atkinson40 Posted September 21, 2011 Report Share Posted September 21, 2011 My kid's got my impact. Any holes in the motor I can stick something into to keep the flywheel from turning while I use a breaker bar to get the 19mm bolts out to remove the flywheel? I can't find any. -K Quote Link to comment
Sealik Posted September 21, 2011 Report Share Posted September 21, 2011 Coat hanger works Quote Link to comment
Wide14u Posted September 21, 2011 Report Share Posted September 21, 2011 coat hanger never seen that but i like it Quote Link to comment
Sealik Posted September 21, 2011 Report Share Posted September 21, 2011 coat hanger never seen that but i like it Yes...simple and rather effective :D Quote Link to comment
DanielC Posted September 21, 2011 Report Share Posted September 21, 2011 This picture should be pretty much self explanatory. Quote Link to comment
banzai510(hainz) Posted September 21, 2011 Report Share Posted September 21, 2011 I made a Bar as Daniel C when I saw this photo Quote Link to comment
DanielC Posted September 21, 2011 Report Share Posted September 21, 2011 I am so honored to give an idea to banzi510. I know his ideas have helped me also. Quote Link to comment
datzenmike Posted September 21, 2011 Report Share Posted September 21, 2011 Just make sure it's locked on and just give it a hard yank. The inertia and compression is enough to hold it. I've never locked the crank to remove the front pulley bolt yet. Put a ratchet on and kick sideways with your foot. Quote Link to comment
banzai510(hainz) Posted September 21, 2011 Report Share Posted September 21, 2011 Daniel Yeah I made it . I used a 225mm flywheel to make the holes then when I went to put my 200mm on I said WTF. Then I remebered the hole spacing(200mm) is different on outer clutch bolts. hade to make another hole. I was using a borrowed flywheel hand held type holder. But after dropping my TESTICLE holding it I decided to make a bar as you shown. PS Now Im known as the UNIBALLER!!!!!!! 1 Quote Link to comment
atkinson40 Posted September 21, 2011 Author Report Share Posted September 21, 2011 Just had a thought. My motor is still in the vehicle. I'll try putting a socket and wrench on the front pulley bolt and try to brace it against something to keep the motor from turning. -K Quote Link to comment
