78dattysun Posted November 11, 2011 Report Share Posted November 11, 2011 How important is it to use a syncing tool when syncing dual 44phh mikuni carbs, or is it possible without one? Im guessing no. but I wanted to ask somebody else. Quote Link to comment
metalmonkey47 Posted November 11, 2011 Report Share Posted November 11, 2011 I'd say it's pretty important. You want your car to run consistent right? There may be a trick to tuning it without one though, and just using a single vacuum gauge. I read about it a while back when I was wanting to use ITB's Quote Link to comment
Sealik Posted November 11, 2011 Report Share Posted November 11, 2011 2 vacuum gauges on mani, 1 for each carb...if you have the ports of course Maybe.... :D Quote Link to comment
flatcat19 Posted November 11, 2011 Report Share Posted November 11, 2011 Not using a uni-sync is like dividing by zero. You're fucked without it. Just kidding. I would imagine that it is way more accurate than tuning by ear and smell. I would also believe, short of having a 5-wire wideband AFR guage, that a unisync is the definitive way. Anything else, and you're just guessing. ;) Quote Link to comment
Sealik Posted November 11, 2011 Report Share Posted November 11, 2011 You can use the uni-syn, listen with a hose or... the vacuum gauges...basically measuring the amount of air getting sucked into the engine, relative to each carb, which has to be the same Then use the wide band to dial the mixture in Quote Link to comment
Elkie Posted November 11, 2011 Report Share Posted November 11, 2011 It'll run, but most likely idle horribly, and have a loss in power. Quote Link to comment
Draker Posted November 11, 2011 Report Share Posted November 11, 2011 I've got a set of these. Don't know if they will work for you or not. Quote Link to comment
datzenmike Posted November 11, 2011 Report Share Posted November 11, 2011 All the uni-syn does is help to adjust the idle air volume so that multiple carbs are drawing the same amount of air. Otherwise two cylinders are holding the idle and two are not doing enough work. You can do the same with a piece of garden hose held at the throttle opening. Adjust till the hiss sound is the same. Quote Link to comment
Elkie Posted November 11, 2011 Report Share Posted November 11, 2011 I have those synch's as well draker for my cb550's, I'd recommend spending the extra $50 for a decent one. Quote Link to comment
Draker Posted November 11, 2011 Report Share Posted November 11, 2011 I have those synch's as well draker for my cb550's, I'd recommend spending the extra $50 for a decent one. I got them for my CB750. Seemed to work good for that application. Quote Link to comment
Skib Posted November 11, 2011 Report Share Posted November 11, 2011 if your asking then its important. I tune my SUs without them, but Iv done it a million times. my ear tune is pretty dead on to the sync. lol ask nismo dr. Quote Link to comment
Hardwyre Posted November 11, 2011 Report Share Posted November 11, 2011 How important is checking the prostitute for an adam's apple before you turn off the lights? PRETTY FUCKING IMPORTANT. You can always get away without doing something; but not doing so may result in some uncomfortable situations. Quote Link to comment
datzenmike Posted November 11, 2011 Report Share Posted November 11, 2011 How important is checking the prostitute for an adam's apple before you turn off the lights? PRETTY FUCKING IMPORTANT. You can always get away without doing something; but not doing so may result in some uncomfortable situations. Say AHHHHHH... Quote Link to comment
78dattysun Posted November 11, 2011 Author Report Share Posted November 11, 2011 Awesome thanks for your guys help and advice. Im just a little broke to buy a uni sync now and im exited to just throw them on. I was hoping i can get away with it but im guessing not. Quote Link to comment
Sealik Posted November 11, 2011 Report Share Posted November 11, 2011 Need a sticky for SU carbs. http://www.z-car.com/510/S_U.html I've amassed quite a bit of info... :D Quote Link to comment
paradoxx Posted November 11, 2011 Report Share Posted November 11, 2011 just as Ski,says....i you are old enough, hm hm i mean, experimented enough you can do it by ear, which is not my case,I use my uni-syn. Quote Link to comment
