 15 years ago but i gave it away..thats life. Quote Link to comment
ggzilla Posted December 20, 2011 Report Share Posted December 20, 2011 It's no difference except the resistor is removed and the three wires of the resistor are spliced together. Quote Link to comment
Laecaon Posted December 20, 2011 Report Share Posted December 20, 2011 If it was originally dual point, there are a lot of wires you can get rid of. I mean, I am running single points and I got rid of a lot of wires. But you dont need to get rid of it to run. As for making a diagram, well one day soon I would like to make my own full diagram for my car, but I need to find some decent software. If you are just looking how to wire it up, check the how to section. a few examples there. Quote Link to comment
jbirds510 Posted December 20, 2011 Author Report Share Posted December 20, 2011 yep dual point.thanks man..ill look over there. Quote Link to comment
yello620 Posted December 20, 2011 Report Share Posted December 20, 2011 Laecaon, could you draw it in Autocad? Quote Link to comment
Laecaon Posted December 20, 2011 Report Share Posted December 20, 2011 Dont have a lot of experience with CAD software, but I could learn quickly... I have been trying to figure it out, and it seems to be impossible to find anything that will do striped wires in color, or color at all. Autocad seems like it should work, but everyone says it is overkill and just use Microsoft Vizio. But pretty much to do what I want I would save the diagram in a large format, and then open it in photoshop or illustrator to add color and stripes. Quote Link to comment
Laecaon Posted December 20, 2011 Report Share Posted December 20, 2011 And if I ever found an effective way to make wiring diagrams, I have a feeling I would make a ton for all sorts of applications... Quote Link to comment
DanielC Posted December 20, 2011 Report Share Posted December 20, 2011 Battery power goes to the positive side of the coil, and the "B" connection on the matchbox. ("B" for Battery). The negative side of the coil goes to the "C" connection on the matchbox. ("C" for coil.) Hook up the ground connection on the matchbox distributer to the head. I used one of the small 6 MM bolts on the front, that go to the front cover. Distributer wires. Coil wires. I am using a stock "ballast resistor" coil I left my ballast resistor in the circuit. This is a 521, not a 510. This part of the electrical is the same. Quote Link to comment
Laecaon Posted December 20, 2011 Report Share Posted December 20, 2011 Technically not Battery power, but Ignition power... And it connects to the positive of the coil, which is where Black/white and Black/blue attach to as well since you are running a EI coil. (neither are battery power). Quote Link to comment
Laecaon Posted December 20, 2011 Report Share Posted December 20, 2011 What car is that for? I mean, which car uses those colors on the wires? Quote Link to comment
banzai510(hainz) Posted December 20, 2011 Report Share Posted December 20, 2011 isnt this in the "HOW TO" section Quote Link to comment
ggzilla Posted December 21, 2011 Report Share Posted December 21, 2011 Most Datsuns -- even the dual-points (emissions points) -- have a BW wire for 'IGN', BR wire for 'Start', and B wire from Resistor to the Coil + terminal. Such as Datsun 620, Datsun B110, and Datsun B210. Single-point Datsun 510 I think has BL "Start" wire and later 510 has a BG wire for 'Start'. To confirm, disconnect both and measure which one is hot with IGN on. The colors can vary from year to year and occasionally do not match the Datsun factory wiring diagram. The BW and L wires come with the Matchbox distributor -- if you cut them out of the harness along with the T-connector. Quote Link to comment
