moparvwfreak Posted April 2, 2008 Report Share Posted April 2, 2008 does anyone ahve the part # for this switch? both wires are gone off of it and i would liek to have everything connected. thanks guys! Quote Link to comment
motavated Posted April 2, 2008 Report Share Posted April 2, 2008 I bought one from dealer. Not cheap! I paid over 50$ for one.... Edit! You know what. I do have the part # and price. I have to look for it after work.... Quote Link to comment
ggzilla Posted April 3, 2008 Report Share Posted April 3, 2008 22120-U2001 ASSY-SWITCH,WATER TEMPERATURE From Mar 1973, Chassis PL620TU-253975 and up. Yes it is only $74.48 at your friendly Nissan Dealer. But costs less at unfriendly ones. Quote Link to comment
moparvwfreak Posted April 3, 2008 Author Report Share Posted April 3, 2008 22120-U2001 ASSY-SWITCH,WATER TEMPERATURE From Mar 1973, Chassis PL620TU-253975 and up. Yes it is only $74.48 at your friendly Nissan Dealer. But costs less at unfriendly ones. ok how much at an "unfriendly" dealer? and where??? as it sits i already have to replace a bunch of stuff and cant afford to drop $74 on a damn switch. Quote Link to comment
banzai510(hainz) Posted April 3, 2008 Report Share Posted April 3, 2008 http://www.nissanparts.cc/cart/?pn=22120-U2001 is it needed that bad? somebody should have a stack of them some where. I even might have one . Quote Link to comment
]2eDeYe Posted April 3, 2008 Report Share Posted April 3, 2008 Take a trip to pull-a-part. You should be able to pick up that switch and a radiator. Might take more than one trip for the radiator, if they don't have any 620's at the moment. You may be able to get that switch from other Nissans though. Quote Link to comment
Pacific coast Datsun Posted April 3, 2008 Report Share Posted April 3, 2008 2eDeYe;50368'']Take a trip to pull-a-part. You should be able to pick up that switch and a radiator. Might take more than one trip for the radiator, if they don't have any 620's at the moment. You may be able to get that switch from other Nissans though. exactly but at the yard put it in your pocket. One off a Early Z car may be the same. You could always go w/ an aftermarket temp. gauge that has the probe going into the radiator. Quote Link to comment
datsunaholic Posted April 3, 2008 Report Share Posted April 3, 2008 $75? Holy cr@p. It's just a switch. And it's just for the dual points. The temp gauge sender only has one wire, the switch has 2. Even the temp sender doesn't cost that much. Quote Link to comment
moparvwfreak Posted April 3, 2008 Author Report Share Posted April 3, 2008 of course. what else is new. so i might be able to get one off a different car? and its for the dual points??? so if i swapped to electronics i wouldn't even need it right??? might be cheaper to swap to EI and say F it. pull-a-part here i come! Quote Link to comment
