jdmdime Posted December 1, 2011 Author Report Share Posted December 1, 2011 All put back together Nearly done!! Quote Link to comment
jdmdime Posted December 1, 2011 Author Report Share Posted December 1, 2011 Front rear Whats I have to work with peek a boo!!! Back of the pan welded up. Still needs to be cleaned up though Front all cleaned up Quote Link to comment
mrbigtanker Posted December 1, 2011 Report Share Posted December 1, 2011 great work looks awesome.would look better in my 521 though. 1 Quote Link to comment
jdmdime Posted December 1, 2011 Author Report Share Posted December 1, 2011 Sump time! Sump is going to be interesting It looks like its going to have to be a bat wing pan Quote Link to comment
jdmdime Posted December 2, 2011 Author Report Share Posted December 2, 2011 things begining to take shape (front) things shaping up (rear) The only thing more impressive then this pans beauty is its complete and utter failure. Im calling this the mark 1 pan/prototype Quote Link to comment
jdmdime Posted December 2, 2011 Author Report Share Posted December 2, 2011 Took less then two minutes to plasma cut off the pan from the flange....... Afer it was apart i took the time to fill it with water, it holds eactly what the math said it would......4 quarts.... Aww look at this cute little oil pan flange the Deviant whipped up.........AGAIN........Mk2 oil pan coming soon.... Instant Mk2 oil pan just add weld..... Quote Link to comment
jdmdime Posted December 2, 2011 Author Report Share Posted December 2, 2011 Bead I give you the mk2 pan! see the diffrence? See those holes were supposed to be in the last pan.......I kinda welded it together before putting them in...........haha oops.... And this is what makes it all possible!! The cool part is the tubes are stainless so even though the insides cant be painted they will never rust! Quote Link to comment
Laecaon Posted December 2, 2011 Report Share Posted December 2, 2011 I think I would have added a bit of tilt to the pan, to help collect oil for oil changes. Other than that, I like this option over cutting the crossmember. Quote Link to comment
jdmdime Posted December 2, 2011 Author Report Share Posted December 2, 2011 A view from the inside of the tubes View of the inside, needs some welding but its nearing completion Quote Link to comment
jdmdime Posted December 2, 2011 Author Report Share Posted December 2, 2011 After adding the engine weight, the pan hit the x member :/. so the front needed some notching Quote Link to comment
Rustbucket Posted December 3, 2011 Report Share Posted December 3, 2011 That is the fucking craziest oil pan, haha! Awesome, dude. Quote Link to comment
fisch Posted December 3, 2011 Report Share Posted December 3, 2011 This thread never fails to impress! Crazy cool pan. Quote Link to comment
69FJWagon Posted December 4, 2011 Report Share Posted December 4, 2011 After adding the engine weight, the pan hit the x member :/. so the front needed some notching Man that pan looks awesome!!! what would it cost to build me one??? I hate my front sump pan on my FJ in my wagon Clayton Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 I think I would have added a bit of tilt to the pan, to help collect oil for oil changes. Other than that, I like this option over cutting the crossmember. I actually thought about that... I guess ill run it for a wile then check for sludge buildup later? That is the fucking craziest oil pan, haha! Awesome, dude. This thread never fails to impress! Crazy cool pan. Thanx guys. Yeah my fabricator is good. All fabrication credit is due were its deserved! Man that pan looks awesome!!! what would it cost to build me one??? I hate my front sump pan on my FJ in my wagonClayton Well you would have to talk to my fab guy daniel. Pm me if your serious about it and ill give you a contact number. Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Second pan begin modified to take the first oil pan sump Cut the first sump off the first pan... Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 First pan enclosed second pan all closed ready for sump Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Apply weld now Blam fully modified and notched for frame Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Thats a lot of welding and modifing Oil pick up Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Hmm oil drain bung convineintly made from huge bolt Oooh paint Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Skid plate! Skid plate from the back All painted and installed. Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 Notched the pan for the steering center link, still needs some loving... Yep yep its that tight.... Oh yea its that tight All ready to leave. All done and ready to leave Quote Link to comment
ZackTheImpaler Posted December 4, 2011 Report Share Posted December 4, 2011 Fucking crazy build man i can't believe I didn't notice it before. I just looked through every post. I love your oilpan setup. I thought I was slick for swapping mine and having to cut my own gaskets haha!!!! You are moving through pretty quickly though. Great car. Quote Link to comment
jdmdime Posted December 4, 2011 Author Report Share Posted December 4, 2011 And its on its way back home finally... I raised my coilovers all the way up to facilitate loading the car onto the trailer. Its still kinda low.. Quote Link to comment
collision and customs Posted December 8, 2011 Report Share Posted December 8, 2011 WOW!!! I like where this is goin. Quote Link to comment
