Icoblue Posted December 19, 2011 Report Share Posted December 19, 2011 Well, I stand corrected. Wasn't expecting that. Thanks, Sealik, for the comparison photo between the two. Two things I notice here; one, the length from pin to bushing tip appears to be equal in the pic, it appears that the difference in length that Sealik noted is above the pinhole, and compensated for by the spacer above it. Therefore, the important dimension is the length from pin centerline to the bottom of the bushing. As long as those lengths are equal, you would not shorten the bushing. And two, are those pins different diameters, or is it just me? So long story short, measure pin centerline to bottom of bushing. It should be equal. Remove pins, take spacer from metal bushing and transfer onto EI dizzy, install bushing and pin. Link to comment
Z chopper Posted December 19, 2011 Author Report Share Posted December 19, 2011 here is the numbers on my dizzy if that helps D4K9-090405 22100N8502 Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 D4K is the hitachi matchbox distributors (including fours and sixes) D4K9-090405 is the Hitachi part number 22100-N8502 is the Nissan part number ... for 1980 200SX with Z20E engine The main difference between the different part numbers are the advance characteristics. They are slightly different every year, even between FED and CAL in the same year. The advance curves aren't very different, and they all are wrong for your engine (e.g. L20B curve is not optimum for L20B). Hence recurving even the stock distributor will pick up a few HP and a few MPG. Link to comment
Z chopper Posted December 19, 2011 Author Report Share Posted December 19, 2011 The main difference between the different part numbers are the advance characteristics. They are slightly different every year, even between FED and CAL in the same year. The advance curves aren't very different, and they all are wrong for your engine (e.g. L20B curve is not optimum for L20B). Hence recurving even the stock distributor will pick up a few HP and a few MPG. I only understood the part about more HP and more MPG. I am sure when I get to building the engine I'll be asking lots of newb like questions Link to comment
Z chopper Posted December 23, 2011 Author Report Share Posted December 23, 2011 D4K is the hitachi matchbox distributors (including fours and sixes) D4K9-090405 is the Hitachi part number 22100-N8502 is the Nissan part number ... for 1980 200SX with Z20E engine The main difference between the different part numbers are the advance characteristics. They are slightly different every year, even between FED and CAL in the same year. The advance curves aren't very different, and they all are wrong for your engine (e.g. L20B curve is not optimum for L20B). Hence recurving even the stock distributor will pick up a few HP and a few MPG. enlighten me on advanced curves and how to recurve a dizzy Link to comment
ggzilla Posted December 23, 2011 Report Share Posted December 23, 2011 We alll know that having more spark advance gives more power (up to a point). Well most distributors don't give the optimum advance. Because there is a tolerance in the parts they err on the side of caution (e.g. it might be right on, but on average it will be a ways off), and also because of emission profiles for anything after about 1968. With most engines, you can add more HP by having the distributor recurved than you can by changing the camshaft. Even if your peak timing (advance) is right on, you can add a bunch of part throttle performance. But not always. Just usually. This is a main reason why when new, some stock engines ran better than other identical ones. You take it to an distributor expert and they check it out and make changes as necessary. Or a dyno tuner will do it by direct measurements. Link to comment
Z chopper Posted December 23, 2011 Author Report Share Posted December 23, 2011 cool thnx Link to comment
dat521gatherer Posted December 26, 2011 Report Share Posted December 26, 2011 Not trying to tread jack here. How about just a part number for the plastic piece so I can try the dealer? I need one too. Let us know if the metal one works on it. Link to comment
Z chopper Posted December 26, 2011 Author Report Share Posted December 26, 2011 I am kinda curious about the part number just incase Link to comment
ggzilla Posted December 26, 2011 Report Share Posted December 26, 2011 22119-W0400 COLLAR COUPLING SET it was used by a bunch of different Datsuns and Nissan, both Matchbox and newer style EI distributors, both L-series and Z-series engines. Link to comment
Z chopper Posted December 26, 2011 Author Report Share Posted December 26, 2011 22119-W0400 COLLAR COUPLING SET it was used by a bunch of different Datsuns and Nissan, both Matchbox and newer style EI distributors, both L-series and Z-series engines. cool thnx Link to comment
jefe de jefes Posted December 29, 2011 Report Share Posted December 29, 2011 Not trying to tread jack here. How about just a part number for the plastic piece so I can try the dealer? I need one too. Let us know if the metal one works on it. The metal one will work. I have swapped around 4 of these in the past. I think I removed the little washer that sits between the dizzy and sleeve for a little more clearance. Link to comment
Z chopper Posted December 29, 2011 Author Report Share Posted December 29, 2011 The pin height is about .75mm lower on the plastic bushing. The metal bushing would work on the dizzy that had the plastic bushing... just drop the overall length by .75mm. No foreseen problemos. :D Could ship you a metal bushing....if you're in a bind. All my plastic bushings are somewhat attached to good... useable dizzys :D you got that metal bushing? Link to comment
DREWSDIME Posted December 29, 2011 Report Share Posted December 29, 2011 I have some spare dizzies for parts, I have one with thr metal and one with the plastic $10 each plus shipping Link to comment
Sealik Posted December 30, 2011 Report Share Posted December 30, 2011 you got that metal bushing? Earlier today....I pulled the metal bushing off 1 dizzy and fitted it to a dizzy that had the plastic bushing. It fits....as jefe de jefes stated. 10 bucks...... to cover shipping. Would be cheaper....but if a envelope is thicker than 3/4 inch (?) it's classified as a parcel.... Link to comment
Z chopper Posted December 30, 2011 Author Report Share Posted December 30, 2011 saweet I'll send pay pal tomorrow pm me your paypal Link to comment
ggzilla Posted December 30, 2011 Report Share Posted December 30, 2011 It'll fit in the $5 flat rate USPS box. Link to comment
Sealik Posted December 30, 2011 Report Share Posted December 30, 2011 It'll fit in the $5 flat rate USPS box. Canada Post.............no USPS flat rates. Link to comment
