Z chopper Posted December 16, 2011 Report Share Posted December 16, 2011 I got this dizzy in the mail and noticed the little brittle plastic piece broke in shipping now I need to see if I can get the plastic piece, here are the oics so you know what the hell I am talking about. Link to comment
DREWSDIME Posted December 16, 2011 Report Share Posted December 16, 2011 I have an extra piece from a parts distributor, let me dig it out . Link to comment
datzenmike Posted December 16, 2011 Report Share Posted December 16, 2011 The plastic ones are on the EI dizzys I think. Link to comment
Z chopper Posted December 16, 2011 Author Report Share Posted December 16, 2011 it is a ei dizzy Link to comment
Icoblue Posted December 17, 2011 Report Share Posted December 17, 2011 FWIW, I got a reman matchbox dizzy from rockauto and it came with the metal (spindle cover?). Anyway, I never had cause to remove it, but the fact that it's on there means they're probably interchangeable. Doesn't look any different than the plastic ones except, of course, more durable. Link to comment
Icoblue Posted December 17, 2011 Report Share Posted December 17, 2011 Oh, and FYI, that pin is a real bi*** to drive out of there. I broke one of my plastic ones trying to remove it. Also broke the pin punch. Link to comment
Guest 510kamikazifreak Posted December 17, 2011 Report Share Posted December 17, 2011 The plastic was put on, to make em not so noisy. Just like the gm plastic timing gears. :blink: :lol: Link to comment
Z chopper Posted December 17, 2011 Author Report Share Posted December 17, 2011 but still need to see if I can get the piece plastic or metal Link to comment
Guest 510kamikazifreak Posted December 17, 2011 Report Share Posted December 17, 2011 but still need to see if I can get the piece plastic or metal Ill check my parts in the next couple days Link to comment
Icoblue Posted December 17, 2011 Report Share Posted December 17, 2011 I meant to put that in my last post, sorry. I have an L16 points dizzy with the metal drive spindle sleeve. I can punch it out and send you that, or just send you the whole dizzy. If I punch it, it'll take longer because I'm in the middle of a move and don't know exactly where my punch set is at right now. Without that sleeve, the rest of the dizzy is just parts, anyway. Disclaimer, though: I BELIEVE that this spindle will work on the matchbox dizzy, but I've never tried it. They look the same, but the one on my matchbox may have been different in some way. Maybe someone else can answer for sure? Anyway, if I can still get the flat rate boxes at the post office, it's yours for $20 shipped. Link to comment
Guest 510kamikazifreak Posted December 17, 2011 Report Share Posted December 17, 2011 Disclaimer, though: I BELIEVE that this spindle will work on the matchbox dizzy, but I've never tried it. They look the same, but the one on my matchbox may have been different in some way. Maybe someone else can answer for sure? Anyway, if I can still get the flat rate boxes at the post office, it's yours for $20 shipped. I just cant remember if they are "clocked" right,or was it deck height :unsure: Link to comment
Icoblue Posted December 17, 2011 Report Share Posted December 17, 2011 Well, there's no "clocking" with the sleeve, because all it does is surround the drive spindle. And I don't think that dizzy height would be an issue because that is set by the dizzy pedestal. I think this sleeve only acts as a bushing surface for the drive spindle. even if it were a "clocking" piece, there's only one way to install it; the pin driven straight through the center. The only problem I could possibly foresee is if that pin hole were at a different height between the metal and plastic bushings. I highly doubt it. Z chopper, if you still have your points dizzy, why not punch the old spindle bushing out and use that one on your matchbox. Remember you'll also need a matchbox dizzy pedestal. That's where the clocking issue comes in. Link to comment
Guest 510kamikazifreak Posted December 17, 2011 Report Share Posted December 17, 2011 Well, there's no "clocking" with the sleeve, because all it does is surround the drive spindle. And I don't think that dizzy height would be an issue because that is set by the dizzy pedestal. I think this sleeve only acts as a bushing surface for the drive spindle. even if it were a "clocking" piece, there's only one way to install it; the pin driven straight through the center. The only problem I could possibly foresee is if that pin hole were at a different height between the metal and plastic bushings. I highly doubt it. Z chopper, if you still have your points dizzy, why not punch the old spindle bushing out and use that one on your matchbox. Remember you'll also need a matchbox dizzy pedestal. That's where the clocking issue comes in. But there is, a couple different L motors take the clock different.. Link to comment
Z chopper Posted December 17, 2011 Author Report Share Posted December 17, 2011 Z chopper, if you still have your points dizzy, why not punch the old spindle bushing out and use that one on your matchbox. Remember you'll also need a matchbox dizzy pedestal. That's where the clocking issue comes in. the L16 I got is basically a long block with no intake manifold, exhaust manifold, dizzy or valve cover Link to comment
Guest 510kamikazifreak Posted December 17, 2011 Report Share Posted December 17, 2011 the L16 I got is basically a long block with no intake manifold, exhaust manifold, dizzy or valve cover price was right tho :unsure: Link to comment
Icoblue Posted December 17, 2011 Report Share Posted December 17, 2011 Well, I have quite a few parts laying around, so if you need something else, let me know. That dizzy is yours if you want it. I think the post office is still open on Saturdays (at least until next month :blink: ). I also have a spare stock L18 intake/exhaust set sitting out there, but it's pretty heavy to ship... Link to comment
Z chopper Posted December 17, 2011 Author Report Share Posted December 17, 2011 price was right tho :unsure: damn straight it was considering what I plan on doing :devil: Link to comment
Z chopper Posted December 17, 2011 Author Report Share Posted December 17, 2011 Well, I have quite a few parts laying around, so if you need something else, let me know. That dizzy is yours if you want it. I think the post office is still open on Saturdays (at least until next month :blink: ). I also have a spare stock L18 intake/exhaust set sitting out there, but it's pretty heavy to ship... the dizzy would be cool post a pic if you can, I prefer not to get anything from cross border till after christmas shipping season, so the chances of getting lost in mail is reduced Link to comment
Icoblue Posted December 18, 2011 Report Share Posted December 18, 2011 Single point dizzy, everything works. Here's your steel bushing. Link to comment
KC Phirus Posted December 18, 2011 Report Share Posted December 18, 2011 The plastic was put on, to make em not so noisy. Just like the gm plastic timing gears. :blink: :lol: Don't forget the Ford 351w and v4 Epic mistakes. Link to comment
Z chopper Posted December 18, 2011 Author Report Share Posted December 18, 2011 Here's your steel bushing. I hope that is the the same inside diametre Link to comment
ggzilla Posted December 18, 2011 Report Share Posted December 18, 2011 Ford V4 with fibre timing gears ... was still a better idea than GM's plastic engine parts on a vibration-inherent V6. It's maybe not a bad idea in the Datsun. That plastic doesn't break in operation, does it? Only when you take the distributor out an drop it :-) Link to comment
Sealik Posted December 18, 2011 Report Share Posted December 18, 2011 The only problem I could possibly foresee is if that pin hole were at a different height between the metal and plastic bushings. I highly doubt it. The pin height is about .75mm lower on the plastic bushing. The metal bushing would work on the dizzy that had the plastic bushing... just drop the overall length by .75mm. No foreseen problemos. :D Could ship you a metal bushing....if you're in a bind. All my plastic bushings are somewhat attached to good... useable dizzys :D Link to comment
Z chopper Posted December 18, 2011 Author Report Share Posted December 18, 2011 well if the metal bushing will work and make my dizzy usable Link to comment
Sealik Posted December 19, 2011 Report Share Posted December 19, 2011 Actually...I may of spoke to soon. It looks like the tabs/tangs (for the OP spindle) in the plastic bushing dizzy are a little larger the other dizzy. Kind of hard to measure.....so...I'll try to find another NFG dizzy, and see if the metal bushing slides on. Link to comment
